Posts posted by Alex M
Very fine planking, Toni! I also like the contrast between Holly and Pear!
Alex
That is a fine work, Albert! Very clear and nice! And I ask also for you other models (four if I'm correct?) Do you work on them parallel?
Alex
Thanks Tom, why intimidating? I have seen your Vinal Haven, very fine work at that scale! Will be Sphynx your next model?
All things are difficult before they are easy
Regards
Alex
- Trussben, Jorge Diaz O and mtaylor
3
Thank you very much!
Alex
Hello all, many thanks for warm words and comments!
not a big update,I have produced stanchions for the ladderway rails. The images are mostly self explanable, I hope
They are turned on Unimat from 1,5mm brass road. Then finished with steel whool on Dremel Tool. The rings are from 0,3mm brass, the rails from 0,4mm.
Finally installing around ladderway after blackening
Continue to work at Q-Deck beams, and how she look now.
Next step will be Capstan.
Regards
Alex
Hi guys, and many thanks for your comments and warm words!
Robin, I have read your thread about paneling, I will try to add some things I have researched of this subject, but It's hard to add sometimes really new to been said by others.
Alex
Hi Mark,
such inboard profiles are usually as designed, copies are sended to ship yards and used for all ships of the design. It can be, that the dashed line represents just a difference between design and particular ship as build, or it is later plan with alterations for further ships, or some else, but not aft face or thickness of frames. In this case the line should run more or less parallel to rabbet. With other words, as I assume, the dashed line show the true rabbet of Bellona, because the line match the fore perpendicular. And the plan show probably later ships slightly largened
Alex
Hello and many thanks for warm words! Now it's time for litte update. Firs the last hanging knees in the cabin, I have decided to make them a little compass:
Then completted fore bulkhead of captains cabin, I leave the doors half open as in the rear bulkhead:
I hope I will have more time for modeling now...
Alex
Allways a pleasure to see your updates, Johann! Lovely metal work!
Alex
Hello Marsalv,
yust found you Pandora build log and I'm amazed of very fine work! Excellent! Will follow with interest.
Alex
Hello guys,
many many thank you all for warm words abuot my plans! I'm still alive, but was very bussy last vew months with our web page and forum, as Herbert mentioned.
I hope I can answer your questions about modeling different parts.
Alex
Very realistic finish! You really make brass to iron. And very fine work!
Alex
Hi Danny, very fine wheel! And very good step by step showed!
Alex
Hi Remco,
absolutely incredible details, and very crisp and precise work! I will follow you build to the completing!
Alex
- dvm27, EdT, newbuilder101 and 26 others
29
Hi Pat, I'm using german version of PhotoShop, so the names of functions may be wrong. For rescaling e.g. from 1:48 to 1:24 go to Image->image size option, change units to %, and type 200. Check the "maintain ratio" and "recalculate image" ckeckbox. Click OK
The formel for scale ratio in %: divide given scale by need scale and multiple by 100.
Alex
Hi Dan,
lovely looking fenders, and your metal work is incredible! Your Vulture is one of my favorites here on MSW!
Alex
Hi Gaetan,
what a incredible puzzle work on those beautiful galleries! Awesome.
Alex
HMS Vulture 1776 by Dan Vadas - FINISHED - 1:48 scale - 16-gun Swan-class sloop from TFFM plans
Hello Danny,
very impressive work on masts! Your details are amazing! Also very good rigging. A pleasure to follow your log.
Alex
