Hi Pete. There were several different heights and a lot of blade adjustments!
Also a little fine tuning was done with a file.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
More nice "set up" Rusty. By the time you get to actually start this project, you'll be so well "set up", that the build will seem to take no time at all! ;)
Rusty - grant is right that if this setup work continues at this pace there won't be much actual work to be done.
Nice work on the keel with the saw, I just ordered some Byrnes toys, can't wait until they arrive and I get to play with them on my Echo.
Ben
So what did you end up ordering Ben? As I recall you had a bonus cheque to spend (with the Admiral's blessing).
Yes do tell!
Rusty
Ok seeing that the pieces for the keel had all been cut to size I figured it wouldn't to start assembling it.
Here is the hog, keel, false keel (upper) and false keel (lower).
Hog and keel clamped together and drying,
False keel drying too.
Rusty
Hi Ben,
That’s great you’ll love it! The wood is swiss pear and the false keel
is ebony. I have a little left and figured it was a good place to use it.
After gluing the two sections together I cut out the pattern that shows the
rabbet location, transferred it to the keel and then cut it out using a V grove chisel.
Rusty
wow at last - i have found my first scratch build -
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
     Yes this would me a nice first scratch for you.
Rusty,
   Glad to see you back again. Keep the pictures coming, I also like this build.
Wacko
Joe :D
Go MSW :) :)
Thanks Grant and Ben.
Joe, I'm here, there and everywhere. I flit from place to place. Probably because it harder to
hit a moving target. Work has slowed here with the limited summertime availability of shop time.
Kevin, you’ll love it and it is huge! After getting the plans I went and had 3 copies of the frames
made and one extra copy of everything else and kept the masters to double check everything.
Did I mention it’s huge? Now get back to work on the Victory so you can join me! :)
Rusty
Hi Rusty,
Nice to know you are getting at least sometime in the workshop, I just finished painting the Confed cannons last night! 20 coats and I'm finally happy with them. I'm going to try blacking the Echo cannons but really want to think about the best product to use, sooooo many conflicting points of view on MSW to consider.
Hope to see some updates on the Bomb soon.
Ben
Hi Ben, 20 coats is impressive. Ten is about my max. As you've said there are
so many ways to do cannon barrels but I find I like painting them the best.
Can't wait to see them mounted. :)
Rusty
Hi David and E&T, Thanks for looking in. Sorry for the delay but I missed your posts.
Well I’ve finished the Triton cross section and she’s safely tucked away in her case.
Now it’s time to get back to the “set up”. Now where was I had left off? Oh yes I had
completed the keel and now it is time to cut out the pieces for the frames. There are a
total 17 frames 5 of which are doubles so that’s 22 frames to make. I will take and cut
up the frame plans and use temporary paper glue to adhere them to the cherry billets.
Then I will use the scroll saw to cut them out, over lay them on the plans and then glue
them up using wood glue. It doesn't show but remember the wood for the frames is
1/2" (12.7mm) thick.
And here is a single and double frame all glue together and the chocks added.
Two down and a whole bunch more to go.
Rusty
Thank you Pete, Bob and E&T for your interest! :)
Rusty
Thanks Grant.
Rusty
Hi Rusty,
It's time I join the cheering section and follow your 1/24 scale build. I happen to have the Bomb Section plans in my inventory but every time I look at the size on that beauty in 1/24 I shy away. Maybe watching you put your skills to work and learning will encourage me to change my mind. Need to start thinking about a future project after the Triton Cross Section. :)
The jig and your startup frames are looking good.
Edited by Paddy
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Thanks Paddy,
You know you can always have the plans reduced to the Triton scale. It would
save a lot on the wood costs and completed size. If I had to purchase the wood
in 1/2" billets I don't think I would have done it at this scale either. :huh:
Rusty
Working on the frames here and there is an interesting way they designed the sweep and gun port openings. As you can see from the plans they are all cut out prior to installing the frames. I used the
Byrnes table saw and disk sander to make the cuts.
The nice thing is that if they are off a bit I can adjust them as the upper hull
is planked inside and out. :)
Rusty
Moving on making frames here and I forgot to mention that when I added
the chocks to the frames I left them a little proud. After that I used a spindle
sander to clean them up.
Here I’ve placed the bracing around the keel on the building board to hold it
in place while I test fit the first of the frames.
Here are the first two frames set temporarily on the keel in the jig.
Rusty
Hi Ben,
Thanks and it's great to hear you are back from your vacation. :)
Rusty
