Couldn't wait any longer on this one. It is an odd creature to say the least. I learned about this type of boat while researching Niagara and the goings on at the Great Lakes during the War of 1812. They have an interesting history.
The kit is pretty minimal. A lot of wood without much metalwork. From a quick glance things don't look too bad. The main instructions with all the illustrations is in Italian of course. There is an English version but it refers to the figures in the Italian instructions so you really need to have both opened. The plans show decent details about the build but NO MEASUREMENTS. Very odd.
 The first task at hand is to drill the mast holes in a piece they call the centerboard. They supply a little jig so that you can drill the holes at the proper angles. That's assuming you can drill a hole straight down. Good thing my drill has a bubble level in it. So I got thru that.
Now for the frames.
Here's a weird one - frames go on the keel right?  NOT! The flat side of the frames are glued to the centerboard. You have to center them and make sure they are perpendicular. I marked up the centerboard and that turned out not to be a big deal. So the first 11 frames are on.
Next are two end frames glued to the end of the centerboard. The instructions say that the flat side of the frame is supposed to be above the centerboard surface. How much? That's when I noticed there were no measurements.Turned out to be 5/32"
Added the undersurface for the lower deck
Began planking the lower deck.
Odd as it is, I still think this is a cool looking build. As you can see things are moving along well. Just what I needed - a build that won't take years to finish.  :)
03/11/17 - I have decided to add a few notes here regarding things that I have turned up during the build. Hopefully this may make it easier for a future builder. A couple of things today:
1. As you are building out the lower deck - planks, foot rests, benches,etc. - color and finish them at that time. It will get progressively more difficult to access them later. Same thing for the upper deck.
2. The instructions say to plank first then install the stem and stern post. In hindsight I will disagree with this. I would follow a more normal pattern of installing those pieces and the additional step of cutting a rabbet. I've found that the ends of the planks just kinda lay on top of the pieces. They don't integrate like they would with a rabbet cut all around the hull.
3. If you decide to do #2 be sure to make and install the gudgeons and pintles for the stern post and rudder before the stern post is installed. Don't let the gudgeons extend too far back on the stern post else they will keep the stern post from sliding all the way into place.
Mike, you may have discovered this already on your own, but Arrow is one of those European kits of a subject with a fictitious history. Although Arrow wasn't actually built, there was a design for a gunboat with that hull form and sail plan. There's a drawing of it in Chapelle's History of the American Sailing Navy.
Scott - welcome and thanks for the additional info. I'll check the MSB log.
Chris welcome as well. Yup I know there was never an Arrow, but this design is similar to the type used during the War of 1812.
I knew I had seen something somewhere on the row galleys. In Chrisman's book Coffins of the Brave there's a chapter on the Allen. I would imagine this is where Amati got a lot of their ideas for Arrow. The Texas A&M Nautical Archaeology team excavated it from a river. The starboard side was in fairly good shape and they were able to discern a lot about the design.
That book is a good read if you're interested in the Lake history of the War.
Mike,
I looked at Chapelle's History of the American Sailing Navy and History of American Sailing Ships as well as Coffins of the Brave to see what I could find. The US Navy did build several two masted lateen rigged "row galleys" in the very late 1700's and early 1800's. Some of these fought in the war of 1812, on the Chesapeake and on Lake Champaign. Gunboats also fought on Lake Ponchatrain but I don't know which design. As noted above the galley Allen was excavated on Lake Champlain and another on the Chesapeake near Badensberg, MD. An archeology report for the MD gunboat is available on the Internet.
I could find no design (Chapelle) or archeology report that represents the model that you are building. The long head and protruding stern platform are anachronisms. The American gunboats were double ended.
It would appear that the kit manufacturer either copied a Mediterranean design or imagined one and called it an American gunboat for marketing purposes.
Roger
Hi Steve - glad to have you along.
Scott - yes a chapter on that also Niagara, Eagle, Jefferson as well as a few of the British boats.
Roger - I reviewed Coffins again and it appears the drawings they show don't show the extended cutwater as you said. I wasn't  looking that close before. However the kit design does seem to be closer to Allen than any other row galley or gunboat drawings I have seen.
Mike,
I like the building of the gunboat along with your Tugboat.
Question not related to any of the kits, how do you like the storage compartments from HobbyZone?
It looks like you have quite a few of them, and I am considering to buy them in some future.
Respectfully
Hello Per - with the epoxy process for the tug there is definately some down time so another build fills in nicely.
I like the HobbyZone setup. If I did it again I would keep the same footprint but probably would have gone for more of the larger drawer units, less of the smaller drawer units. The MDF is quite thick so a 2" tall drawer really only fits something 1 1/2" tall. However I imagine it's different for everyone. If you have a lot of small stuff the small drawers might be a good thing. All that being said it is a huge improvement over what I had before.
Edited by mikiek
Beginning some work on the interior seating area. The foot braces come first. Nothing too exciting, just a lot of repetition. Cut columns to length, drill holes, insert columns and glue. The only hard part was getting the columns aligned and the same height. Height was easy. I have a stainless straight edge about 12" x 2". I just inserted the columns a little high, set the straight edge on top of them and pressed down.
The inset for this step in the plans actually had a measurement! One foul up on the holes :angry:
EDIT: - 03/02/17 - I'm adding this as I install the benches that go right next to the footrails. As I add the benches which are supposed to be laid right behind every footrail I'm seeing what a bad job I did with these holes. The pairs of holes are off in some places and in other places the starboard holes don't line up with the port holes. This wasn't overly obvious until I began to lay the benches. With the S&P benches inline it really shows when a footrail is not straight. It's not really correctable now. A suggestion to help avoid this would be to drill the holes much earlier. Even before the lower false decks are glued in place. You could tape them together (piece 21 & 22) at the ends and then drill holes thru both at the same time.  TAKE YOUR TIME measuring!! Use a square to mark off each pair of holes. If you have a drill press even better. This should make each row of holes line up better.
More work on the interior tonite. Finished up the foot rails - 28 total. I still haven't learned how to get consistent placement for repetitive things like this. They're all close but not exact.
Next up was the faux bulkheads. These were odd. There were supposed to be 3 different height pieces - 7.5mm, 8mm, 11mm. Well darned near all of them were about 8.2 - 8.4 . The placement was strange too. the tallest ones (4 of them) were placed 1 on each side by the bow & stern. Working towards the center next was  the 8mm, then filled in with the small ones. These are supposed to support the upper deck pieces.
However the bow and stern decks came out at some funky angles as you can see.
This is a problem as there are some side deck pieces that are supposed to meet them but the side pieces are too high (or actually the other pieces are too low). So after the glue dried I found something to wedge under the corners to lift them up. Then I wet down the area and will be hoping that the wood stays in that position when it dries.
I did catch one potential disaster before it happened. The masts are stepped at about a 3 degree angle. Given the typical ships we build I assumed they tilted towards the stern. NOT! The lateen rig in this build has the masts leaning towards the bow. That would have been trouble had I begun to add all the deck items.
Very interesting build. I don't know anything about the history but I do know it looks cool and that's what counts, to me at least ;):P  .
Edited by donrobinson
Don - that was a big part of it. The rigging is relatively simple as well - that's what set the hook.
As far as history, while designs varied, this type of boat had some interesting roles from the late 1700's into the 1800's. From bay and coastal duties to lakes and rivers.  The English used them quite a bit also.
BTW - the trick I tried - wetting the deck with a wedge under it worked. This morning the corners of the piece stayed put. I will be doing that one more time. I need to find slightly thicker wedge to list the corners a little bit more.
Edited by mikiek
Here's a look at the deck section after "bending" it.
However I could not get the edge in line with the edge of the side piece of decking so I cheated. Added a brace to the side piece that will go under the bent corner of the bow piece. They'll be nice and flush that way. A few pix may explain it better.
So here's how the decking ended up. All of that will be planked.
I guess I did not grasp the concept of those false bulkhead pieces. I glued them down for support of the deck not realizing they are really supposed to be the extension of the frame pieces down below. It's going to take a lot of sanding to round all that out. As you can see some of those bottom frame pieces don't even extend out to the edge of the lower deck.
No matter. It all needed some serious fairing up anyway.
If the deck edge seems a nice fair curve, perhaps the solution is to pad out where needed on the bulkheads to match the deck edge.  Add a shape like this:  (( to the bulkhead and sand back to get a nice curve.
Nice start Mike.
I've heard conjecture that the kit is a representation of the Burrows, which was one of McDonough's row galleys on Champlain. Arrow was a mis-translation from what I recall from somewhere...
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Welcome Joel and a great idea. I was getting concerned that the entire hull was getting smaller. Once again, me trying to make things complicated.
Joe - Welcome also. That's interesting. McDonough built a number of galleys - Allen, Burrows and 4 others. They found a galley downstream from Eagle and Linnet and it is believed to be Allen. So they have quite a bit of info. I'd be interested to know where any info (specs or design) on Burrows is. I would imagine since they were built at the same time they would be fairly similar. There was some discussion earlier in this log as to whether the cutwater in the kit is accurate. From what I have read about the Allen excavation the stem was not complete, so we may never know. When they drew up the plans based on the wreckage the stem had no protrusion forward like the kit does.
Thank you Scott. It's an interesting build. Some details here that you wouldn't run into on a sailing ship. As a matter of fact, oars is one of those. If I do choose to do them I would consider having them in place sort of like the Roman & Egyptian galley models. The reason being there's 28 of them, I think trying to bundle up that many and place them somewhere in the boat might look funny. Even if I did 2 bundles of 14 - one per side.
I have run into an aesthetic  quandary. The planks for the upper deck are walnut. I will give Amati an A+ on the cutting work - good clean edges, consistent size. However the color range goes from the dark brown we know & love to something so light it looks like basswood. I did not notice this as I began the deck planking. It took 2 sticks to cover the stern deck and as luck would have it I grabbed 2 of the dark ones for that. So the stern is all dark. Now I'm working down the boat and seeing that the contrast between the darkest & lightest sticks may be too much. Especially since the stern is all dark. Don't get me wrong, I like having planks in varying shades but maybe not in this case. I put some natural stain on to see if that might even it up. Ehhh.
The pic sort of shows this but it is more pronounced in person. Would appreciate some opinions before I continue on or tear them off and redo.
And no, I will not be outfitting the build with carbon fiber tubes  :D
Edited by mikiek
Thanks Joel. I think the variations might look better had I not done the stern with the dark planks. I may try to pop a few of them up and replace with a different shade.
Maybe some O.C.D. surfacing? :)
OK guys - Continuing on. Will leave everything as is for now. As Scott mentions I could always stain it some color. What I was using earlier was Natural - no color added. Should be finished in an hour or two.
Upper decking is laid. Color is still questionable but I will wait until tomorrow to see what the stain looks like when it is completely dry.
Normally for a strake, I like to cut a stick into pieces and lay those as individual planks. At the bow & stern this didn't come into play as those are all short pieces. I did not do it on the central beam either as that will have quite a few covers for what I suppose would be storage. Short planks would have been laid in between them not staggered.  I could have cut planks for the rails but I had already put down 2 whole sticks before I realized I should have cut them. The rails will be fairly busy with little items so it probably won't be noticeable. Planking around the big holes was the only real challenge. I forgot I had a set of riffler files, so when I finally pulled them out it was easier to file the round edge.
Still have some hull fairing to do. As suggested by Joel, I added some "padding" to the false bulwarks. Now I can sand a little more aggressively.
BTW - there is another piece to the bulwarks that will sit on the upper deck. I'll do a better job of lining these up.
Hull planking is supposed to come next but I have a bad feeling about the foot rails not being correct - too high - so I will continue on with the upper deck for now.
Edited by mikiek
My first real problem with kit materials. Maybe there is a way to do this without mangling the parts. These are the top piece of the frame or fake bulkhead. They will be glued on the upper deck.
The parts get splintered when cutting them from the plywood with an exacto.
Unlike the other pieces of the frame, I believe these parts may be in view when the build is complete. And being laser cut there is the unsightly char that would have to be sanded off. I'm thinking of replacements. Take a dowel, rip it into quarters, then cross cut. If I can keep the results from flying away from the saw, it might work.
I can give that a try Scott. If I could use a jewelers saw that might work as well. Maybe a good chance to practice.
I am going to have to replace 3 pieces somehow as I have already destroyed them.
