That's some marvelous crisp detail you got there. She starts to look like the real thing, not so much a model with that kind of detail
Cheers
Carl
If the blackening won't stick, you could use some gunmetal paint ... Nice smithying!
Edited by cog
Carl
That's one of those things you might forget in your enthousiasm ... Nice save though
Edited by cog
Carl
Brian- Thank you very much.
Cog- That's a good way to look at it. I'm looking forward to starting the cannons but I think it will wise to take care of the small details first as opposed to waiting until the end. Thank you.
Chris
The way I look at it, Chris, you should do what and while you can reach it easily. At a later stadium you often need to put far more energy, and creativity in the job at hand, to get it done, whilst it would be a jiffy when tackled at the right moment. That and the probable unnecessary damage you may cause ...
You can start on the canon, though, just don't mount it if you're not finished with some other jobs on the inside of the hull.
I am very much looking forward to your updates. A wonderful build!
Cheers
Carl
After some trial and error, the rudder is complete. Shaping and drilling little brass pieces on a large wood lathe is a little less then ideal but do able with some patients and extra material. I also purchased a few gadgets to help hold those small annoying little parts during soldering.
Chris
Well, the carriage is ready. Now all that's left is the gun, the mast, oars, and some other small war like utensils
That is a very beautiful boat, Chris
Carl
Cog, Thank you very much.
Regarding a mast and the oars, the plans don't show them. In fact, I have researched this boat in other build logs and don't recall seeing a mast either. Archjofo built an absolutely beautiful rendition of this boat. I will scroll through his build log and see.
Chris
Ancre publishes the rigging and sail plan for €18. It's written in French, but I don't think that's an issue with understanding the plans. You can find it at http://gerard.delacroix.pagesperso-orange.fr/Chaloupe_greement/plaquette.htm. The plans were being given away free with the Rochefort monograph for a while, but I think that has now stopped.
Tony
Tony
Hello,
The complement "Rigging and sails" is not published by Ancre but by its author to the address that you indicated.
Blockplane, good job.
GD
Edited by G. Delacroix
My apologies, Gérard! I had forgotten these were independently sold!
Tony
Work continues, slowly. As the end of the build draws near I decided to get the case out of the way. I originally planned on making the case out of Plexy Glass but decided glass was a better fit. It took a fair amount of trial and error to get to a point where I was comfortable. The process of wrapping the glass with copper tape, burnishing and applying the solder was tedious. Im happy with the end result and feel it adds a more classical feel to the model.
Chris
Chris,
Your canon turned out very spiffy. The sledge looks quite nice
Carl
    The main canon is in place and fully rigged. I also built the cradle that the boat will sit in. I initially did some reach to find an image of a period correct cradle, but in the end, I just designed my own.
     Yesterday, i turned the four small 1lb. canons.  They came out ok. Turning pieces that small on a full size lathe and getting all the canons to look identical is a challenge.
Practice makes perfect.
Chris
Chris
She's looking good, Chris.
Bob
Current build:  SS_ Mariefred
Thank you Carl,
  Still working on the small canons. I'm not 100% happy with how they compare to one another. I will probably end up making a few more.  I'm planning on adding oars and a few canon accessories. I will say that the finishing touches are hard when your mind starts wandering towards the next build.
:pirate41:Chris
Chris
Chris,
I know, I'm still pondering on how to continue with the Dolphyn I'm building. Someway I can't decide what to do with her. That's why there are so many people building multiple models ...
I don't mind, I'll just have to wait ;)
Cheers
Carl
Carl
Hey howya goin Chris, a fine job there mate a fine job. Love the way you did the stand.
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
