Posts posted by Tadeusz43
Hi,
The Cornwall Model Boats offers big choice of ship model accessories in resonable prices.
http://www.cornwallmodelboats.co.uk/
Tadeusz
- Canute, thibaultron, mischief and 1 other
- 4
Hi,
Corner show case
As the number of my models continues to grow, it was necessary to find a place in my living room on their exposure.
So the idea for a corner display case is a good solution.
It will be a safe haven for the model Peter von Danzig, the ship of the fifteenth century, which was related with the city in which I live.
She was a privateer of Hansa League during the war against Britain and France.
She’s biggest conquest in 1473 it was cargo of the Burgundian galley "San Matteo” in it was triptych of the Last Judgment painted by Hans Memling.
Material for display case
Profiled slats of pine
HDF boards white
Furniture corner joints + screws
Plexi (for reason of required bending it was ordered in specialized company)
Two lamps + cable + power supply unit + switch
Time for job - two dysTadeusz
- mtaylor and usedtosail
- 2
Hi,
I made display cases for my models.
Our models built at the expense of many hours of work should last many years and enjoy the perfect eye look.
To protect them from dust, which is the main enemy of these delicate structures and especially the rigging, place them in showcases.
Such cabinets can do with your own hands.
Several ways to implement them.
- The frame structure of aluminum profiles joined with aluminum blind rivets.
- The frame structure of wooden profiles glued and fastened with nails and screws.
- The frame structure of PCV angles with use of double face self-adhesive tape for joint it with plexi plates.
The basis for showcases can be made from MDF board, plywood or wood boards.
The cover can be made as the transparent plexi or the same material as the base.
Lamps for lighting model can be installed in showcase cover.
PVC angles
Wooden profiles
Metal fittings and legs
Aluminium, PVC and wood strips
Woodenstructure of display case
Aluminium structure of display case
PVC structure of display case
Tadeusz
- dvm27, Mirabell61, tadheus and 7 others
- 10
- mtaylor, cog, Landlubber Mike and 11 others
- 14
- captainbob, why me, IgorSky and 7 others
- 10
Hi,
Ship boats I made as epoxy and glass fiber laminate using fine glass fabric ( 25 g/sq. m and 150 g/sq. m.) .
Laminated structure was made on wooden core covered with layer of paraffin.
It was 4-5 layer of glass fabric with fine on the top.
After full cure of epoxy light sanding was applied for better paint adhesion.
Final painting with acrylic paint.Tadeusz
- tadheus, captainbob, juzek and 6 others
- 9
- juzek, mmdd, Erebus and Terror and 3 others
- 6
- Mirabell61, mtaylor and Jorge Diaz O
- 3
Hi,
After a long break, I go back to modeling.
Meantime, my workshop was twice flooded with water from a broken pipe
fortunately there was no damage tools, machines and models.
I am working on equipment today installed a fife rail, pin rails along the bulwark,
windlass, pump and winch as also deckhouses, skylights and companionway.Tadeusz
- jbshan, Jack12477, piratepete007 and 6 others
- 9
- mtaylor, JesseLee, aviaamator and 1 other
- 4
- JesseLee, MarisStella.hr, mtaylor and 3 others
- 6
Hi,
Karlskrona, southern Sweden was established as a base for the Swedish fleet
in 1680 because in this area the sea does not freeze in winter.
Many buildings have survived to our times but the area is still used by the Swedish Navy.Artilery Manor - artilery arsenal
Curent view - the long building it is old rope walk
- mtaylor, Captain Poison, Mike Y and 4 others
- 7
Hi,
Figurehead on my HMS Warrior comes with this set of figures Celtiberians warriors.
Producer is HaT http://www.hat.com/
Tadeusz
- mtaylor, Captain Poison and aviaamator
- 3
Hi,
Because the sculpting is not my strong point problem of figurheads for my models I solve using commercial figurines with possible “face lifting”.
It may be figures of knights and ancient warriors.
I do not know what is figurehead on HMS Surprisie, the problem is if this is figure of a woman, no many this type figures are available on market.HMS Warrir - it was Roman warrior from commercial kit
Golde Yacht - it was knight on horseback
Tadeusz
- mtaylor and BLACK VIKING
- 2
Hi,
Chemical blackening is the best solution.
Tadeusz
- aviaamator, Canute and mtaylor
- 3
Art of period shipbuilding
in Nautical/Naval History
Hallyard winches on windjamers, Passat and Krusenstern
Tadeusz
