Thanks for the liks and the info el cid
I diddent find anyting about lights on the syren so I made up my mind to make 5
one down below, one in a lantern monted in he hull were the ladder is ( port 4/5), 1 in ech mast monted in a lantern, and
one if I can pull it off , a capt.figure holding a lantern in historie hand
if is historic correkt ??? but ider way I think is going to look grat and it wil be seen from the sea😉
Svein.erik
Svein.erik
Hi
I did some work on the mast, wel I ned to beginn from there
yust to get the wirering clare and to make it work at this time
I drill some holes in the mast and carved out some wood under the ceeks for the cabels and I wil conekt them
the pico wil be conekted into a lantern later
Svein.erik
Erik - I saw you post on Dirk's log. I assume you have the list of rigging line. I too want to do the same. let me know what you find for the blocks. I have ordered the wheel, line, hooks, grating, & Cleats.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Hi
thanks, well I realy do Not know at this time
I thing I May have to make the lanterns my self to get this fit
and I wil by some crew member and also try to fit some wire inside an out the hand
and then make a lantern to hold in his hand
befor I do that I have to try it out first😶
Svein.erik
Although I haven't worked on it in a long time, I also did some work on adding lighting to my Syren.  Very similar to you, I will be using pico LEDs, but I am still not sure where.  Definitely below deck and maybe a couple other locations.  It will be great to see how you place them.
I also did some work on a small lantern:
Hi am nerly back on the syren build
thanks for the liks
now back to wat am doing,  am still waiting for the castello boxvood planks, butt I started to get the sheet line in order and am
happy with the outcome
I did also mesure the wale planks 3 stk.5/32 and 1 plank 1/8 on the botten wale.
Then I started to line off the hull
am going to plank the syren hull with the spiling teknick,  and yes the hull is getting copper plates butt am going to do this as a practice so I can do this on a hull without copper plates later.
I think this is going to be fun😇
Svein.erik
Hi and tanks for the likes,
dunn some more work
planking of the baboard side is also dunn and am at the start of the stern,
The sanding in not dunn yet but its coming nicly together
I will Soon begin the treenails,  for this I will use walnuts color with light oak finish
Fore the Wales I maby using round headed metal nais ( I maby the first to do this on the syren)
Svein.erik
Hi again
Finish the transom and put 2 more 5/32 planks for the wales but not the 2 ones , it will be dunn later
I also define the lines for the treenails  (74 lines) +
There will be 2 nails in ech plank yust for the fun of it😲 (prototype has one)
1480 + nails on 1 side
I also took a photo of  a test using round headed metal nais  and reduce it to fitt the scale  (about)
this is fore the wales
Svein.erik
Thanks for the kind works and likes
This is my last photo for know , I have to start all over again (the other side )😊
I have painted in chucks spirit😉
there are 10 layers of thin paint ( mars black akryl from winsor )
After all planking job is dunn I wil paint the rest and many more layers
so I gess I will start nailing again😨
Svein.erik
This is wat am thinking about doing to the wales
brass nails scale down to fit
but am ?????😲
I can do this 3 ways so it dosent get to be over killing on this
wat do you thing??
Svein.erik
