This may represent a transition period between the use of the two rub rails. I have seen these wider rub rails on other vessels from other parts of the US and you can sometimes see them used as a foot hold as they move along the side of the boat at sea. Maybe they kept it on for that purpose. I will continue to ask around to see if there is an answer.
Russ
I would expect the wide one to be thicker too as a rub rails. When I look at it, I 'd expect it would tear off easily when moving against the dock (up- and downward with the waves ...) Thanks
Carl
Of all the luggers we boarded in the late 60s and early 70s (there weren't to many left by the end of the early 80s) They always had 2 or 3 tires where they would ride over the rail at the widest part of the boat. They trawled from the stern once the trawl boards broke the water they would make wide circles washing the catch into the end of the bag then  winching in the tail bag of catch. They had what was called a lazy line just above the throat of the bag and haul it into the boat a little forward of midship. I believe the rail it was refereed to as a chafing rail assisted in the lifting of the bag keeping it away from the hull so the webbing would not catch on any protrusions , nail heads, splinters etc. Its been a long time memory fades I think I am right though I could be wrong;)
Did it happen to be docked at the large processor by the old Biloxi Bridge ?  By the way absolutely accurate and beautiful build brings back a lot of memories
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
John:
The shrimpers with whom In have spoken just called it a rub rail. It may be that some of them are not old enough to recall its exact purpose. I have seen many photos with the tire slung over the side. That may be the answer to Carl's question.
This boat worked for Biloxi Canning so it would have been docked out front. You might be thinking of Cruso's which was around back near the old bridge.
Thanks for the kind words.
Russ
she's look'in good Russ......nice smooth hull.   noting the outlines of the structures on deck,  perhaps one use would be as a footing,  as one goes fore to aft...or aft to fore.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Lest ye believe I have given up, here is some small progress. :) Life got in the way for a while, but hopefully, I can manage some more progress now.
Here are some temporary cradles I made for the model now that it is planked. I am also working on the pilot house. More later.
Russ
beautiful lugger Russ,
you did a fine work on the hull, love it....
Nils
Current builds
-Lightship Elbe 1
Completed
That is a very fine looking hull Russ; this will one little beauty when complete.  Slow progress is still good progress :)
cheers
Pat
Edited by BANYAN
the stand looks sweet!   I still have the first stand I ever made.   if you look in the Nordkap instructions,  you'll see it........and I assembled it that way.   I made another one for the Nordkap later,  and the original stand has hosted most of my past builds.  I fear though,  that it may finally find a home under the trawler Syborn.........what'll I do then!?!?!?!  :)  :D
good to see your still working on her.  she's a fine model......just wouldn't do,  to see her on a shelf or something.   look forward in seeing more of her progress ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. I came up with this general style for my recent models and I will probably use this style on other local boats as long as it is appropriate etc.
Russ
Just a little more progress. This was the perfect day to work on the model. Nice cool, dry weather.
I am making some progress on the pilothouse. This pilot house differs from the trunk cabins I have built for schooners in that a lot of the interior is visible so I need to take some care to make sure that the interior details are presentable. This is all very rough right now, but it is coming along. The dashboard will have dials on it and the small bulkhead below it will have paneling and the wheel will be mounted just below the dashboard. There will be three windows in the openings across the front of the pilot house and the exterior will have vertical planking.
Russ
When I look at what you have achieved for details on your past builds, you'll manage fine, maybe not a walk in the park, but what do you expect when you're building a model ... Looking forward to the end result of this subbuild
Carl
Just a bit of catching up Russ, that hull really does have sweet lines, Love the low shot from the stern.
I hope the weather down your way hasn't been too much of a problem.
Michael
Here is a look at the bead board treatment for the bulkhead below the dashboard. The wheel is temporarily set to check for height which is good. The bead board will get painted white. The bead board is made up from 1/8" wide strips with both edges chamfered off.
Russ
John:
Thanks. There may be another version of this, but we will see. The wheel could be a tad smaller and the bead board might want to be a shade more narrow. It will not take a lot of time to redo it if I decide to do it.
Russ
If I may suggest a little dusting of your lens ... (just pullin' your leg) I would have said the wheel looked somewhat big, but you beat me to it. Course panneling should be good, after all, it is a working vessel, and the planks aren't much wider than the wheel's outer ring (don't know the name of that part) ...
Carl
Carl:
I will probably make another dashboard assembly with some smaller paneling and see what it looks like. Thanks.
Russ
