Kevin
MSW Social Media Moderator
Posts posted by Kevin
  1. good morning everyone
    without notice the wife has been admitted into hospital, which has thrown a massive curveball in my direction, so i have decided to put all my present builds on hold like the Bounty, however i fancied doing a bit of rigging, if and when i get chance, so have brought the EX Amerigo back to the table to redo all the shrouds and rats
  2. 26 minutes ago, chris watton said:
    I am very happy to tell you that igorcap (igorcap - Model Ship World™) is now my digital carver. Igor has already done the lower quarter drop for Surprise for me, and his first main project for me will be the decoration for my next development, Agamemnon.
    Thank you, Igor!
    great result
  3. 2 hours ago, LyleK1 said:
    Great start Kevin!
    I'm from one of those logs you mentioned, that hasn't been finished...
    Long story but after a hiatus, I've returned to finish her up.
    I look forward to watching your progress too.
    Best of luck!
    Lyle
    Good Morning Lyle
    im actually been looking at yr build as it is the most advanced one i have seen and has given me quite a few ideas, thank you, link to yr build is here
    HMS Bounty by LyleK1 - Artesania Latina - 1:48 scale
    my build will be renamed as she will bear little resemblance to the original build and adapted from the kit, the wife wanted me to build her, so she will possibly be renamed "Ruth"
    i very quickly realised why so many of this kit go unfinished
    Internally the kit although bears very little resemblance to the vessel, and the kit contents to make something out of it is sparse and not very well thought out is pants to say the least, for example the cargo hold is to short as the lower foredeck is far to long, and the very high centre line, gives you a W shaped space lol.
    But i have found the biggest issue with adapting her, is keeping the frames in the correct position, other than the keel and the one side of the middle deck there is nothing to keep them lined up, the very least AL could have done was put some indications on the top deck
    if this is classed as a entry level build then double planking should have been included, i will be doing that with mine,
     this could be a fantastic kit, had they spent a few more Friday afternoons thinking about builders making and completing her
  4. Good morning everyone
    progress has been made, but a lot of going back and forth, and reworks
    my problem with this kit is the lack of any upper hull strength, all the frames are just  supported by the keel, the only deck that helps to keep the frames in place is one side of the middle deck, the rest are either been designed for the internal viewing, or are only small sections , therefore allowing the keel to flex all over the place
    thinking ahead i have been making templates to help kee things stable, but hope to show this as i move along
    lower foredeck
    removed and reduced in size, it was far to long and was adapted for the Bethia conversion to Bounty
    IMG_4656.thumb.JPG.7a1d2bb828c42c528691c7a4651741d3.JPGIMG_4657.thumb.JPG.de6a760382f5c0ab3f0864a514299054.JPG
    IMG_4588.thumb.JPG.75022e0de779dd6f163d6d7d839dd68b.JPGIMG_4589.thumb.JPG.697027cc93ca226d69cda4162751f0e4.JPGIMG_4590.thumb.JPG.5ffb3b76872723d0bbfeaa53c63771c4.JPGIMG_4591.thumb.JPG.e0529c7c863da9561233ab8ca31a2202.JPGIMG_4592.thumb.JPG.c5eeadd86447470328fe26724cef4ea6.JPGIMG_4593.thumb.JPG.aa3944f1c0bad575ee3fcf10e4ca1215.JPGIMG_4594.thumb.JPG.e68398da0e0c7e0733f38649ff9118a3.JPG
    im currently in the process  of making up some bulkheads, although unsure of what will be seen , as im undecided what cutaway needs to be done on the middle deck
    after deck remains the sameIMG_4614.thumb.JPG.278b41420834fc512e7fbc35af7e6a13.JPG
    templates
    before doing anything to the hold i duplicated the middle deck half to give me a fighting change of keeping the frames in place
    Cargo hold
    ongoing,
    i wanted to to be able to use this space, even more so after the fore deck was shortened, but the frames  where they fit to the keel were all different widths, do the three middle ones were de-bonded and made the same, i also traced the outlines to allow template to be added to the frames under the fwd cabins and the pump well
    IMG_4623.thumb.JPG.9a0ec1ad1c9fe4347e81b7fe4e0272c5.JPGIMG_4622.thumb.JPG.140715c4d17d36da624c598a8e0586c3.JPG
    now im able to use some stained 1X5mm stained lime strips to plank the hold
  5. good evening everyone
    thank you for likes and comments
    Lower decks
    perhaps overdid the staining on these, they turn much darker than anticipated, they they have been secured into the hull after the support beams were placed
    IMG_4550.thumb.JPG.388ec92ef718b2d57a97cbe53762810c.JPGIMG_4552.thumb.JPG.7c92d846c1ef0c4a7126edc1e799286b.JPG
    Hold well
    must have attempted this 5 times at least, i didnt want the open side and every time i redid it i found bits i did like, or it didnt fit as well as the previous versionIMG_4556.thumb.JPG.3c30a0c453a3b83cf42707c38fce0d72.JPG
    IMG_4557.thumb.JPG.52f4f64f6f4726d60ea780f324968260.JPGIMG_4559.thumb.JPG.612d8014d1ea29d7c4d1ec486efe1f7b.JPG
    when i had a version built that  i liked i then saw something that made me rethink it all.
    The AL version is more towards the the ship Bethia before she was purchased and renamed Bounty, as part of the conversion she had extra cabins built, and one of these sits in front of the mast well
    so i had to move the door forward and make room to put in a small extension deck, which will become the deck of the extra cabin
    IMG_4574.thumb.JPG.5853830093fad2174b94b4f8374159d8.JPGIMG_4575.thumb.JPG.4420e51a6701239df7982a8396e15988.JPGIMG_4576.thumb.JPG.8544d326cd23a7efb0e918c4039e0fc1.JPGIMG_4579-Copy.thumb.JPG.6e64f965bde6cf557a1a7b52d4d04dca.JPG
    access to this deck is via a ladder from above
    the next stage is to put in 5 cabins on the port side, but unsure how to do this, as the deck above has been reduced to allow the insides to be seen, bearing in mind the kit has nothing provided  in this area,
    hopefully i will be able to show the middle deck in place to show the problem i have created for my self
  6. first build post day 3
    day 1
    clear room, only long enough to get a good clean done, and did the kit review photosimage.thumb.jpeg.4c9c19e05f5ce864a9d007096aa4872b.jpeg
    After marking identification numbers on all the parts All the plywood bits removed . shame they dont do this at the stage they are made, after test fitting
     day 2
    i painted them in Oak, using the OcCre dye, then made the hull up using titebond original
    too yellow
    IMG_4533.thumb.JPG.4c5f6e0516b6ef398d4943116819657c.JPGIMG_4532.thumb.JPG.2fbd2a0bc385d09a0d0a3d012bbe1ad4.JPG
    day 3
    im happier with that, becomes a nice shade on top of the oakIMG_4535.thumb.JPG.9faa675a8198ed5fed2094b9c57e4884.JPGIMG_4537.thumb.JPG.a8dc0f371efb0828431bd8ac03d7aae1.JPGIMG_4539.thumb.JPG.077ea1a048ef7adbf3e3503af756f04a.JPG
    lower hold forward half deck
    on one side of each plank i marked with a permanent marker - in black
    painted the deck black, laid planks in a 3 shift butt system
    drilled holes to represent nails
    stained in oak
    IMG_4540.thumb.JPG.71bf9fb358548c09d009ff62526a82a0.JPGIMG_4542.thumb.JPG.d317c9d2bc2af15a4dc68d4c49d3c19b.JPGIMG_4543.thumb.JPG.71d66e438bf051c56486702da19476cf.JPG
    this is how she stands tonight
  7. a conversation between the wife and myself last week (yes we do talk)
    wife. i love that Viking thingy, i like the  wood effect
    me. oh
    wife, will you build something for  just me
    me oh
    wife yeah
    me, what
    wife, something like that, no copper tiles, no colours  on the hull, just natural wood, sails, bit of lighting, and see something inside like on that big thingy you build from chris
    me.  you mean Indy
    wife yeah
    Now i have everything i want in life, Ruth never asks for things very often, so i have to say yes,
    we ruled out all my on hold builds and spent a few days looking around,
    in the end this build suited all the requirements, so it was ordered and i found a copy of the AOTS by
    John Mckay 2md hand
  8. Good evening everyone
    42 days on the table and of those i did something on 39 of them and im calling her finished, i have another couple of figures to paint but im not good enough to do them
    Thoroughly enjoyed this one, quick build, brilliant online tutorials, excellent plans and wooden material, pants supplied thread, instructions, and after sales (but im very well aware of what is going on in their country
    glues used Titebond original and C/A
    Occre walnut and oak dyes
    paint 1 bottle came with the kit, a acrylic metallic colour for the shields
    figures from Aliexpress
    i have the Captain John Smith's Shallop ordered at the same time from @chris watton Vanguard Models
     1:32 Captain John Smith's Shallop - Ships of Pavel Nikitin - REVIEWS: Model kits - Model Ship World™
    but have also recently ordered the  San Bartolome
    1:48 San Bartolome by Pavel Nikitin - REVIEWS: Model kits - Model Ship World™
    IMG_4460.thumb.JPG.14ff22230d084e48dcf68d30800e81c4.JPGIMG_4461.thumb.JPG.5224ff99b632bc33622c9816d57ae499.JPGIMG_4464.thumb.JPG.4670fdb20dc6da0e1ad7de0395bb19c6.JPGIMG_4467.thumb.JPG.87a4213b91a460d74ce43818391c4f31.JPG
  9. good morning everyone
    took a while to get the sail to look more realistic, but i think this looks better, most of the fittings are now in place, except the shields and mast stands along with the bow and stern scrolls
    still have to trim some excess thread from the sail, and cut the bolt rope ends.
    5 seconds after the last photo the breeze caught her and she landed on the puppy, puppy is ok though, and build was repaired
  10. good evening everyone
    thank you for comments and likes
    i seam to have missed a post, so lets play catch up
    seat lockers day 29-2
    nice and simple with just 28 to make up, stain and varnish
    oar storage brackets stained and fitted
    name plate two tone stained and varnished
    day 29-2
    barrels made up along with cradles and the rudder
    IMG_4216.thumb.JPG.c5987920455b722692a8cd661081833c.JPGIMG_4217.thumb.JPG.3bb621033a0ae04ca83f9b8f9e65081b.JPG
    image.thumb.jpeg.dd2e7e248ebcca9a306c9b69fe517510.jpegimage.thumb.jpeg.177aaea0b7a90409f3e98dcbe4d23129.jpeg
    oars required a lot of clean up due to laser char, then stained
    image.thumb.jpeg.65391cebe960fa89ad3832af1516961f.jpegimage.thumb.jpeg.75ab0a4f19e3012d5f690587cb35280d.jpeg
    1st August 2025 day 34-2
    stand cleaned up, stained and varnished image.thumb.jpeg.f6dc4ff02c9f544f93973a2c493f90d6.jpegimage.thumb.jpeg.646875b3b54eaaec017cc57a952262f3.jpeg
    outside contractors employed (Ruth)(wifeypoos) for sail building
    3rd August day 36-3 started rigging
    i fed a bolt rope around three sides, and room for a wire if im unable to get the sail to sit right
    not many rigging lines to fit, but getting the sail to sit right took longer than most other things
    today was spent tidying her up. and adding a few bits like the rudder, oars, seats, rope coils
    more to add tomorrow, before the big reveal, and move on to the next project
  11. 4 hours ago, md1400cs said:
    Kevin,
    Great work !!! - I saw your image on "at a glance" -- Did you add the oar hole covers, or did those also come with the kit? Nice detail.....
    I'm waiting for the 1/35th to be available in the US - shipping directly from the Ukraine is very "OUCH".
    Again great work - looks awesome indeed.
    Need to get back into this hobby - been MIA for too long......
    Cheers,
    The shaped inserts come with the kit, the handles per the instructions are shaped dowel, but i used some out of scale belaying pins
