really nice fittings....details the yard very well  :)   chain instead of rope?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
By this period in time, most tops'l sheets were chain with a block and tackle out of rope. The wear around that block on the end of the yard and then the block in the middle of the yard underneath was quite severe. Theses ships rarely handed topsails as they were the last ones to be brought in so the sheets needed the best abrasion resistance they could get and chain was it.
when the yards are fixed to the mast,  will the studding boom be in their proper location?   they should jut forward from the yard with a slight tilt downward.  they look very nice......the fittings look great!
Edited by popeye the sailor
extra text
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
yes I think it's located right while the boom is downwards and a little ahead, chained from the sail downwards and a little back so they do not meet.
thans for looking in and komment  Denis  B)
Hi Jens -
Are you referring to the white iron rod?  If so, I think that it is the lower topsail-yard crane.  What's it for?  Not sure.  Unlike the mainsail yard, which has a chain to take most of the weight of the yard,  the topsail yard doesn't have this.  Perhaps the crane supports the weight of the topsail yard(?)  The lower end looks to sit on the lower mast cheeks.  Although I don't see how the yard would be allowed to swing (not tilt) round to the stays.
- Tim
Current Builds:  Cutty Sark
Finished Builds:  Yacht America
it does pivot though...Tim is correct in his assumption.   fore lower top sail and main lower top sail should have one.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
those look sooooo good :)  really nice work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 1 year later...
Hello everyone . I have spent many hours on this mast project.  and have now reached where I want to mount the yards and make the top mast ladders and so on ,but still only one at a time -the picture with all the masts is just to boast
847512782_cs.master(6).thumb.JPG.fb8060a554f23dc33aac9b150154780c.JPG342480385_cs.master(11).thumb.JPG.d4dfc4d5631d5df53c8ae0f76a2a6e42.JPG926688226_cs.master(4).thumb.JPG.481748c2c11a6d22630ca3c4381f34cc.JPG
I look forward to the great work being done now that the masters "get together"
Cheers All.
Jens .
Hello Jens. Really nice work on your masts and yards. I especially like all the fittings you made. Where did you learn to make such detailed fittings?
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
hello Jens.......so glad to see your progress....looks great!  yards and masts have come together nicely :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Peter
Hi Peter
Thanks for your nice words.
I took part in a 14 day jewelery course which was very instructive in terms of learning to sand cast and to solder etc. and the best part was that I was one man among 12 sweet ladies on that course
Hello everyone I have finished the lower fore topsail with its special bearing support device. I've made it movabel like on the real ship - unfortunately, one thing that won't be seen when it's all finish  one day, but I'm glad to know that it's working properly.  :)  333677800_mastarbejdc.s(4).thumb.JPG.1184e92f662e3006599ea2b1bf2296c0.JPG1470677153_mastarbejdc.s(5).thumb.JPG.55d73e53a81d823a734b6a037d0c3abc.JPG1846341888_mastarbejdc.s(8).thumb.JPG.2e4f4031e268b5b8444668348e857943.JPG939742040_mastarbejdc.s(14).thumb.JPG.a7ee50dc4183f780c16d963328a81c17.JPG
woooow
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
it is now almost 4 years since I put dead eyes on C.S. and much has happened and learned since then and now I have broken the code to make ok dead eyes and have therefore changed them all.
Before :
After
and thus the work continues indefinitely
Cheers All
Jens.
Hi a little updating. a lot of work goes into preparation to finally raise the masters but I thought myself I have come a long way with the form mast. - why a yard is placed is because it is a whole ring that connects it to the mast and therefore must be on before being closed over it1700250601_cs.formast(3).thumb.JPG.3e300d4564582542918c62eeca5a2b53.JPG1179876638_cs.formast(2).thumb.JPG.00ac5b1613e40f1fcc5d131fcab266ea.JPG393133427_cs.formast(11).thumb.JPG.893720a313a83f32a9a77b3c35fa1eba.JPG787969970_cs.formast(7).thumb.JPG.a7eb06ccfa2dd67e3451203ac799022c.JPG489268699_cs.formast(4).thumb.JPG.f61b181b20e85845642a19d6b601ce59.JPG1342115128_cs.formast(10).thumb.JPG.0a5e5a97533802710db6cb02b524e5c9.JPG
Well.
still a lot of work to do then back to the workbench
Cheers All.
Jens
