2 hours ago, paulsutcliffe said:
Getting chilly in the garage now
Must be if you've got to put a blankie over the Sirius :D............hows the new kitty doing?
Cool today Paul - stuck it out in the workshop to mid afternoon and then retired to the lounge for a warm - winter is a coming.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
1 minute ago, druxey said:
I hope the damage was minimal.
It will grow back.
STAY SAFE
current builds:
Managed a few more hours in the garage today before it got to cold, fore channel finished and moving onto the mizzen which was fitted some time ago but not given deadeyes etc
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
I took a few pictures of how I make the chains, First nice piece of oak with three pins for the different lengths required 20191021_150441.thumb.jpg.7ca10ccca41a22622bf2d6fc852ec522.jpginsert the wire into the hole and then wrap tightly around the pins
Squeezing the ends around the pins as I go with small pliers to get the required shape
Once enough turns are done I lift it off the pins and pull apart like a large spring
Then cut each piece away carefully checking I am cutting the correct side and end up with seven or eight same size pieces
I then flatten them in a vice and square up the cut ends ready for soldering
Previous builds-
Among others 😁
Wash in some vinegar and then blacken20191021_151947.thumb.jpg.0b4edc22f93cfb1b31ae2ef60acaa933.jpg
Finished pin to boat with nails
Previous builds-
Among others 😁
Paul, thank you for sharing, they look great. I'll be trying that out for the Tennessee.
A little more time in the garage today, onto the Gallery, last year I had a hell of a job with these in the port side, with help from Druxey and his comet book, i got there in the end
This one going much easier now I know how to do it!!! Made a template from a strip to ensure all the same size
Edited by paulsutcliffe
Previous builds-
Among others 😁
I then cut the template length down to the size of the window
Previous builds-
Among others 😁
And used that as the base for the window, frames 0.8mm thick with mitered joints in the corners
Previous builds-
Among others 😁
Did a little bit of redesigning on the makeshift lathe adding a piece of aluminium for the tail piece
Previous builds-
Among others 😁
Keith the new kitty is doing very well thanks, fitted in like he's been here years and growing like mad
Previous builds-
Among others 😁
Amelia is in love, I told her not to fall for that long hair and that British accented meow.
Nice improvised lathe Paul. Even has 2 speeds. Tool rest securing screw look a bit basic but if it works that's fine. Tailstock almost looks over engineered.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Better not show Amelia this then keith
Previous builds-
Among others 😁
@KeithAug thanks, I'll change the screw if it offends you 😁 the tool rest is bit thin so intend to do some work on it, not enough room for a butterfly though
Previous builds-
Among others 😁
I'm gonna have to burn the computer!
Small update as getting to cold in the garage now, 2° out there today
Started on the caprail
Previous builds-
Among others 😁
Also added First bottom moulding on the Gallery
Previous builds-
Among others 😁
Hi Paul - yes I agree B****y cold in the shed. I bet the cat had more sense.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
You're not wrong Keith, the cats had no interest in going out in that weather, I didn't stay out there long either
Previous builds-
Among others 😁
Superb workmanship.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thanks OC, the windows were just slid in for the photo and need some straightening up before the top moulding goes on, but certainly going a lot easier than the port side did, three or four times
Previous builds-
Among others 😁
Hey!   that cat sits cross legged  - cool.
OC.
Current builds
Completed works.
Ha yes he does all the time, he's taken to lying on the ironing board as well hanging over the edges!!!!!
Previous builds-
Among others 😁
Thanks Jan, unfortunately reports will get much slower now due to the weather
Regards
Paul
Previous builds-
Among others 😁
Managed to get a couple of hours in over the week, even though extremely cold, yesterday a bit milder
Added the top moulding and the pillars between the windows
Not looking quite as straight in the pictures as to my eyes
I broke the top window frame while putting in the pillars as can be seen above, bummer!!
Previous builds-
Among others 😁
Keith and Amelia, one for you @Keith Black
What a pair of beauties
Previous builds-
Among others 😁
