Have now finished the decks, inner bulwarks, and cap rails.  I like the color scheme on this model a lot.
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter, Amati Bismarck, Occre Jupiter Locomotive, Caldercraft Brannaren
Currently Building:  Mantua/Panart Amerigo Verspucci
Chris:
I can't find true matt in the hardware stores here, so I use satin, which is pretty flat.
Regards,
David
David Robinson
Boston, MA area
Bow detail completed, and I made plenty of mistakes -- if you are sharp eyed (or even not so sharp eyed) you'll be able to pick them out.  Nevertheless, I'm satisfied with the overall look.
Some notes:
  • The instructions call for the figurehead's wrap and the small strips to be blue, but I like green better so I used that color.
  • The lighter piece leading up to the cathead support is something I had to fabricate.  The instructions call for brass strip to be "manipulated" into shape, but I tried it and got nowhere, so I used some leftover wide basswood.  In retrospect, I should have cut it from a corner of one of the walnut ply laser sheets -- one of my several mistakes here.
  • The instructions say to paint the brass yellow or gold, but I don't get the point. The brass in its natural color looks great.
Figuring out what went where was something of a challenge given the instructions and drawings, but there are enough pics on the internet and in build logs that I was finally able to figure it out.
There is also a pic showing some minor progress on the deck.
Now on to the side rails and decorations.  Looking forward to that.
Regards,
David
David Robinson
Boston, MA area
I have started on the side rails.  The instructions suggest fixing the lowest rail according to the plan drawings, then attaching the lower row of decorations, then fixing the next rail to the top of those, and so forth.
When I went to the plans and took measurements, I wasn't confident in how they were matching the actual boat, and was concerned that the decorations would not line up properly -- would I miss the window alignment or something further up.
Since the lower row of decorations has cutouts for the tops of the windows, the alignment of the decorations to the windows is really the critical thing.  So per the attached picture, I aligned the decorations on the windows and taped them.  Now I can install the lower rail up against them, and know that my starting point will work all the way up.  Same thing going across the center -- I can align the top of the decoration to a dry-fitted second rail.
Regards,
David
David Robinson
Boston, MA area
The lowest side rails are now in, and I have painted the hull above them, ready for decoration.
I'm going to do this side all the way through first, so I can do the other side (which will be my display side) better if I learn anything unexpected.
Regards,
David
David Robinson
Boston, MA area
Looking very nice - lovely tidy paintwork.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Decoration on first side completed (except for the large stern windows, which I'm painting now).  The approach of using the window cutouts on the decorations worked really well and everything lined up.
I also found that the best way to fit the decoration that abuts the curved endings of the top rail is to dry fit the rail and position it with the decoration dry-fitted, to get both right as it's a tight and exacting fit.
Regards,
David
David Robinson
Boston, MA area
First side now finished, with addition of the stern side window and the top rail.  I noticed that the stern side windows in the Amati pics and some other build logs are more simply painted, and having now done these with discrete window frames, I can see why.  Lots of retouching multiple times.
Now on to the other side, and then the stern fascia.
Regards,
David
David Robinson
Boston, MA area
[NOTE:  I HAVE REDONE THE STERN PICTURED IN THIS POST.  SEE WHY HERE AND THEN REDONE STERN IN NEXT POST]
Finished the stern.  "FLY" is not quite centered -- the letters are devilishly small, and the CA gel I use that typically gives me at least 5 sec to slide things into alignment decided to grab right away, so I ended up with the "L" closer to the "F" than I had planned, and that governed spacing to the "Y".  Nevertheless, I'm happy with the stern decoration overall, and the green highlights worked well.
Regards,
David
Edited by drobinson02199
David Robinson
Boston, MA area
I worked too hard on the stern gallery to have that off-center lettering spoil it, so I removed everything in that section, repainted, and remounted.
This time I aligned the letters on a piece of paper, and then picked them up with a small piece of painting tape.  Added glue, applied the set, and then peeled the tape.  That did the trick.
Regards,
David
David Robinson
Boston, MA area
Rudder mounted as well as tiller & tiller housing.
Regards,
David
David Robinson
Boston, MA area
Worked on channels:  first picture shows channels with pins in.  They are only 1.5mm, so it's delicate drilling.
Second pic shows the channels installed on the ship.
Regards,
David
David Robinson
Boston, MA area
Spyglass -- Thanks for the comments.  Some answers to your questions:
1)  Yes, I am leaving the top rudder pintle unconnected on purpose.  I did it because once it's on the shelf, only the really sharp eyed like you would notice, and getting the other three aligned was difficult -- and they were barely aligned -- so I didn't want to add a fourth one into that equation.  There's actually a fifth one provided and showing in the Amati pics, but on my model there's no room for it.
2)  The under deck gun carriages are painted and mounted in place, so I just have to insert the guns through the gun ports.  I'm waiting to the very last for that so I don't hit one and knock the gun carriage loose.
3)  Yes, again your sharp eyes picked up those notches.  I acknowledged this in an earlier post, and it's a learning for me.  It comes from the plank bender blade biting through on that side.  I actually don't need the plank bender, as my steamer will take care of all the bend I need.  I didn't notice those notches until after I had mounted the planks and I wasn't going to rip them out.  So for finished planks, no more plank bender.  It's fine for layer 1, but not layer 2.  I didn't get this on the Revenge, so I think it must be some aging in the plank bender and misalignment of the blade.
Regards,
David
David Robinson
Boston, MA area
Spyglass:
Great suggestion, which I took -- see picture and much improved rudder appearance.
Re the barrels:  I tested each carriage as I mounted it by making sure I could place a cannon through the windows -- particularly important because I framed the windows which makes them smaller.  One or two are tight -- but I can get it done.
Regards,
David
David Robinson
Boston, MA area
Hey David, this rudder looks super. What did you do different to the first rudder picture you took a few posts up? It does look heaps better now they are all connected I reckon. I am really enjoying your work on this build. Doing a great job on her.
Cheers
Chris
Chris:
Thanks.  If by "what different" you mean mechanically, I glued an eyebolt into place and trimmed it.
If you mean photographically, I cleaned my lens!  It had some stuff on it in the previous pic, I think.  :piratetongueor4:
Regards,
David
David Robinson
Boston, MA area
Deadeyes and chainplates installed on the channels.
Regards,
David
David Robinson
Boston, MA area
All deck fittings and gunport doors now done.  Next step is masts, yards, and rigging.
Regards,
David
David Robinson
Boston, MA area
Chris:
Yes, I do plan to rig them -- but I forgot and might have kept forgetting, so thanks for the reminder!
Regards,
David
David Robinson
Boston, MA area
Finished the lower fore mast.  It's just dry-fitted in the picture.  Lots of detail and blocks to attach.
I really like this kit, but one thing I don't much like is the instruction to dye natural thread black when a small diameter thread is needed.  The reason given in the manual is that black thread gets brittle when glued, but there was plenty of it in the Revenge kit, which is a later Amati Victory series kit.  So I'm using the leftover thread from that kit when I need thin black.
Regards,
David
David Robinson
Boston, MA area
Hi David -- I have barely learned about your build, and here you are flying like the wind ahead of all the other Swans.  Great work on this beautiful ship!  Can't wait to see how you proceed with the rigging.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks, Martin.  I think I go fast and then slow, depending on what else is going on.  I'm working on the bowsprit now, and there are a LOT of blocks to tie on.  I think I'll do the bowsprit yards and attach them, and then shoot out another picture.
Regards,
David
David Robinson
Boston, MA area
Finished the bowsprit and went ahead and did the bowsprit yards and mounted them.  The only rigging on the bowsprit so far is the yard lifts.
I thought the bowsprit was the most complicated block/deadeye assembly I have encountered so far in modeling.
I also included a shot of the full foremast, which I completed since my last post.
Regards,
David
David Robinson
Boston, MA area
looks really great david. lots of fine detail work with all the blocks and rigging. at least the riverboats have minimal rigging to get around.
cheers
chris
