Everything posted by mij
HMS Alert 1777 by Jaekon Lee - 1/64
mij replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
Hi Lee I`ve just picked up on your very fine and beautiful build log. Full credits to you. Kind Regards mij -
I`ve had my Proxxon lathe for about 3 years, its a nice little lathe for what we do. Regards mij
Home Built Thickness Sander
mij replied to Snowmans's topic in Modeling tools and Workshop Equipment
Nice one Snowmans, I like it. mij -
Pandora by marsalv - FINISHED - 1:52
mij replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Hi Marsalv Your work is very neat and tidy. Very nice. Kind Regards mij -
This is the way I bend my planks. Bending 4x1mm cherry over a home made plank bender. The planks are placed in cold water for about 10 minutes, then taken out of the water and then placed over the hot plank bender and worked to the shape you require. Use the water as frquently as required. Kind Regards mij
The way I tension my blades is to tighten the blade with the tension knob until you can flick your finger on the blade and get a clear ting from the blade. Hope this makes sense mij
Xebec by mij - FINISHED - 1:60 scale
mij replied to mij's topic in - Build logs for subjects built 1751 - 1800
Hi John All I worked with was a set of drawings and everything was scratch built. The carvings were my own design and were carved from box wood. To loosen the grating area, try lifting the glued wood with a scalpel, But be very gentle. Good luck mij -
Hi Dan A very nice professional job, I look foreward to seeing more of your great work. mij
- 241 replies
- queen annes revenge
- pirate
