Dan, maybe you can help identify the piece on this page with the bottom plates. It has no number and all the bottom plates 1-8 are present and accounted for.  Also, followed your advice and am putting in some longitudinal bracesimg105_edited-1.thumb.jpg.63cabc9f3a13692b40922dc98b2fbf91.jpg
Hard to say Ron - perhaps part of the Rudder? It's definitely part of the lower hull below the waterline. It might need folding but it's an odd shape. Can you put up a pic of the other Hull Skins?
Good to see you took the advice on extra hull bracing :).
:cheers:  Danny
Cheers, Danny
My guess is the publisher has just filled in the blank space between parts with a colour 'swatch' which can be used to make repairs or patches.  Some publishers do this, others don't which is a pain as it means trying to colour match any repairs.  Usually big enough to make at least one full size replacement part though.
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
i must say, that you posted almost perfect snaps of i assume majority of the kit. if i was you, i would put something across the pages prior to picture taking, just to make life of pirates a bit more miserable.
Pavol stands for Paul, Pablo, Paolo etc. Please do not try to pronounce it, just call me Pav...
Doh .... of course it is :D. I gotta say, they sure pack them onto a page.
No real problem there Pav - the pics are too low a resolution to be of any use to someone copying them.
:cheers:  Danny
Cheers, Danny
danny, you would be surprised what have i found in the dark corners of the internet...
copies so bad, that unless you would use repainting heavily, there is no way to build anything presentable out of it...
Edited by maaaslo
Fair enough ;).
:cheers:  Danny
Cheers, Danny
I deleted the whole post for you.
:cheers:  Danny
Cheers, Danny
FYI, I wont be posting over the rest of the month. Mrs and I are taking a trip to Italy to celebrate our 51st wedding anniversary.  We missed out 50th celebration as my wife needed gall bladder surgery.  Good thing we had trip insurance!
Trip to Italy was the Tauck "Classic Italy".  We started in Sorrento and the Amalfi coast, then went to Pompeii, Rome, Orvieto, Assisi,San Gimignano, Cinque Terre, Florence, and Venice.  A fantastic trip
Now that I have nearly finished the hull I have learned some valuable lessons.:default_wallbash:
1. Use white glue VERY sparingly.
2. Keep your workspace spotless so that you don't lay a critical part on some wet paint:default_wallbash::default_wallbash:
3. Thicken the bulkheads or add lots of longitudinal bracing so that all of the hull plates lie smoothly.
4. Trim the seam-hiding strips so that the additional armor plates do not overlap and leave an ugly bump.
5. Write part numbers on the back before cutting out.
I can't wait to see what I learn as I attempt the deck furnishings.:cheers:
I certainly agree with all the above Ron, but Number 2 doesn't work for me (see pic :D:D:D ) :
:cheers:  Danny
Cheers, Danny
21 hours ago, ragove said:
Neat workspaces are a sign of a disturbed mind.
I think you're right Ron. I must be getting better then :D.
When I finished skinning the hull of Amatsukaze I made and attached the permanent stand to it. I also tack glued a large sheet of balsa under the stand as a protection against bumping into the odd tool (or twenty ;)) on the bench. That all worked rather well  :).
If you intend using that cradle, I'd suggest you cut largish 45 degree angles into the uprights - they look like they will restrict your reach somewhat. I can see bruised wrists coming up ;).
:cheers:  Danny
Cheers, Danny
:cheers:  Danny
Don't think that is necessary, the cradle is foam-core poster board so not likely to injure me.  But, point taken, the edges might get in the way.  I will see how it goes as i progress.  Not sure what to do for a permanent mount if she ever gets finished.
