Posts posted by robdurant
Hi all,
More progress on the deck furniture.
I made up the second ladder for the aft deckhouse, and the ladders that lead to the raised deck at the bow.
And I've made up the stove chimney for the galley using styrene tube (the kit calls for 5mm dowel, but I couldn't see how I would get a nice even bore through the dowel that looked to scale) - I also used 4mm dowel as it's a little more dainty and looked better to my eye.
The hole was made in the deckhouse roof as per the plans, and here's the chimney dry-fitted. Thing is - now I'm tempted to put the stove in the deckhouse! Not least because there's a door opposite! Hmm... door open? door shut? And what would the stove have looked like? All thoughts welcome!
Finally, I've started making up the companionway that sits beneath the raised deck at the bow. In the kit it has a flat roof, but I wanted to add in a curved roof from side to side, and also make sure the fore and aft walls were perpendicular to the waterline. It will have curved corners like the deck houses. The line running through the parts is the level that the bottom of the internal former will sit at to be horizontal to the waterline and to clear the king plank running along the deck. The lines running vertically on 3.5mm either side of the corners are the lines I need to cut to so that there's room for the corner mouldings, which are 3.5mm quarter round styrene. You can see on the left, I've already put a support underneath that line on the port wall of the companionway - this will make gluing the whole thing together much easier, and although the styrene is only 0.5mm, it should be a good strong structure.
As I look at the model now, I'm beginning to realise how much more restricted a lot of the rigging points will be compared to a Napoleonic frigate, for example... They're all tucked away below bulkheads and between deckhouse and hull side, etc... In addition, once the companionway is in place I'll lose pretty much all access to the space in front of it beneath the fore deck. Plenty of thought will be needed to ensure I don't paint myself into a corner. (Not least because I neglected to follow the instructions and have already glued the fore deck down!)
Anyway - it's going okay so far.
Happy building, all!
Rob
- chris watton, ccoyle, Keith Black and 7 others
- 10
Oh yes, and I forgot to show the CAD drawing I did, so here it is as a jpeg...
... and attached as a PDF, which is the right scale in case anyone wants to follow along. Do note, though, that the rungs should be 11mm long for the aft deckhouse of Stefano.
- Keith Black, dunnock and Ian_Grant
- 3
I've been looking at the ladders that go on deck today... I've found a couple of pictures of ladders on Cutty Sark, which are providing some input alongside the kit plans.
This photo is © Copyright Christine Matthews and licensed for reuse under this Creative Commons Licence. In fact, I found a very similar photo taken in the same place that had a person standing in it, which helped with the scale.
I drew up a plan for the ladders based on this, and taking into account the perspective effect. It worked out to have a rung height of about 25 centimetres. Then I went back to the Barque Stefano plans, and cross-checked the dimensions... there would be less rungs necessary for he ladders at the back of the aft deckhouse, but the angle was good, and the dimensions close to those on the plans. The difference was in the thickness of the materials suggested.
I decided to create two jigs. The first would allow me to cut rhomboid shapes which would go above and below the rungs and hold the rungs at the correct angle (6 degrees from horizontal) and spacing. These would be stuck to solid outer sections to create each side of the ladder. The second jig allowed me to cut the rungs to size consistently. These jigs were quickly made out of styrene.
The whole structure has been made out of 4x0.4mm walnut strip.
The jig for cutting rhomboids...
The rhomboids cut...
Constructing the sides of the ladder... A strip of the rung material was placed between the rhomboids until they were fixed in position to ensure the gap was right.
And the sides completed... (but left overlength at the top and bottom...
Rungs glued onto one side...
And the finished structure...
Finally, a shot of the ladder (still untrimmed at the top) dry-fitted in place. The aft edge of the deck house roof will be trimmed back to allow the ladder to attach firmly.
I like that the rungs look so light. Often on kits, I feel they look a bit oversize.
Right - that's it for this update. Happy building to you all, and thanks as always for the likes!
Rob
- dunnock, yvesvidal, Keith Black and 3 others
- 6
On 3/21/2022 at 7:47 PM, JSGerson said:
I remember someone had commented somewhere on another build log that one should paint the white styrene, white. He claimed that over time the plastic tended to yellow a bit.
Hi, Your Constitution is looking really great! Styrene does discolour if it's left on sunlight without some sort of protection, such as paint... I have some sheets that were left out near a window that gets plenty of sun (I live in England, so nothing too ferocious) over the period of a summer, and it ends up looking like this... The fade is because one side end was nearer the window, so got more sun. To the right is another part of the same styrene sheet that didn't get any sun, and it's on top of normal white paper to give a colour comparison. I believe it's to do with chemicals leaching out, so some styrene is more susceptible than others, but others would doubtless be able to give a more detailed explanation. Definitely worth painting it, though.
On 3/18/2022 at 9:41 AM, Punxsutawney_Phil said:
Thanks for the advice. I will look into it. Let‘s see if I can find something for Apple machines…
Aah - yes, that windows app won't help you much on an Apple - On my mac, I use an automator file... It's a batch script that allows me to select the files I want to resize, and then copies them, resizes the copies, and changes the file name as it does it to reflect the new image size. Automator comes with Apple OS X, so no cost involved... The screenshot below shows the batch file open in Automator... Once you save it, all you have to do is click the .app file, and select the pictures you want to resize.
If you'd like a copy of this application, let me know, and I'll send you a copy.
Rob
Hi everyone,
Not so much an update today as a few photos that might be of interest. I was re-making the dust cover for Ethalion, and thought I'd grab the opportunity to take some pictures of HMS Ethalion (the Caldercraft HMS Diana kit, bashed a bit), and the Barque Stefano to date...
I find it fascinating to see the differences and similarities between the two...
I've got a busy few weeks coming up, so there may be a bit of a pause before I'm able to give any more updates. Fear not, though. I'm keen to continue with Stefano asap
Rob
I've made the binnacle. I used the RB models binnacle for inspiration - It's really good, but made for 1:50 - too big for Stefano.
Instead, I used it to work out the dimensions of a binnacle at 1:63 - it works out 23mm high - 1.4 metres at scale.
I turned the main structure from 10mm lime dowel, then added a paper trim round the centre of the compass housing, a styrene viewing window and painted it. A 1.5mm rod was left on the bottom to provide a stronger joint with the model.
I also glazed the skylight with transparent plastic, and used a couple of plastic battens to ensure it wouldn't fall into the model. A walnut trim was added to the inside of the skylight, and another walnut strip to the partition in the deck house where it was visible through the skylight. No pictures of that right now, but I'll try and add some later.
Happy building!
Rob
- yvesvidal, ccoyle, Keith Black and 3 others
- 6
Hi Phil,
She's coming along great. At that scale, those curves in the hull create a real challenge, but you're making good work of it!
On 2/23/2022 at 9:28 PM, Punxsutawney_Phil said:I don't know why the pictures are the wrong way around. They're fine on my computer...
You're not the first person to find this a challenge. Take a look at this thread on... It's a free windows application I programmed to help get rid of those problems (which are caused by information inside the image file that your camera or phone sets when you take the picture, but web browsers don't pay attention to).
All the best with your build.
Rob
Hi all,
I've had a lovely day today cracking on with Barque Stefano, and it's time for an update (in amongst being dad's taxi ).
I've been continuing to work on the deck furniture, and among that are the skylight and companionway. The kit suggests these are built on balsa blocks, but I've never much liked that mode of construction, and the aft superstructure had gone so well, I was contemplating making the skylight the same way, with the 3.5mm radius corners, but when I started to draw it up in QCAD, I realised the corners were going to be well oversize for the skylight and could look a bit silly - especially when the angled top was put on with its squared off corners. Instead, I used styrene to construct the main housing of the skylight. Measurements were taken off the plans, and I made the sides to maintain the angled front and back, as per the main superstructure (which sits on the fore-and-aft angled deck. This angle turns out at approximately 3 degrees.
Once constructed the skylight was placed on sandpaper that was placed on the cabin deck to sand in the curve in the deck so it could sit flush. Unlike the structures that sit on the centreline of the main deck, there is no raised king plank here, so it's an easier task.
Once the size was finalised, I could mark the cut-out on the superstructure deck and drill a hole for access, then and cut it out with a coping saw (I tried chain-drilling it, but it was very heavy going, as the plywood false deck makes for a very substantial structure. I scored through the planking where I was planning to cut to avoid the planking lifting as I went.
And a picture of the structure in place with the skylight hole cut.
Now attention turned to the panels that form the lights on the top of the skylight. I wanted to end up with something like the effect seen on Cutty Sark as posted by Nenad here (thank you for the inspiration!):
The kit shows a few upright bars, but I wanted lots of horizontal bars that were much lighter in diameter. So I made a walnut frame, and then a styrene frame to sit on top of it to simulate the metal guard. I still feel it's a little heavier than I would have liked, but it's heading in the right direction.
Here they are being primed...
And once the skylight itself was painted, they're put together. There are still some details to be added yet to add glazing from the inside, and to tidy up the inner edge of the superstructure deck.
And here it is sat in place (but not glued on yet), showing a hint of the patterned deck below...
Next up is the companionway.
Thanks as always for the likes.
Rob
Hi all,
Thanks for the likes!
I've been blessed with a few evenings to work on Stefano over the past few days, so I have a little to report.
With the foredeck filling up, I decided to paint the bitts matt black instead of leaving them walnut. They'll complement the anchors nicely that way.
I've also put together the anchor stands with their metal parts that clamp over the anchor to stop it moving round in heavy weather. The suggestion in the kit is that the metal strap over the anchor is made from copper strip. I reverted to a tried and tested technique and used 2mm wide strips of black card. These were detailed with eyelets glued onto brass pins and cut short to represent the hinges. It's not perfect for detail, but at 1:63 it gives that suggestion of detail that approximates what's going on.
I used masking tape to stop the anchor bar (proper name?) from flopping around while this was being done. The bar gets tied down with rope, and I've done this on one of the anchors - a very fiddly procedure!, but I don't have a picture yet. I'll put up a picture once they're all done.
It was then that I got distracted again. I started thinking about the figurehead. The kit provides a block of wood and encourages the modeller to carve the figurehead. Thankfully, I had a figurehead left over from my HMS Ethalion based on the HMS Diana kit by Caldercraft. In that build, I scratch built a figurehead from a greek figure and a dolphin's tail...
The Diana figurehead was the perfect size for Stefano with a couple of modifications:1. The decoration where she sits on the bulkhead was cut off.
2. The tails of her dress needed to be bent outwards along with her legs to accommodate the stem and bow of the vessel.
These figureheads can be purchased separately from Cornwall Model Boats, I believe.
I was worried she'd get a bit cold in the Atlantic breeze, so I added a little modesty and gave her a dress that covered both shoulders, and filled in the gap where she would have sat on the Frigate's beakhead all using Fine white Milliput. Once done, the suggestion is that the whole figurehead be painted in gold, but I used a mix of Vallejo brass (which is a little toned down compared to their gold) and "Ivory" for her skin, again to tone it down a little. A pen was used for the eyes, as it's easier to control than a paintbrush!
Here are some pictures of progress...
As she was at the beginning of the process...
Starting to add the dress...
Adding dress details...
And beginning to paint her...
And once she was painted she was added to the bow...
Overall, I feel she's a great improvement over anything I could have carved from scratch, and since she was sat in a parts box doing nothing it's a win-win situation!
I'm really pleased with the way the ivory and brass colours work together, and from a distance she really makes Stefano look smart! I'm also pleased that, much like the figurehead on the plans, she has one arm outstretched.
Thanks for looking in!
Rob
Right. Time to behave and get back to the build in order.
The next step was the "remaining elements of the foredeck". Firstly, item 30 - the bitts. There are six of these, each comprising two vertical posts which are shaped from 4mm walnut dowel (I struggled to get a nice round section, so ended up using some 5mm dowel instead), and a plate made from a 15mm length of 1.5x5mm walnut strip. Using the Proxxon DB250 lathe, I was able to turn these uprights reasonable consistently. Unlike the columns on the aft cabin these will not be in a line next to each other so if they vary a little it's not such a big deal.
Here's a picture of the foredeck so far, with the bitts placed roughly in position. Nothing on the foredeck is glued down yet. I've also put together the belaying pin rack (49) which can be seen at the bow. Again, I replaced the belaying pins with thinner ones.
And a picture of the stern area with the bitts roughly placed in position...
And finally an overview of the whole vessel so far... (I'm waiting for some 8mm dowel to make the mizzen mast).
Next up in the instructions is detailing the anchor davits and working on the vertical windlass.
Happy building!
Rob
Hi Don,
It's looking great! That's a lovely neat line you've got where the starboard and port planking joins up at the stern.
It's probably already occurred to you, but when you get to putting the stealers in, it's worth trying to make them terminate on one of the bulkheads rather than in the gaps between. That way you shouldn't have any problems with them dipping into the hull or sinking away from the sandpaper or scraper when you're trying to get the hull smooth. Ask me how I know
Looking forward to seeing your next update!
Rob
Hi,
Thanks for the likes and encouragement. There's more to be done on the deck houses, but I fancied a bit of a change, so I've been working on the main mast. This is made from 12mm dowel. It narrows to just over 11mm as it gets towards the top, then there's a flat section on both sides for the top cheeks which becomes 8mm square, then becomes 5.5mm square for the last 5mm where the mast cap fits.
The plans are excellent. Very clear, and with all the information you need clearly laid out in 1:1 scale. I was really impressed. Sadly the dowel was both too long, and too large a diameter for my lathe and my drill, so gently hand sanded the dowel to create the taper. In retrospect I should have created the square section at the end first, as having this taper made it harder to then create the square section. nb: You will need to leave enough diameter to ensure the square section will not have rounded corners. Pythagoras tells us that for an 8mm square, the minimum diameter will need to be the square root of 64 + 64, which comes to 11.32mm (to 2d.p!), so don't reduce the dowel beyond that.
I used the lathe three jaw chuck as a means of seeing whether I'd lined the mast up at the right angle for filing the edges.
It's not perfect, but it's getting fairly close to how I'd like it to be. The mast cap is a laser cut part, an I opened up the cap slot to allow it to sit horizontally rather than follow the mast's rake.
I'll take a picture of it in the daytime tomorrow as the light will result in a terrible photo this evening.
Rob
- yvesvidal, Keith Black, BobG and 2 others
- 5
Hi Don,
Looks like a solid start. Hope you won't mind if I follow along.
Rob
I've placed the columns on the other side of the aft cabin deck. Once the glue was well set the whole unit was turned upside down and very gently rubbed over sand paper to add the slope to the top of the columns ready for the railings. The railings were made of 15cm lengths of 1x4mm walnut, with a 0.5x2mm walnut strip glued down the centreline stopping a millimetre from each end.
I've also started detailing the insides of the aft cabin with a tiled floor made from 0.13mm styrene. The styrene had 6mm masking tape placed in stripes spaced 6mm apart. It was then painted black and cut across into 6mm strips. These strips can then be used to create a checkerboard tiling pattern. The pattern was glued diagonally onto the floor of the cabin, and the partition wall glued in place over them, such that when looking through the doors, the floor continues into the main space of the cabin.
And the finished result, looks like this. Only a hint of detail, but I think it's quite a nice addition to add interest (and we'll just ignore how brutal the close-ups are!). Since this photo I've glazed the portholes with Humbrol ClearFix as I did with the other cabin.
The finished result so far...
More soon
Thanks to you all for looking in, liking, and encouraging me along on this build. I'm finding it fascinating and fulfilling, and it's nice to know that others are finding enjoyment in it, too!
I took another look at the cabin roof, and compared it with those on the Cutty Sark, and realised that the profile was the opposite way up (thick at the top and narrow at the bottom). Not a big deal, but it niggled at me, and I decided to try it the other way round.
Through my own laziness in not taking progress shots, I also neglected to take photos of me sticking planks onto the cabin roof only to realise that I hadn't cut them to scale length... so - here are some shots of the work, which I obviously got right first try!!! 🙄🤣 One of the benefits of re-doing it, is that I realised it made sense to plank from one end, over the other end, and then sand it back to get a neat transition to the surround.
Then the surround was glued in place...
And the profile was carefully filed back into the corners where the joins were (yes, I wimped out of trying to do neat 45 degree mitres!)
Then it was a case of rinse and repeat for the aft deckhouse, with the added challenge of making sure the hole for the raked mizzen mast was in the right position. (Achieved by measuring back from the front of the deckhouse when the deck was not in place, and then transferring this measurement (plus the overhang) onto the deck.
The next thing I wanted to have a crack at was the railings. They could probably wait a bit, but I was itching to see what they looked like! There are 17 each side, covering 140mm between the centres of the columns at each end (at least on this interpretation!), and that leads to an 8.75mm gap between column centres along the row.
The aft deck has a 3 degree slope, rising from front to back. It also has the camber to allow water to run off. I made a jig to allow me to file the bottoms of the columns evenly to 3 degree angles. By turning the column slightly so that the angle faced inboard, I could account for the slope fore and aft, and the camber.I've drawn a very rough diagram here...
And the actual jig looks like this... You can just see the column poking out from the end of the styrene tube.
When the column was removed from the styrene tube, I marked the top to show which direction the angle was (it's barely visible to the naked eye!) Then these marks were used to line them up as I glued them in place. I've only done the starboard side so far.
When the deck is laid flat you can see the angle (I made up a small 87 degree angle piece to check against.)
And a few pictures of the side, finished.
The wide angle lens makes the end columns look like they're at different angles, but they are in fact all as near parallel as I can get them.
I'll gently sand the top to add the angle to the columns for the rail, and once added, the whole structure should be reasonably strong.
Right. I think that's enough for this evening. Happy building to you all
Rob
Thanks Vladimir
I've been planking the cabin roofs so I hopefully should have another update by the end of the day.
I tried glazing some of the portholes, which seemed to go very well. More practice would not go astray, but that's the beauty of Humbrol clearfix, you can just go back and have another crack at it.
I have yet to put the portholes into the aft superstructure.
I used my violin rib bender at 230 C and water to warm the ply roof formers and introduce the curve of the deck (it never seems like a good idea to me to simply try and make the glue force wood into a curve).
Then I took some walnut 4x3 strip and using Artesania Latine micro shapers (https://artesanialatina.net/en/micro-tools/1296-micro-shapers-b-wooden-plastic-models-miniatures-tool-8421426273014.html - the bottom right shape of the middle scraper in the picture on this site. The profile was put into the entire 1mm length of the strip, and a length of it bent vertically to match the contour of the cabin roof.
It was glued to the cabin roof clamped with a 0.5mm strip on the plywood so that there was a lip of 0.5mm. THis means the decking should sit flush with the surround, eventually. That's the plan, anyway. In this photo you can see the profiled strip at the back, and I'm gluing each end to the cabin deck ply.
Once the pegs are removed it looks like this...
And because I used plasticard for the spacer, it doesn't stick to the carpenter's glue I used for the wooden strip. It simply lifts away, leaving the lip for the decking to be applied.
And here's a decking strip which seems to fit nice and flush. (I do love it when a plan comes together )
The next task is to cut nice neat mitres at each end of these pieces so that I can add the lengthwise edges. Before I do that I'll plank the deck, so I can get the edges really nice and neat. That way, when I glue the edges on, they'll simply butt up against the decking, and I won't have to worry about the 0.5mm lip.
More soon
What a great idea! You've reminded me, I have some already tucked away in the back of my paint cupboard I shall fish it out and see if it's still serviceable. I've used it in the past on a 1:96 destroyer, and it was brilliant. I've just got out of the habit, because my more recent models have had gunports or stern lights! It's useful for sticking in clear plastic without clouding it, too.
- Keith Black and BobG
- 2
Thank you Rob.
33 minutes ago, rwiederrich said:Are your port holes going to have glass in them?
Yes, I shall glaze them from behind. I'll probably used clear plastic, as I have some left over from a previous build. I was thinking that a hole punch might be a neat and efficient way of making the circles.
Thank you Rob.
Again, a little progress this evening. I have drilled and filed out the porthole openings in the forward superstructure and fitted the portholes. The deck is as yet unbent, but I'll bend it with water to give it a water run-off.
I've also found some columns for the railings that are close to those on the plans. These are Amati walnut 12mm columns (I bought 70 of them, which should be enough, with a few left over!).
And a few lined up for effect... They're a tiny bit over height so that I can file the angles into the bases and tops to make them vertical on the model (even though the deck is sloped a few degrees.)
Happy building all
Rob
- Beef Wellington, BobG, dunnock and 6 others
- 9
Barque Stefano by robdurant - MarisStella - 1:63
in - Kit build logs for subjects built from 1851 - 1900
Thank you Rob. Yes, I think leaving the deck houses loose until as later as possible sounds very sensible. I'm trying not to glue down anything I don't really need to at this stage, as I feel my way through the build.
