The four photos show her in 41 in drydock after her ramming of a destroyer and a still from a video after he returned from the USA (paintwork falling off) The cable is at the front and rear. .
3.thumb.jpg.8cb3af7be0c22dbb84618dbe9c3a7057.jpg4.PNG.9444bdc80e5121ca70493333422ee8c8.PNG
The this photo from her during the invasion of Sicily in 1943 shows the rear of the cable present, notice the nameplate is framed by it.  There does not appear to be cable at the bow.
You can see the 1945 shot of her stern with no cable and some portholes closed over. 2.jpg.ea24280c89c664d00057c275736c4f03.jpg
Greg
4 hours ago, lmagna said:
That's what I was afraid of! :(:default_wallbash:The reason I asked was because I still have the Titanic looking at me to do for the wife. I have always done drilling and sawing on plastic by hand as well for the same reason.
Thanks
Maybe start on the Titanic, instead of writing about it ... now you've seen how it works by following RGL's builds. Did you see his logs on the Japanese armada?
4 hours ago, RGL said:
Just sit in front of the TV with a pin vise and drill away, it’s mindless work but has to be done
Nice relaxing passtime after a hard days work ... something to look forward too
Probably just right for me then.
Nah, you would get bored real soon ...
3 hours ago, popeye the sailor said:
off and running I see......... ;)   I used my battery operated drill for the Vendetta.......does well at a slow speed.   now,  if I was to do anything major for a modification,  I wouldn't use a scroll saw...already seen where that gets you {now THAT'S a mess}.   have you a method thought up to cover over the potholes aft?   I would think really thin brass.......use a paper punch or something to make the circles....would do well.  better yet though....I've seen items in the local craft store,  like confetti,  or look in the clothes enhancement dept......I've seen stuff there too that can do well in covering them up.
Greg beat me to it, but he has, as I do, a lot of those portlets from Yamato, your paper punch idea is nice, but maybe only for over sized portholes, brass rod would make it very expensive
You have set yourself quite some prepping, mate .. drill out portholes, making the deck flush ... I'll stick to rigging for the time being ...
Carl
Not yet. Providence first!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
2 minutes ago, RGL said:
Hurry up as you can get the Seydlitz
I wouldn't stand a chance at keeping up with your quality and no one can match your speed!
Besides, (I'll tell you a secret if you keep it to yourself) I went ahead and bought the Indianapolis and have located the brass and fighting tops I will need to build it as the Houston! Hiding it from the Admiral because she REALLY wants the Titanic as a night light!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
that's Dirk........putting holes in a star destroyer,  before the rebels do  :)
well take solace Greg that your building her at a time where she still has them......you won't need to do all that ;)    will you need to do the square ones?   glad you found out about the D cable :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
what can I say.....I route for the good guys ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 hours ago, Raven101 said:
Count me in on this build - just started on Tamiya’s Prince Of Wales with the Pontos detail up set.
Build log?
Carl
Ok, I’ve made a start on the hull, only 120 or so portholes drilled out, all the deck details cut off and sanded and the 3 purge ended deck stuck on, including some plastic card to fill the hole amidships.
This Ringol set from alliance Modelworks will be used above the portholes, and you can also see the amount of detail that needs to be scribed into the smooth hull.
The plan is to do the layers of primer first so I can build up some thickness then place the ringols and the rear part of the ships degaussing cable.
Greg
I think this would classify as a form of torture.......   the diagram shows the square portholes too.......are those going to be added as well?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Greg, any chance of slowing down - I am getting dizzy trying to keep up with your builds ;)
This looks like a great project and you are certainly off to a really good start.  Your research in your quest for accuracy will result in a great model of her.
No room in the rafters so i'll take a pew in the foyer (better access to the popcorn out there :))
cheers
Pat
I'm in as well and plunked myself down next to Pat and the popcorn.  Any coffee around?
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
cheers
Pat
Apparently  throwing popcorn or other snacks at him slows him  down, as he cant duck and build at same time.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hmmm, what's set off ...? Woke me up again you lot!
Nice progress RGL, bit sloppy on the alignment of the squares mate, they're all straight :wacko:
Carl
looks good Greg :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
