Posts posted by Tadeusz43
The capstan & windlass
Wissemara
Kamper Kogge
Roland von Bremen
Vasa
Amsterdam
Batavia
Gotheborg
Bounty ( base of capstan looks like it was out of period)
Victory
Warrior
Jylland
Kruzenstern
Passat The windlas was powered from capstan situated above on forecastle deck.
Passat The capstan and bulwark winch
Dear colleagues,
Thank you for your kind words about my work, but my stock images on ships and their construction is limited and not very long runs out.I had a dream…
Because I see that collect photographic information on this subject can be interesting and useful to propose joint creationShippediA The Free Encyclopedia period ships and their construction
Many of us live near where the maritime museums and museum ships, and can take pictures of interesting passages in their construction and equipment, maybe they want to share them with our community.
What do you think about this proposal.
Tadeusz
Pumps
Pumps are very important ship equipment and was used for emergency ship dewatering as also for deck washing and fresh water pumping in to the galley.
Emergency pumps was located on the deck above waterline with suction from ship bottom near keelson and discharge to the pumpdale scuppers or directly to the deck.
Elm tree pump is oldest type of ship pumps.
Vasa - reconstruction
Batavia
Asterdam
Victory
Chain pump has bigger capacity and was introduced in British Navy in beginning of 18th century. Not was used in the Continental fleets.
Chain pump accompanied by elm tree pump
Chain pump handles and chain wheel on pump head
Chain pumps discharge to the gundeck
Pump suction tubes in the well near the main mast feet.
Victory
Crosshead pump introduced in 19th century.
Jylland
Flywheel pump introduced in 19th century.
Rotary action of flywheel was changed into oscillating movement with crankshaft
Jylland
Marine Museum in Stockholm
Cutty Sark
- Canute, avsjerome2003, JesseLee and 2 others
5
Cannon tackles
Guns placed on guns carriages were equipped with tacks enabling them to
go back for loading - train tackles, and return to the position for a shot –gun tackles.
The breeching it was thin rope seized to the cascabel or to the gun carriage.
Purpose of the breeching was to absorb the recoil of the gun when it was fired.
Pivot guns was equipped with tackles for change it position.
Vasa Museum Stockholm
Marine Musem in Kalskrona (Sweden)
Jylland
Marine Museum in Gdańsk (Poland)
Gotheborg
Victory
Batavia
Warrior
- Bobstrake, mtaylor, avsjerome2003 and 4 others
7
Rope belaying
Small size ropes are belayed with belaying pins, which are plugged into pin rails.
Pin rails can be situated on bulwarks on the ship side or made as the fife rails
around mast.
Belaying pins are made of wood or metal.
On the ship is used one only diameter of pins with diameter is of thickest rope used in rigging.
Excess of belayed rope is coiled and hanged on the pin.
Ropes with bigger diameter are belayed on cleats, kevels, bollards or riding bitts
Wissemara.
Gotheborg. The ship is fully rigged and seaworthy.
Jylland. The ship is not seaworthy and running rigging is significantly reduced
Jylland. Basket for rope excess.
Kruzenstern. The ship is fully rigged and seaworthy.
Passat. The ship is not seaworthy and running rigging is significantly reduced
Victory. The ship is not seaworthy and running rigging is significantly reduced
Warrior. The ship is not seaworthy and running rigging is significantly reduced.
Bounty
Kevels ( staghorns )
Amsterdam
Vasa
Batavia
Warrior
Victory
Cleats
Gotheborg.
Gotheborg. Shroud cleats.
Ridding bitts
Batavia Ridding bitts on lower deck for mooring lines and anchor cable.
Victory. Ridding bitts for anchor cable.
Tadeusz
- mtaylor, Seventynet, dgbot and 1 other
4
Here's an image of a gun port and cover from the full size Vasa, showing the ropes that were used to open and close the gun port cover. There's a small ring attached to each side of the gun port cover, with a separate rope tied to each ring. The upper rope is under tension because it is holding the gun port cover open. The lower rope is used to pull the cover into its fully closed position, and then tie it off under tension so the cover remains closed in bad weather. I am thinking of using some thin copper wire to make the rings ... will the work on modifying the "Billing" gun ports ever finish?
Can anyone tell me what the "step" with a hole in the middle is, the piece highlighted in red?
Hi Rob,
In my opinion this is scupper from middle deck on which they are installed pumps.
Tadeusz
The drainage channel
Elm tree pump on middle deck stern pardt.
Running rigging
Wire ropes in running rigging.
Wire ropesi in running rigging was used on beginning of 20th century.
In such period was constructed the last cargo sailing ships famous Windjammers.
Wire ropes was used as halyards, yard lifts and brass.
For their winding serve special winches with hand power or even steam power.
Wire ropes was also used for “standing" parts of running rigging e.g. pendants.
Useful information for modelers:
http://pages.swcp.com/usvmyg/squarerig/sq2.htm
Kruzenstern Passat
Kruzenstern
Passat
Running rigging
Hemp rope rigging
Gotheborg.Fully rigged and seaworthy
Gotheborg. Partly furled sails and most important lines.
Shtandard. Fore top sail.
Top and royal yards rigging
Gotheborg.Mizzen lateen sail rigging.
Sthandard. Mizzen lateen sail rigging.
La Glorie. Mizzen gaf sail rigging
Bonty. Mizzen gaf sail boom with sheets.
Sthandard. Mizzen lateen sail yard with rigging
Batavia. Parral.
Batavia. Main sail yard hlyard with ramshead block
Gotheborg. Crowsfeet wit euphore.
La Grace.
- Canute, avsjerome2003, JesseLee and 8 others
11
Tadeusz:
What do you use to prtect your lathe from rust, and do you lubricate the sliding surfaces, if so with what?
I use WD40 and I wipe excess with a paper towel.For gear I use lubricant.
Tadeusz
- Canute, thibaultron, mtaylor and 1 other
4
Hi,
I hawe such machine :
No plstic gears. Only chuck is not easy in use.
http://www.uni-max.com.pl/kombinowana-tokarka-z-frezarka-at125-mini/d/
Tadeusz
- tasmanian, cristikc, CaptainSteve and 1 other
4
Stays
Wire ropes.
HMS Warrir 1860. Wire ropes rigging. Early period of wire rope rigging.
Kruzenstern.One of last existing windjammers
HMS Warrior. Main stay lanyard. Two stays was fitted port and sterboard.
HMS Warrior. Fore stay and fore stay preventer lanyards.
HMS Warrior. Mizzen stay and preventer stay.
Passat. Mizzen stay and mizzen topmast stay.Stays was made as double .
Passat .Main mast stay and main mast topmast stay.
Kruzenstern. Mizzen stay and mizzen topmast stay
Kruzenstern. Main mast stay and main topmast stay. Passat. Fore mast stays anchored at bowsprit.
HMS Warrior. Martingle stay and bowsprit rigging.
Dar Pomorza (1909). Bowsprit rigging. Chains in use.
Kruzenstern. Bowsprit rigged with iron bars.
- mtaylor, avsjerome2003, JesseLee and 7 others
10
Hi Rick,
The shrouds was installed as pair of ropes.
Number of pairs of the shrouds depend of period and vessel size as also of vessel origin.
The number of pairs of the shrouds increased over the years from one to three pairs in the 14th century to 12 and more in the 15th and 16th centuries. On some ships were installed even 18-20 pair of the shrouds.
At the beginning of the 17th century number of pairs want began to be reduced and for the largest ships amounted to 9-11 on main mast, 8-18 on foremast and 2-4 on mizzen.
See: "Historic Ship Models" by Wolfram zu Mondfeld
Tadeusz
Stays
Hemp ropes.
In period of use hemp ropes main stay was the thickest rope in ship standing rigging. Formula gave by Wolfram zu Mondfeld in “ Historic Ship Models” says:
For modelers purpose diameter of main stay is determined as 0,166 of
the diameter of the main mast at the deck.
Diameters of other ropes in standing and running rigging are proportionately smaller.
Batavia. Main stay lanyard and collar.
Batavia. Main stay collar.
Batavia. Fore stay lanyard.
Gotheborg. Main stay and preventer stay lanyards
Gotheborg. Mizen stay and preventer stay lanyards.
Gotheborg. Fore stay and preventer stay lanyards
Gotheborg. Fore stay and preventer stay lanyards. Gotheborg.Bobstays and bowsprit shrouds
Gotheborg. Main stay, preventer stay and crowsfeet at mast top
Victory. Main stay and preventer stay lanyards. Stays snaked.
Victory. Stay and prevetner stay at topmast.
Victory. Fore stay and prevetner stay lanyards. Stays snaked.
Victory. Bobstays and bowsprit shrouds.
- janos, avsjerome2003, Archi and 4 others
7
Hi,
I use different ways for simulate caulking on the deck it depend of model scale.
Scale 1:100 or more I simple draw caulking lines with black fine liner.S/S Savannach under construction.
Scale 1:75 and around I am coloring the edges of veneer strips for deck planking with black permanent marker.
Friesland under construction.
Scale 1:48 and less I made caulking as black thread glued between deck planks.Golden Yacht.
Tadeusz
- CaptainSteve, Canute and mtaylor
3
Shrouds
Lisa von Lubeck. Sheer poles on lower part of main mast shrouds
Nef Victoria. Fore mast shrouds anchored to the deck.
Amsterdam. Shroud seizing and lanyards.
Amsterdam. Lower shrouds on main mast head and catharpins with futtock stave.
Amsterdam. Main mast head and futtock shrouds and topmast shrous.
Gotheborg. Main mast head and topmast shrous.
Batavia. Spirit topmast shrouds
Sheer pole and rat lines.
Victory. Shroud seizing and lanyards.
Victory. Lower shrouds at topmast and catharpins.
Bounty. Main mast with lower, topmast and topgalant shrouds.
Passat. Wire rope shrouds of fore mast anchored to the bulwark with rigging screws.
Passat. Wire rope shrouds of main mast anchored to the deck with rigging screws.
Rigging
Standing rigging Part 1
Channels and chain plates
Channels was installed on ships from the end of 15th century up to half of the 19th century.
It was the place of securing the lower ends of the shrouds and sometimes the backstays.
The lower deadeyes were attached to the hull by iron chains or rods called chain plate.
Neff Victoria
Vasa Halve Maen
Amsterdam
Batavia
Bounty
Gotheborg
Etile du Roy ( ex Grand Turk)
Shtandadrt
Victory
Jylland
Warrior 1860
Tadeusz
- Bobstrake, Archi, avsjerome2003 and 7 others
10
Yars Part 2
Main course yard parral Batavia
Main course yard parral Amsterdam
Yard with halyard and sling Victory
Topsail yard with halyard and parral Victory
Crossjack and gaff jaws on mizzen mast Victory
Main mast yards Jylland
Yard with iron rod jackstay and studding sails boom Jylland
Iron mast & yards Passat
Iron yards and truss Passat
Spanker boom Passat
Spanker gaff and topsail gaff Passat
Iron yards Kruzenstern
- zoly99sask, davyboy, janos and 5 others
8
Yards Part 1
Bounty wtih furled sails
Main topgallant yard Bounty
Driver boom jaws Bounty
Main topsail and main yards Bounty
Mizen yard, crossjack, boom and gaff Bounty
Yards in Batavia Werf workshop
Yards in Historic Dockyards workshop in Portsmouth(UK)
Spirit sails yards Batavia
Yard with hemp rope jackstay Batavia
Spirit sails yards Gotheborg
Bonaventure mizzen yard, parral and halyars Gotheborg
Golden Hind 1580 by rschissler - Mamoli - Galleon
Hi,
Replica of Golden Hind in London
Tadeusz
