Hi Igor
Just wondered where you found a match that large. Had to be one of the biggest matches I've ever seen.
All jokes aside, keep up the great work. Love how she's coming along
Carl
Completed builds: AL Bluenose II 1:75  Gallery
                              Amati Hannah SIB 1:300  Gallery
Current Build: Bluenose II - SIB - unknown scale
Such fine work.  Yes, it's a pun.
Bob
Current build:  SS_ Mariefred
Small update indeed.... tiny little structure but big in detail.
Thank you Mark!
Here is next update - I am continuing to make the deck elements
Best Regards!
Igor.
Edited by IgorSky
beautiful work Igor,
but I ca`nt believe that this steam schooner will go through the bottle neck :o, unless you are able to perform a miracle :rolleyes:...
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Nils!
I hope that a miracle will not be necessary for this and will be quite enough use normal methods )))
Best REgards!
Igor.
P.S. In a pinch I can always use a hammer ))
11707734_511352055683583_300693623865743
Hi everyone!
Many thanks for your LIKEs!
So, I went on to build the deck houses.
Best Regards!
Igor.
Edited by IgorSky
Hi Igor
Nice work on the cabins.  I'm still mystified how you're going to get the main deck with all the tall deckhouses through the bottle's opening.  Are the cabin's going to be positioned individually after the hull's fully installed?
Cheers
patrick
Yes, Patrick, I'm going to set the main deck house separately after placing of the hull in the bottle.
I think we're always our own worst critics. However, I wish, truly wish I had all the skills I needed. For instance, me and metal work just don't seem to mix. But for you, it just seems like second nature! Me envious? Damn right! But, always willing to learn and improve!
Igor,
If I hadn't seen your fingers in the earlier pictures, I would have thought you brought out that giant match again. Great detail at such a small scale. Impressive work
Carl
I understand a giant match but where did you get the giant finger?  Or maybe you have us all fooled and you are a giant.   :P   :D
Great work.
Bob
Great work.
Bob
Hi Bob!
A bit of illusions, a bit of sleight of hands and ...voila ))
Thank you Bob!
Best Regards!
Igor.
