Posts posted by Kevin
- GrandpaPhil, G.L., mtaylor and 5 others
8
3 minutes ago, popeye the sailor said:
you could go that route....it looks Ok. I think though that it employs a few different materials and might not last too long before coming apart. how about you keep the turn buckles the way you have them, and when you rig them..... slide small brass rings to create a loop in the cable, trapping the turn buckle in the loop. cement or anchor them in place on the deck. then tighten the cables within the rings and apply a bit of solder or CA when the proper tension is achieved.
lol bit tired tonight, im trying to visualise how that will work, i will give some thought during doggie walkies, be back soon
27 minutes ago, mtaylor said:
Will this ever actually see water or is it a static display. That's an impressive amount of work to get everything working and lit up.
all the running gear is in place she will see water soon, for test trails and ballasting
- mtaylor, popeye the sailor and egkb
3
5 minutes ago, mtaylor said:
Rats... pity that as it would have made the tightening and adjustment so much easier.
Mark i could make some, well i say make, i could chop the threaded bits off and push them into a hollow tube, BUT am i doing the wrong setup for this build, should it be deadeyes like on the foremast
3 minutes ago, mtaylor said:
Hmm... just curious, Kevin. Regarding the tensioning... do the turnbuckles actually work?
no Mark, just 1 piece white metal
15 minutes ago, Jim Lad said:
Kevin, I'm a bit late on this discussion, but steel wire rope was usually a very dark grey unless very new. That might give you a few more options. I would suggest that a trawler of your model's age would have shroud eyes spliced around thimbles - easily done by the crew.
John
i wonder how Mountfleet got this wrong, and have these aft and deadeyes fwd
On 2/16/2020 at 7:49 AM, DanielD said:
Thanks ASAT! I have really enjoyed this level 2 (beginner) model and I love the double hull design. I have my eye on a level 3, the HMS Terror, but not sure yet. I’m open to suggestions...
my second build was the Royal Caroline by panart
https://www.mantuamodel.co.uk/products/ship-kits/panart/443/royal-caroline-detail
hope this comes out, rigging and aerials left to do, then ballasting
ooooo a fly thingy
lol looking good OC
- mtaylor, Canute, popeye the sailor and 1 other
4
that is absolutely fantastic
lovely work
Good evening everyone
Thank you for like and comments
there was certainly far more reference material for the Victory, there are tons lots of phots of trawlers but they lack any detail, but i try to proceed onwards
the shrouds, certainly appear to be wire on the after ones hence the turnbuckels so i have been playing with thread and various colours of grey and silver, the one in the final shot is a warhammer silver and will see how this goes
next will be ratlines, i am still undecided if i should go with wooden slats or wire, or the same as the shrouds
31 minutes ago, yvesvidal said:
Kevin,
How about soaking the ropes in warm water for a little while, placing them under tension to the best of your abilities and then let them dry. A dry rope is always shorter than a wet rope.
Old barometric devices were based on that principle.
Yves
im trying to replicate wire rope by using it, but the mast is very flexible, as i replaced it from wood to plastic tubing so as to run electrics through it, so it is very difficult to get any decent tension on it
the rope is fine, but i want it to look like wire
good morning everyone
thank you for the comments
there is a deadeye arrangement set up for the fore mast and these turnbuckles for the after one, again i presume that it is a mixture to allow removing the mast for transport to shows and ponds
so on the main mast there are 3 shrouds and the back stays, i dont have are wire that would pass the test, could a silver stained rope representing wire pass?
the fore mast is going to be a while away
if i get something that resembles the wire i could ten use them as ratlines, but will not get the tautness, so maybe a single wire would work, go go to wooden battens
lol any suggestions?
this is Mountfleets show kit
not progressed much at all since the last update, lol i dont think im confused so much now,
the main mast is supported by stays, but very few is any show any ratlines,
the instructions do say that the shrouds can be adapted to enable the mast to be removed for transportation purposes, so from that i presume from that no one went to the trouble, even though the superstructure is removable
mine will have ratlines, again the instructions call out for wire to make them, is this right?
- mtaylor, kees de mol, FriedClams and 7 others
10
lovely build, and lots of fantastic off topic tales (or donkey tails) to go with it
- popeye the sailor, Canute, Baker and 2 others
5
if someone told me tomorrow, no more ship building ever, then this is what i would love to do
lovely project
- popeye the sailor, Canute, Ekis and 3 others
6
51 minutes ago, Mirabell61 said:
Very nice looking build Kevin,
also the boats are kooking lovely.....
Nils
Thank you Nils
wow she looks fantastic, sorry i have not been keeping up with your progress
Good morning everyone
apart from the handling ropes the life boats are finished,
i put everything in place according to the plans, and secured in position, however the forward drum reels are set to far aft to be of use, it looked tight even on the plans, after looking at other builds and seeing the same issue they got moved about 1cm to make them more usable, i may have to move the after hatches now as they might not have enough room
the middle picture drum reels are in place according to the plans, but in reality are to far aft to be of use
reels after being moved, dont quite know what to do about the stain damage on the wood
- Jack12477, GrandpaPhil, gieb8688 and 13 others
16
4 hours ago, lmagna said:
You have already modeled two B-17s, one with gear down and both with closed bomb bay. Not only would hanging from the shelf above save space and allow all three to be shown together it would allow you to have the bomb bay open. Possibly even with bombs falling out!
or above a fire place
- lmagna, Old Collingwood, mtaylor and 5 others
8
Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
in Non-ship/categorised builds
taken in the late 60's early 70's
late time i build a fly thing
