Posts posted by kpnuts
Yes I figured there would be a reason for such loose fitting parts.
- mtaylor, Canute, popeye the sailor and 3 others
6
Hi all next update the crank shaft is poorly represented
So I filled the gaps (I hope it still works it's so heavy now
I realise it a plastic kit but look at the huge tolerances,
I may have to add some piston rings.
This is how they would have you put the pistons together
It would be impossible to remove the seam line like that, so I decided to drill the hole for the gudgeon pin out of one side.
- Canute, Egilman, Old Collingwood and 5 others
8
Hi all I got this today its actually a Franzis kit released under licence at a 3/4 the price of a Franzis kit, yes the instructions are not as glossy and there are no beautiful pics of the engine, and yes the box is not all luxury and flashy but the rest of the kit is exactly what you get from Franzis.
First thing I will have to deal with are those god awful carburettors.
I intend to show exactly how I do each bit of this, painting and such.
I have masked the engine in half (as I intend to do it half see through and half not) we have a machine at work which will add a cast effect to the half that is not going to be see through. The metalizing technique I use need the parts to have a metallic appearance so to get that on the top of the pistons I use my mini lathe and just hold a file over the part whilst it's on (you could do the same with a dremel)
Hi thanks Yves I do like a big kit.
Dan I use cheap paint from cheapo shops like b and m or q d I decant it into my airbrush and spray from there ( I sometime use a shading colour underneath to enhance the shape or add age)
This won model of the month on de agostini when I posted it there.
- mtaylor, Old Collingwood, Canute and 3 others
6
- GrandpaPhil, Jack12477, Paul Le Wol and 14 others
11
6
- Canute, Landlubber Mike, Old Collingwood and 7 others
7
1
2
Hi Bill I forgot about this build (its probably in a bin somewhere)
I used clear bathroom sealant for the sea, its actually a very accurate kit for its time (ok they got the colours completely wrong) that said i really like the blue and gold colour scheme.
There are a couple of things wrong with the kit (its missing a couple of cannon placements and if I remember correctly some of the transom detail is wrong. As a kit it goes together quite well the detail is not that clear on the moldings but for kit of its age and price at the time I think airfix did a Stirling job.
- mtaylor, Canute, Landlubber Mike and 6 others
9
- Canute, popeye the sailor, Egilman and 5 others
8
Porsche flat 6 boxer engine by kpnuts 1/4 machine works
in Non-ship/categorised builds
OK so this is how the carbs should look
Here's my start, yes it needs loads more detail
