Kortes
    Will you be applying a heavy coat of varnish to your model as is shown on all of those harbor photos?
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
19 hours ago, wefalck said:
Very clean work. I like this combination of wood and metal !
Did you glue the steel edge to the lee-board ?
Yes, for the assembling i used PVA adhesive and СA.
1 hour ago, BETAQDAVE said:
Kortes
 My greetings, Dave. There's no point in coating with varnish the model as the functional yahts.
The more so, it is considered bad form in the region where i live, the shine has to be matted. So, as uasually I plan
 on covering it wwith tung oil or linen oil.
My best regards.
Although a boeier that does not shine like a mirror is considered to be ‘a bit neglected’ .
modelling standards and ship-standards clearly no not coincide :)
are the leeboards flat, or do they have a curved profile?
jan
Edited by amateur
Btw make sure the bolt is in the correct place: it is slightly below the centerline of the leenord, not on the centerline.
this image shows a drawing of a portside leeboard of a friese boeier (drawing downloaded from maritiem digitaal), newer than Sperwer, but valud for almost all boeiers, i guess)
Jan
On 12/9/2018 at 9:35 AM, wefalck said:
Incidentally, the Dutch national archives and some museums have a lot of plans for downloading.
wefalck : Which ones? Besides het Friese Scheepvaart museum which has many plans, what other museums have plans for downloading?
Marcus
What do you mean? The foto is exactly like the drawing: the bolt is just below the mid-line of the leeboard, there is only one difference: the number of planks used: 8 in the drawing, 7 in the leeboard of the sperwer.
the curvature of the leeboard is too small to be seen in the picture.
Jan
Edited by amateur
@Marcus,
the only one I am aware of is the navy-archive, that has almost all pre-wwII ships on line (in very high definition, and lots of detail drawings.
next to that is maritiem-digitaal, but most of that is low-resolution, small sized (like the one of the leeboard, posted above).
Apart from that, I do not know of anything.....
Jan
Hi Kortes,
nice tiller. When the tiller is completely to the left or right, does it stay clear from the bulkhead? Very ofthe the tiller has a very subtle curve upwwrd, just to make sure that it does not touch the bulkhead.
Do you also plan to add the eyesbolts to attach the flagpole to the rudder?
Jan
Marcus, I believe 'maritiem digital' is a sort of portal through which one have access to (some) material from various museums, including, I think, Rotterdam. I have not looked at it for some time though.
Concerning the varnishing, I found this always a bit garish on the Dutch boats that have been converted into yachts. Must be some sort of fashion, but in reality doesn't say anything about the quality of maintenance. A thick layer of varnish on a model too looks much like a cheap souvenir model, where also 'glossy' seems to be taken as a sign of quality. I gather something a bit more glossy than satin would be right. Personally, I would apply some cellulose-based woodfiller, rub this down with very fine (0000) steel-wool and then polish with a felt-wheel in a power-drill. On the hard wood you used this should give a nice sheen whithout adding a perceptible layer of varnish.
Yes, I checked. :)
Quote
Yes, I'll show you now.
Quote
Edited by KORTES
Maritiemdigitaal is the portal used by the dutch maritime museums to their digital database. The quality of the pictures differs between the museums, and there is no way to order high quality copies of the pictures/foto's/drawings shown.
But as the museums have invested in this system,they have no own database/ordering system (the fries museum being an exception, but even there is no download-option/ordering option)
Jan
Beautiful workmanship on the lee boards and the rudder Kortes.
Michael
Somehow I liked the bright steel parts. Many older museum models have such parts left bright - does work for a model, but not possible, of course, in real life.
