Everything posted by alde
Requesting feedback for future MSW Group Projects
alde replied to Chuck's topic in Group Projects on Model Ship World
Chuck, A San Francisco Bay Felluca is a pretty little work boat that might make a good subject. Some of them were painted with bright colors and have a simple rig. Maybe a War or 1812 era gunboat would be a good subject too. -
Thank you. I think the 1/48 will be good sellers. I know I will buy at least 2 when they are available. I need one for my Halifax build and one for future use.
- 216 replies
- masterkorabel
- ships
(and 3 more)
Kurt, is it possible to post the correction sheet on the NRG website with the instructions for those of us who already have a set of plans?
- 504 replies
- washington
- galley
Thanks Mark. I was leaning that way but it sure helps to hear from someone with more experience. The half frames that I have installed seem pretty solid without pinning them but I think I'll go ahead and do the half frames like Hahn shows. I did drill and pin all the full frames to the keel and it's nice and solid now. It's fairing up pretty well too. It's starting to look like a hull. I hope to have the rest of the half frames in by maybe the end of next week.
I have a question for those with more experience with this type of build. I'm doing the half frames now and have 3 in place now. In Hahn's book he shows these frames being trunneled in place for added strength. I plan to do this but was wondering if I should drill all the way through both frames and pin them together or just drill into the deadwood? To me it makes sense to go all the way through. I was just re-reading some of the book and see that when he installed the keel he uses epoxy. I used yellow titebond for mine. When I was doing some preliminary fairing a couple of the frames popped loose. I wish I had paid more attention when I did this. I may drill and pin each one through the inside of the hull into the keel for extra strength.
Lawrence, I am having a great time with this build. It's really rewarding to see it come together and I'm learning a lot from it. I'm looking forward to your Oliver Cromwell coming together. Your making great progress. I really like the Hahn method and plan to do at least a couple more like this. The Cromwell is going to build into a beautiful ship and I may build it one day. I think maybe the Hannah may be next though. From there I don't know. I have a pretty good stash of kits I may end up finding new homes for so I can focus on scratch building but who knows.
Looking forward to it James. Thank you.
Looking really nice Mick. I really like the look of the treenails on the deck. The color and size look just right. They don't stand out too much and look like freckles. They are subtle. Very nice indeed.
- 504 replies
- washington
- galley
Thanks Mark. By adjustment I guess you guys are talking about depth? I figured I would have to do that. I have a set of small, curved rifler files that should work great for that. I glued the keel to the whole frames today but haven't touched it since. I'll start on the rest of the frames Monday. I'm looking forward to that.
Tick strip
alde replied to Kurt Johnson's topic in Building, Framing, Planking and plating a ships hull and deck
I would think the bottom of the rabbit would most accurate. If you go from the surface of the keel you'll come up a bit short. -
I know it's not much of an update on the build but it felt like a real milestone for me. I was really stressing about cutting the rabbit but I think it went pretty well. Using the framing plan as a guild I drew in the rabbit with a straight edge and ships curve. Once I was happy with the way it looked and adjusting it here and there I clamped the steel staight edge to the straight part of the keel and started making light cuts with a No.11 blade on an angle. I did all 4 straight lines then started carving out the V-groove. Then for the stem I did basically the same thing only free hand this time to make the curve. After most of the wood was removed I used the corner of my steel straight edge to scrape out the groove to clean it up. Both side look pretty decent if I must say so myself. Now that that is done I will make sure everything fits well and looks good then glue the keel assembly to the frames. Cutting the rabbit was about all I could do today.
Glad to hear your easing yourself back into it. I bet it gets easier when you start to make some real progress. As far as planking goes I don't have a lot of experience either but I've found that the most important thing to do is not glue anything until your absolutely happy with the fit. I have taken a good part of a day fitting a plank until I was happy with the way it fit without any stress on it. Then clamping is really easy because your just holding it in place and not trying to bend it into place. It can be frustrating at first but gets easier once you learn how the wood reacts.
Mike, Welcome to the forum. It is a great bunch of folks. You will end up making some good friends even if you never meet face to face. I know I have. A build log is the best way to learn. You'll get great advice and learn the terminology as you go. Once you have the kit in hand and you study the plans many of your questions will be answered. You might consider a first ship being something there are several build logs for. The Model Shipways Armed Virginia Sloop is very popular with a bunch of great build logs that will guide you through your build along with asking questions in your own log. I'm sure the Friendship Sloop would be a good choice too. They are great looking vessels for sure. Just have fun and ask for help when needed.
