Officially got the Morgan under way a few days ago. I really should be working on a case for my Bomb Vessel Granado, but I was tempted...
I hope everyone enjoys the ride here. I'm really looking forward to this build as something a bit different, since my last four builds were all warships.
I won't get into much about the kit itself, since it is fairly well known. I have yet to fully evaluate what I'm going to keep and what I'm going to discard with regard to the kit pieces, in particular some of the Britannia castings. The rope will definitely be replaced, and possibly the blocks and I will replace wood where needed to avoid things like splitting issues when drilling basswood. Most wood will be painted, which is quite a contrast from the Granado build.
The bulkheads have been cut out and cleaned up, which was a pain since they are plywood. A hobby knife struggles, but the laser cuts are too narrow to fit even tiny xacto saw blades.
Moving on, I've cut the rabbet/bearding line, using a compass to get the line, and a copied paper template from the plans for the bearding line. The basswood keel was much easier to work with than the ply bulkheads...
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Joe I look forward to seeing your progress with this build. If I remember correctly that the kit was originaly a solid hull.
Be well
Dan
Hey There Joe.. Thanks for the link (on your Granado Log) over to here.. Am looking forward to another one of your class builds..  So as Mike above says 'No Pressure'   ^_^  ^_^
All The Best
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Hi Joe,
wishing you a most enjoyable build with this famous "whaling mothership",
shall watch this interesting log....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Joe, just found your log. Glad to see you joining the "Morgan Club". I have a lot of photos as well as a build log here on MSW. should you need any reference photos please check my website as I have them posted there. I'll enjoy following your log --- it brings back memories of when I was at this stage. I'm almost finished with mine probably around 95%. It's a fun build.
John
http://www.charleswmorganmodel.com
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Hi Joe, just an FYI I was just visiting the Morgan yesterday and took over 400 more pictures. I'll be posting them on my website in the next few days as internet connections allow. they will be in the gallery section under the Morgan. I will possibly make another page for them. Check it out if you need anything or PM me and I'll provide you with pictures. Look forward to you getting back into building again.
John
John
  • 5 months later...
Well, I haven't posted anything in here for quite sometime.  I am waiting for some replacement parts from ME to fix a major screw-up with the Morgan. I am finally motivated to try to save it.  We shall see how that works out...
Meanwhile, I realized that I never posted any photos of the Granado in her case. The base is a piece of oak plywood. I routed a lip around the edge to accommodate the acrylic case, and finished the outer edge with oak molding from Lowe's. The acrylic portion was made by a plastics company in Philadelphia, and cost me about $220. They did a real nice job on it and I will use them again. I got a local trophy retailer to make the brass nameplate: a mere $5.00.
Overall I'm very pleased with how it came out.
Joe Volz
Current build:
Joe, it's all correctable....look forward to seeing your progress..
John
John
Thanks guys.
John: Yeah,  I know I can fix it, just wasn't motivated to do so for quite a long time. I have a plan, and at this point I just need my replacement parts from Expo to arrive.
Joe Volz
Current build:
As I patiently wait for my replacement parts from Expo I decided to work on some deck structures to at least get something done. I've built the deck house and vegetable bin (a fiddly little thing) and painted those up. I also built the workbench, but am not 100% happy with it and will likely do it over (top is unfinished at the moment).
I can say after working with mostly boxwood on the Granado build I'm not happy being back on basswood for this one. There are absolutely some areas where I will substitute boxwood for strength, likely pin rails, fife rail and channels to name a few. Probably the skylight as well in order to be able to drill all the holes for the rods an not split the wood.
John, your photos are coming in handy, thanks! I still need to stop by Mystic next time work takes me through the area.
Joe Volz
Current build:
Hi Joe, looking good.  Let me know if you need anything specific.  I agree on the hardwoods and would highly recommend them in the areas you mentioned.  Contact Jason at Crown Lumber and he'll get you what you need....you'll be a much happier camper!
John
John
Well after waiting over a month my parts arrived from Model Expo like this:
They were packed in an envelope with two thin pieces of card stock. How could anyone possibly think that would survive the USPS?
Back it goes on the shelf. I may have another project in the works anyway soon. Very disappointing...
Edited by Joe V.
Joe Volz
Current build:
Hi Joe, man that sucks. Sorry to see that - not much of an excuse is it? You could probably make those work, but it's your choice - don't let that discourage you since about 95% of this build is by scratch. You can probably glue the pieces together and really not know the difference. It get's real discouraging, and unfortunately reflects back on the company MS, not only time but frustration. Good luck with your choices on what to do next. Sorry again to see this...
John
John
Thanks guys. It's really splintered up badly, and being relatively delicate I don't think it will glue up very well.
I'm going to give myself a day or two to ponder my options.
Joe Volz
Current build:
Joe,  may I suggest that you send a PM to Marc Mosko (MMOSKO) here on MSW and tell him about the bad service - he had a lengthy discussion on his company here a while back and talked about his desire for customer satisfaction. Doesn't hurt to go to the top man. ;)
Jack
Current buildUS Constellation
