Posts posted by Alex M
Nobody knows? @tkay11, You has a lot of images from Cutters in the Gallery, kan You probably answer?
- Jorge Diaz O and tkay11
- 2
Hi all,
I kmow that common practice by Cutters was eye splice, but as I have seen two original models with a mouce, just a question...
Alex
Hello usedtosail,
The partner of a capstan was usually made of four pieces, fastened with clenched bolts. Two inner parts are parted in the middle to allow easily remove of them to lift the capstan for maintenance or some other purpose.
Regards
Alex
- usedtosail and mtaylor
- 2
The white wood represents the pine, that was generelly used for deck planking, the pear represents the oak, used for important structural planking, and is darker.
As for me, specially by such wunderfull builds, the used wood does not matter, but the handwork, that is by marsalv simply incredible. I'm out of words.
Regards
Alex
- Hubac's Historian, Dowmer, mtaylor and 2 others
- 5
Hello,
The model above shows a double capstan, the rings are for lifting and lowering. The fore jeer capstan on two decker ships can be lowered down to make room on upper deck for i.e. boat stowage. There was a room under the capstan called capstan room.
Alex
The 20 gun frigate Sphinx is not one of Enterprise Class, but of his own Sphinx Class: https://collections.rmg.co.uk/collections/objects/83710.html.
She have had no guns on Quarterdeck, no solid bulwarks and no openings in the taffrail.
But if anyone has payed for tihis it all does not matter
- FrankWouts, mtaylor and Jack H
- 3
Hi Siggi,
by the rum... if you need more painters let me known :)
stunning work!
Alex
- mtaylor, Siggi52, Keith Black and 1 other
- 4
Hello and many thank you for warm words and likes!
the fenders are completted:
Regards
Alex
- druxey, KARAVOKIRIS, Dowmer and 14 others
- 17
Hello and thank you for warm words and likes!
The "head pieces" (is it right term?) are usually represented on the contemporary models as one piece of wood. On the plans that show this area in detail, you can see a small rail attached:
So I have tried to implement this:
They are first fixed with a few drops of glue, because I still have to adjust the seats of ease in the corners
Alex
thank you druxey, and you are so right! On model is third attempt, and here the waste
Alex
Thank you for all likes!
Small update, the gatings are completted
Alex
Mouse on Cutter Stay
in Masting, rigging and sails
Thank you Tony! If you mean this Cutter: https://www.rmg.co.uk/collections/objects/rmgc-object-66471 , it is not contemporary, but build ca 1940.
Alex
