Thanks everyone for the likes
I did finish the starboard hull planking , I did some mistakes here erlier
my tappering was not enuff at the start, so I got a problem with the last 7 planks
but I did get the 7 planks inn tappering to half a with
I have to take the garboard plank more aft then I was thinking
so its not perfekt but close and the hull is getting copper plates later 😊
Svein.erik
 Not a thing wrong with your hull. Looks great! Nice smooth platform for coppering.
Edited by Jim Rogers
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Thanks for the liks everyone 😄
Am keeping on running,
A have know faring the inner bulwarks and some planking at the stern, I will wait with the rest planks so I can make the hole
for the rudder.
I do have also the 7 last planks on portside to finish
To faring the inner hull I used  3 pises of tools , easy peasy 😊
Svein.erik
Hi again,
yust another task has been  dunn
the cap rails , for this I used 1/4×1/16 castello boxvood
it was wery easy task , soak it in warm water for about 90 minuts and started to lay the strip on top,strig it
and bend it around
The boxwood strip is in exelent condison 😊
Hi
so, am started the planking of the inner bulwarks
Using some wood inside the gunports and sweep ports
than plank around , it works well
I finish the stern planks and started to paint it red using artist paint from winsor and newton  (the cooler crimson)
All the planks is castello boxvood
Svein.erik
Hi and thanks for the likes
Am know taking a hollyday and the trip goes to auer apartment in cypros
But i wil be looking in the sites from there 😎
Best regards
Svein.erik
Enjoy Cyprus, I love that island.
Eat and drink well.
Respectfully
Thanks for the liks,
I did also made a test for a lamp , using basswood
I wil make this in boxvood later (need 5 pices)
2 inside the bulwarks , 2 in the mast , 1 for the capt.figure holding it
and 1 down below cabin (do Not need a lamp here)
Am using pico leds
Svein.erik
Thanks for that Rich,
and something else, the cabel thats coming out of the hull is to use
To pickup the pico led cable  later
and wil be conekted to the cable under the dekk,
so no cable wil bee seen.
Svein.erik
Hello everyone, am know back from hollydays and ready to modeling😀
but I did have to rebuild the shipyard  ( chuck making so grait kits😆)
So I need more rom to build them😉 the nex thing to do is to organize all the tools
All the heavy stuff is in a hobby rom nex to the garage so I have a dust fri space.
Best
Svein.erik
Thanks for  the  liks,  am finish for know,
got most of the tools in the box, under my work space I have 32 boxes
and 16 holes with bigger box etc to use on my other work space.
I have som close cabinet for bigger items to
and I know can see my confederacy too😄 I do also have 2 long boats in the box and the starter kit cheerful from syren (chuck)
Its time to get started on the syren😉
Svein.e
am in to the build again
so I started to do the fillers for the cap rails and ...... the pre made caprail  did not fitt this time and I Wonder why 😲
I then started to do I it over but this time I use not boxvood but basswood
I used 1/32 insed of 1/16 but in to layers to get the thickness and it works well,
I did also make the pin rails  (boxvood )
and I working know on the main rails cut out of boxvood sheet
I did steel Dubs ide for the rails , cut them up in lenght using a hook scarf
Svein.erik
Huston I have a problem 😲
Looking at the cast metal for the stern gallery, it looks like $$$$#@(:.............
so am thinking I have to make some New ones
I have numbers of fitting items from artesania latina, and am going to use them
I have to cut off the top an bottom , this is in scale and then make some Windows etc
Aa, I am ost forgot,  Chuck I need some New ankers 😲
I did look at Alexey Domanoff  (how to make small nails with round head)
But I used a file for this , it works. So I make a sample, posted it on the wales
Yust to see how it looks.
erlier I did or maby wanted to install this to the wales but it diddent work at that time, so with this metod it can?
it may not be historycal correkt but it make the wales come to life, the nails on the photo is a bit to large and if I do this I wil use brass wire, in this case I yust used wat I have, black wire
Wat do you think?
Svein.erik
Edited by svein erik
Thanks for the likes😊 but no comments on the nailing the wil, LOL
I havent drill the hole yet so I have some time to deside,
there are no syren like this yet.
I do like to do experimenting,  its only my Mother in law's ship🙊
Svein.erik
The stern photo in not a good one or .......
I did se it wen the ship is turnd (not upside)
The plank where the ship name is going on has to be ripped of , New and thinner plank has to go in.
OMG😬 I diddent se it .........
Svein.erik
Thanks for kind Word and likes,
but the stamp in not my thing😲 it work at first, Then ......... Its making a mess,
so I looking around the  site and get a hint 😆
Making nails patten using derma rollor, so I order one and something else to go😉
It need to be rebuild a bit.
Copper plating the hull really consists of 2 steps: a) making the copper plates and b) mounting them on the hull. There are a lot of examples of how the plates can be made. I followed a lead in one of the build logs and used diabetes needles to generate the nail imprint. There is also a nice little micro press which I bought at Micro Mark which can be used for stamping the plates. Or the plates can be bought already finished from Blue Jacket or other companies. Mounting the plates just needs a little 'dry practicing' until one gets the hang of it. The finished result is normally quite rewarding.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks for the comments and likes,
I have painted the casting for the stern gallery,  the paint looks ok but the casting looks like ****,
so I do need New one or make it my self, but how do I do that😲
Svein.erik
