HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Time to glue down the fife rail, the boom support is not completely finished.
Somehow I like the contrast in-between the rail/boom support/belaying pins. This instead of having it all white.
1292453067_fiferail5.JPG.ac84b1cf0df819e23c370fbabd56b8ee.JPG1367325753_fiferail6.JPG.8ba6d02989d78bb7971474d02cedc1fa.JPG
Respectfully
very nice :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 3 months later...
This build looks amazing. I have the kit on my shelf waiting for me to finish up a couple projects. I can't wait to get started and this log will be a big help. You did a fantastic job on the deck in particular.
Thank you Bobby, for the nice comment.
She is a nice build, sometimes I have stayed true to the instructions other times other sources have been to help.
Right now I am in stand still due other commitments. Looking forward to get going again,  and also seeing your build log.
Respectfully
I have finally been able to work on my dear Bluenose.
Starting up where I left off wasn't to hard. A light clean up of the work-area and I was ready again.
Creating the Gammon iron for the bowsprit was easier than I thought, using the plywood from bulkheads and false keel, I had the right thickness and with a bowsprit ready shaped I clamped it down and used a plier to get the angles.
The aft hatch was created with a center block and strips on the side. The sides are taller to sit the umber top piece.
Again this will be natural colored just like the other hatch.
Respectfully
good to see your progress again Per......the finished fife rail looks awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Let me see if I can be true and finish her before the summer is over............ which I doubt...😎
Respectfully
Aft hatch coming together with eye-connectors on port and starboard side.
This is a composite picture, so there might some misalignment within. Sorry about that.
Respectfully
I had a lot of thoughts around the main cabin, and finally decided to make it out from solid basswood.
I am so glad having Byrnes thickness sander, to get the material down to right thickness before applying any roofmaterial.
In order to get the cabin shaped correctly I started hollowing it out, to get some walls.
More chiseling is to be done.
This will also allow to create the port and starboard skylights.
Placing a coarse sandpaper over the area where the cabin is to be located I was able to create uniformed "walls".
Respectfully
As I am cheating when building the main cabin, instead of planking the sides I am using a sewing thread to create the illusion of plank separation. When 16" away I can't tell if it's scribed or not. The line is glued into places with diluted wooden glue.
Edited by Nirvana
Respectfully
On 7/13/2019 at 7:50 PM, bhermann said:
Good to see you at it again, Per.  You are coming along nicely.
Bob
Bob,
Thank you, you certainly inspired me with your build log.
Respectfully
Bending veneer for the cabin.20190803_171853.thumb.jpg.2a1d6f8d4523984af46e4f777ddaf4a1.jpg
Respectfully
Corner trim in place so is the brass rings for the airport. Test fitting on the deck.20190804_183905.thumb.jpg.fd9ffa4dfbcfc76a9d34c6469da543f4.jpgmo
Respectfully
  • 9 months later...
Belaying pins in place.
Have to change the format of the video, so it's playable. Coming soon.
Update with video.
Edited by Nirvana
Functional video
Respectfully
I figured out how to do this, hopefully the video clip will work at your end too. Did a test prior uploading, and it worked on my side.
Respectfully
Nice to see them all marching into place, Per.  Now what spell did you use to get them to do that?  :)
The finish looks very good too!
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Bob
I just told them, get to your positions and get in 😂.
It's a simple photo trick everyone can do. I used ACDSee video software to create the sequence. Each move is one frame, then it's just a matter of time of display for the frame. It's a fun feature.
I can create a tutorial if someone wants to know how I did it. I won't say mine is the best, but it was my first try.
Respectfully
  • 2 months later...
I’m still not sure why you had to thin the bulkheads. Could you provide some further explanation? I have not seen that done on other model builds of this ship. Getting ready to start this build myself so just want to understand the why.
thanks,
John
thanks,
John
John,
I am sorry but, I would appreciate if you could list the post number so I can find it easier.  Because I can't recall anything about thinning the bulkheads.
Thanks for asking.
Respectfully
John
Per, if I may.  I suspect John is referring to the tops of the bulkheads that become some of the deck stanchions.  My recollection is that the kit-provided bulkheads were thicker than the stanchion dimension, and that is the reason for thinning the top of the bulkhead above where the decking is laid, to make those tops the same thickness as the stanchions.
For my build (many years back) I simply cut off all the bulkhead extensions and installed new stanchions above the deck from end to end.
If I'm wrong, John will post a reference to the post he is talking about, and we'll move on from there :)
Bob
Bob, I  don't mind at all.
Yes, that's what I did. It was the stanchions I  did it to. But they were cut of after the planking was done and replaced.
Respectfully
