Today, (with the bad weather we currently have ) I concentrated on getting the Cockpit put together. I started by cutting strips for the Cockpit Floor. I then cut them to length and sanded them to 400 grit ( I will put a coat of varnish on them ) I then made the bulkhead sides that make up the face of the Cuddy cabin. I sanded them to 400 grit and stained them Cherry red along with the seat bases and aft cockpit bulkhead. ( wich has a piece of Birch ply on it ) Once the parts were made up I started by gluing the Cabin bulkheads in followed by the Cockpit Floor. I cut out the cockpit seats ( they have not been glued in at this point) Next will be to make up the seat backs and Cockpit coamings . Here are the results
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Nice looking cockpit, now she's beginning to shine.
Bob
Current build:  SS_ Mariefred
Thank you John, I am happy with how the stain turned out
Thanks Patrick, She's going together rather smoothly, this has been one of those builds that just fall into place
Thanks Cap'n'Bob, she's getting there , I am pleased with how the Cockpit is turning out
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Beautiful work Pete,
you have already so much practise in building These small boats, I trust you could do the hull over the Weekend if necessary. To date you must have quite an extensive number of craft moored to you model Floating marina
Very well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils, I appreciate the vote of Confidence , I currently have 8 boats ( models ) I have been selling them on Ebay, so that I can build more, there are quite a few Boats that I would like to build .
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
A busy day today, I started by making the seat backs ,and installed them. I then cut out the Cockpit coamings and put them in rubbing alcohol. I then painted the Deck a sand color, next  (after roughly 3 hours ) I bent the Coamings . I then sanded them to 600 grit and installed them. I then made the Cabin top sanded and installed it. I then made the aft cockpit coaming sanded and installed. I finished up by staining the coamings and seat backs a cherry red.  The seats have not been glued in yet ( I have not decided weather to paint them white or stain them ) Next will be to get the Hull painted ( white with blue antifouling paint ) Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Pete, the cockpit and combing really look fantastic! Was the 3 hours for the combing so that it could dry or did you need to just bend a bit at a time? I think shaping those combings are tricky as can be and yours looks great!
Cheers,
Jay
Current Build:  Ariel
Thanks Jay, I generally like to let the wood soak 3 hours and then I start bending ( Bent Coamings can be tricky so the longer I let them soak the easier they bend )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Jay, I found that the longer that I let the pieces soak ( wood that needs to be bent) The easier it is to bend
Thanks Patrick, I am pleased with how she is turning out
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I was able to complete the Hull Painting , It took 2 coats of flat white, with a base coat.( 3 total )  I will need to touch up the Bottom ( Anti-fouling) Paint. I just unmasked her and here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you John, I was hoping to capture that elegance/grace that makes these boats so beautiful
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Ben, there is plenty of this build left, so go ahead and pull up a chair
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Best Regards,
Pete
Pete,
I daresay that you have captured that elegance perfectly.
Thank you Mark, I greatly appreciate it , she has been a pleasure to build thus far
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
First off, I would like to thank Michael Mott, for the Teak that he had sent me, I started by using the teak for making the Cockpit seats ( you can't beat Teak ) I then turned my attention to the Toe rails and rub rails. once installed I stained them a cherry red along with the Cabin top . Next will be to start making the Spars and fittings , Almost on the Downwind leg on this build. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The teak does look good in there, Pete.  Just works very well with the color choices.
What a lovely lady Pete!  Build be a 1:1 so Gwen and I can go sailing on the St. Johns river.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
I would like to thank everyone for all the likes ,
Thank you Mark, The Teak was something that I have wanted to add to my builds , and it set her off rather nicely
Thank you Piet, A 1:1 build would be nice , I have not done a 1:1 build in quite some time , hopefully in the future I will be able to do one
Thanks Patrick,, The teak definitely made the Cockpit pop , Herreshoff designs ( I am not telling you anything new) just have that beauty thats all their own  , I still have to tune up the bottom paint.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
A small update, the paint shop was pretty busy today, I went ahead and sanded and re painted the Bottom ( anti- fouling ) Paint. the next step will be to start the spar making . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I thought about doing something different, so I decided that I would finish making frames for a Buzzards Bay 14, that I started working on a few weeks ago , I am building this one as if it were a 1:1 build but to 3/4" = 1' - 0" scale. I will be building one in similar fashion in a 1 1/2" = 1' - 0" scale soon and there will be a build log. in the meantime, here is what she looks like with the frames glued into the Keel
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Ok, were rounding the top mark and ready to make the downwind leg to the committee Boat. I started by making the Mast , first cutting the then tapering the Mast. Next I made the spreaders and drilled all the holes in the mast ( to accept the Halyards, Blocks and stays ) I then made the Boom and drilled the holes for the blocks and out haul. I then laid out and drilled the holes for the stays on the deck. And lastly made the tiller ( not glued in yet ) next will be to make the Blocks and Cleats along with the Sails. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
The combo color difference between the hull and the cockpit leaves a distinct impression of style.  Doing that kind of prework on the mast is time consuming but best done early.  From the beginning you have shown that you have thought this build though did you make an instruction book on building it?
David B
