On 27/7/2017 at 3:29 PM, dvm27 said:
Your building technique requires  all the varying angles and surfaces fay perfectly into each other. Extraordinary work you are doing!
Thank you very much
Matiz,
This is beautiful work! Very accurate milling and hand work from what I see.
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
It appears that our French and Italian building friends construct those difficult hawse and counter timber assemblies off the models. This certainly seems like a simpler (and probably more accurate) method then building in place. Lovely work Matiz.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Good evening, A constructive note on the 74 gun ship of Boudriot, the foot of the frames is parallel to the keel, and not horizontal,To the bow have a tooth, to the stern, where the tenon is present, there is no tooth
40 minutes ago, hjx said:
really pretty good!The schedule is quite fast
Hi, hijx
the progress is fast because model building started in 2001, the pictures they are public are about 10 years ago :)
