Hello my friends and fellow mates,
after a long break I come back to my shipyard. I have a very challanging projekt to solve - the Friedrich Wilhelm zu Pferde. I plan a construction time of more than four years for the vessel. The box is full of material of obviously finest quality. I will take some photos an publish them the next few days. I downloaded all the interpretive documents  available at the Euromodel site written by Peter Coward. After studying the book I will go to the working space with great respect - though I do not know how far I will follow the modifications. But I want to build a real good model further than the not-modified one.
I decided to start now although I actually wanted to wait till I am retired - but this will last another 6 or 7 years. So long I did not want to wait.
I will be back soon with some pics of the box and the material.
Cheerio
Max
:10_1_10:
Next: Friedrich Wilhelm zu Pferde by Euro Model 1:47
Finished: Half Moon Corel;  HMY Royal Caroline Panart; HMB Endeavour Occre 1:54; Fregatte Berlin, Corel, 1:40
A life without dogs is possible... but worth to live?
Hi Mark, thank you for your attention. I am not sure how big this project will be. The plan give so much more informations as I thought and the interpretive documents by Peter Coward are almost frightening with their detailling. But I want to create a really really good model - so I will look and be grateful for every kind of help :) I will NOT put sails on it as I think it's not necessary.
Cheerio
Max
Max - How much detail you want to add is your choice - the  plans are excellent & show plenty of detail. Not every detail is in the kit - you may need to scratch build some of it.  Do not hesitate to contact Pete - he is a great help if you get stuck on something. He is on this forum as piratepete007.  I built my ship without the help,as I didn`t even have a computer when I built it,so I struggled with a few things.
Regards,Mark
current build - HMS Vanguard - Model Shipways
Hello mates and friends,
now some pics of the kit and its content. There is a lot of timber - seems to be top quality - some lasercut parts - frames, decks, keel - and a lot of stuff from block, yarn, canons up to any kind of decoration. There are NO prepared parts - you have to create everything by your own. 12 sheets of plans (including sail instructions, but no material for sails), a small booklet, a CD-Rom with additional advives. Thats all. I am looking forward to start and will begin with the construction of  itemsd like bollards, canons etc. After this I will start the hull's construction.
Cheerio
Max
Edited by maggsl_01
This is a very nice kit. You can see the quality of the wood and the other parts like the cannons, anchors and metalparts are allready black!
I will follow this build and this is a kit on my wishlist!
good luck sir!
Peter
Hello again...
I did the first step - I startet with a dry-fit test of the keel and frames. The first test is excellent - there is NO further work to do on the frames, the material (frames: 5mm plywoob, keel: 10mm plywood) is extreme good quality. Everything fits perfect, just clean the parts an prepare it for the later planking. If the rest of the kit - esp decks - has the same quality it will be a fun to construct this ship. Although the material is quite thick I will build in some cell strengtheners between the frames. The model will be at last almost 100 cm long, so any additional stability is good, as Pete recommends to do.
Just a few pic are attached to show the very first step - not any clue used.
Cheerio
Max
My comment here is not intended to denigrate the overall quality of the kit, but for the amount of money such kits cost it would be nice if they could add another half-dozen frames to the hull structure -- it would make getting the proper form much easier. Anyways, thanks for the unboxing!
Hello friends and mates,
a small update to my FW. I started to construct the hull and all went good so far. The frames were excellent precut, almost no further work had to be done as the usual. Nevertheless I was surprised that the notches in the frames for the stringers are not as exact as they should and of course could be. There is quite a lot to work with this notches to get the stringers so tight and straight that they will fulfill their job and fix the decks.
Oh... the decks...  another disappointing expierence. Although I controlled the precut notches they did not work properly. I had to widen all notches to get the battery deck fitting on the frames. I did not expect such a bad preparation by Euro Model...  It's not a challenge you can't win, but in my opinion it could have been done better. At least  all is ok and works fine. I glued the battery deck in its place and later I will plank the deck partial, were it can be seen from the main deck.
Thank you for your attention - and as usual: some pics show the progress so far.
Cheerio
Max
Hi Max - maybe a little late now,but what I did was I used the notches in the decks to line up the frames before glueing the frames in place. I set all the decks in place,then added glue to the frames at the keel former. After the glue had set,the decks were removed. The deck notches needed very little adjustment that way & the frames were good & square also.
Hi Mark
just found the gallery pics from your FW. I see you painted all decorations in gold. I was thinking about to paint them in a wooden brwon color and a kind of bronze. I will try both and compare... but this is future :) At the moment I plank the battery deck where it's visible through the gratings and along the guns place. I will also use maple for the main decks and not the provided walnut. I don't like the dark color for the decks. I hope in some years my FW will be a s beautiful as yours... btw - you built a flat transom?
regards
Max
Yes,my transom is a bit flat - it was built long before there was a forum like this & I had a little trouble interpreting the plans,so many errors were made:(.  Painting everything gold is probably incorrect also,but I didn`t know any better back then.
Hi mates and friends
another update: I planked the battery deck where it may be visible through the gratings. I used maple strips as Mr Moonfeld says the decks where planked with light wood. The provided walnut seems to be too dark for deck planking. You can see the size relations of the cannons to the deck in the attached pics. All good so far - just thinking about the Derfflinger by Euro Model and the Royal William... Got another seven years to get retired :)
Cheerio
Max
Hello again
time for an update (I am in vacation from mid Dec to mid Jan - so I have time enough for my shipyard :) ) Working on the stern. Up to now all works quite easy and good. As piratepete says in the interpretive document you have to make a major decision - curved transom or flat transom. The parts provided are made for a flat transom. It's quite difficult to bend the plywood and the supporting pieces of the stern construction. I decided to take the way to the flat transom. It's my interpretation - and so it's ok to me.
Nevertheless there is a lot of sanding and cutting off to do - but the plans are so good that you understand all - as soon as you have understood the plans :) But nothing is a problem just a very calm and contemplative way to the final ship.
As usual some pics in the attachement.
Cheerio
Max
Hello mates,
after the holidays a little update about my work on the FW. A mentioned before I completely renewed the stingers (except the already installed battery deck). It's quite a lot of fine tuning to do, but at least you get the stringers fitting. I was surprised - although this is my fifth built and I should be used to it -  that especially this detail work is so much relaxing. The more you understand the function of the parts you work with the more you become a part of the ship. I always feel like travelling in the time... often I listen to Youtube-Videos that tell me about the historic navy. I have prepared all decks for the later use, especially I fixed some supports on the lower side of the deck halves. This will give more stability to the decks - as I hope. The bow fillers - I changed the timber: I used balsa instead of the provided limewood - are in shape and all further preparations are done.
Next step is to create the guns on the battery deck. As this guns will no be seen later - just the barrels go through the ports - I will only make some basic work - gun carriage, wheels and the barrels. There is no need for rigging. Later for the visible guns on the main deck I will take more care for a detailled and historic correct impression. The interpretive documents by piratepete show a very good way to reach this goal.
The first planking will be the next challenge... I think I will start next week.
Cheerio
Max
Hi Max,
Will follow your build log with great interest and as you have already found out, this is a 'kit' that actively encourages your own input. My own writings on this build were deliberately detailed to enable the potential builder to select what direction they wished to take and were never intended to be totally prescriptive. All the best and please PM whenever you wish.
Pete
Hi Pete,
thank you. I know your interpretives and use them as you mentioned: I will take ideas from it but don't understand them as "rules to be followed". E.g. I build a flat transom and will sure do a lot of things quite different (as my skill is not 10+ 😂) But they give so much hints and tipps to come along with this wonderful kit. I enjoy every minute - even when the challenge is quite powerful :)
How did you solve the problem with the last gun before the stern? It has to be placed between frame 8 and 9 to be on the correct place according to the plan. I decided just to use the carriage without the wheel - thus the gun will fit into the place.
I will surely write whenever I come to a dead end :)
Best wishes from Germany, the "home" of the Friedrich Wilhelm zu Pferde...
Max
Max,
As regards the transom, most builders go for the flat transom rather than create a curvature and why not, its your build ? In my build, after soaking the supplied plywood in water for some time, screwing it down onto a prepared curved surface and then drying in a warm oven, I was able to surprise myself with a very useful curved surface for the transom. What I thought was an impossibility proved to be the opposite and again demonstrating each Euromodel kit is a surprising collection of little gems.
As regards the placement of the last gun between frames 8 & 9, your solution was my solution. Others have removed part of the frame to accommodate the full gun but that seems a pointless exercise as it will all be hidden. The bottom line is that the Euromodel drawings are incredibly detailed and you need to add or subtract what you want and just remember that this is not a true kit where the outcome is totally predictable and the end result the same as every one elses. It will, in many respects, be your interpretation creating your very own design.
Regards,
Pete
Hi Pete,
thank you - what you say is just the way I understand this kit. And this is just what it makes so exciting. It's not only glueing parts together and some day you have a model like any other modellers have. No - it's brainwork, it's thinking about solutions, it's improving your own skill, getting expierence.. and at least, as you say, create a model, not only assemble parts together.
Regards - Max
Hi Max, coming along really nicely.  Look at the size and shape of the stem on the FWZP!
I agree with you and Pete on Euromodel kits.  I'm currently working on the La Renommee, and the plans are so detailed you have the ability to choose along a long spectrum of whether to build the kit from the box to almost a scratch build to somewhere in between.  It's been fun and a great learning experience working on my kit so far.
Hello again
I was busy today and prepared the skeleton of FWZP for the first planking. Therefore I first decided to plank the entire battery deck. I had done this before just for the probably visible area below the opening in the main deck as I perhaps will leave one or two gratings opened. But at least I thought I have to plank the rest too. Its not visible and in this matter it would not care if planked or not. But I knew it - and thus I started to create a proper surface. Just a pity that the pattern of planking is not correct...
The first planking of the stern is done, also the last fine tuning on the bow, the stringers and the frames. I marked the correct position of the guns so I can cut off the ports later. I will have a break now til monday. Then I will probably start the first planking.
Cheerio
Max
Hello my friends,
it's time again for a little update. Of course I could not let the weekend pass by without some work on the FWZP. Due to the very bad weather - even the dogs did not want to take a long walk - I decided to start first planking of the hull. The provided material - limewood strips - is really excellent. It's very easy to bend the strips after a hot water bath, the timber is sliced very exactly and cut into 1.5/6mm strips. It's very comfort to work with it - I know kits with much more worse material.
I started at the gundeck level and will go to the keel and upwards to the lower level of the main deck at a first step. When I have finished this work I will sand and fill up some smaller gaps. After another sanding I will cut out the gun ports of the battery deck. After this a second layer along the inner side of the hull (battery deck) will follow. I do this for a maximum of stability and for a good fitting of the gunport sills.
As usually some pics in the attachement :)
Cheerio
Max
Hello my friends,
a few pics show the progress. I have finished the first half of the first step - the planking of the starboard side below the maindeck-level. I used a planer and sanding paper and some wooden filler. All in all it was a pleasure to plank the hull. I cannot see any problems so far. It is the fifth hull I plank so I've got some expierence with this job :)
Just look at the pics and you will see what I mean - it's a phantastic build. Next week I ill plank the portside, then I cut off the gunports and will do a second planking along the inner side of the gundeck.
Cheerio
Max
Edited by maggsl_01
Hello again my friends,
time for another update. I finished the first step of the first planking. The hull is planked below the main deck level on both sides, all is plane, filled (not so much necessary) and sanded.
I will prepare the battery deck now for the later insertion of the guns. Therefore I made two tools: First an adapter for the correct height of the gunports. The center of the barrels has to be 12 mm above the deck level - according to the plans. So I cut off a part of a strip, marked the middle line and made a hole exact 12 mm above the beginning of the strip. I had marked the center line of the guns before I started planking. This is the lower reference point. Here I fixed the adapters middle line and marked the barrel center point through the hole with a pencil. Then I used a pin to puncture the marking. That's all. Now I drilled a hole through the hull.
Now the pattern for the gunports were used. I cut off a piece of plywood with the correct measures (16mm x 18 mm), made a hole in the center and sticked a toothpick through. This toothpick fitted in the hole in the hull - and voila: I could line the gunport along the pattern. Now the gunports will be at the exact height following the curvature of the deck with the correct dimension.
I will cut off the 20 gunports of the battery deck, mount the inner second planking for more stability and a good fitting of the gunport sills.
As usual some pics are attached.
Cheerio
Max
I too am working on a model of Sir Frederich Wilhelm. Started around 2000 and I am still on the hull and decks. The model is from a kit made in Italy By  Carta Augusto, Laboratorio di Modellismo Navale, Cagliari.
The documentation included in the kit consisted of four line drawings, with very little annotation, no dimensions other than the drawings were “drawn to scale”.  The drawings might more appropriately be called sketches when it comes to accuracy, detail on the rigging, ornamentation, or actual construction.  I have been building to photos other models of this ship found on line and the book: "Risse von Schiffe" contained drawings with more detail of the frigate, but again no dimensions.  The 1:100 drawings included in the book are a reconstruction from a painting by the "well known dutch painter Lieve Verschuier  and other contemporary drawings and paintings.” This book was borrowed from a library in Norway? by my city library at my request.  I am reluctant to start a build log because I feel I have taken so many liberties with the design.  Lack of better documentation and looking at the variety of designs exhibited by other models of this same ship lead me to believe that I am not the only one to encounter the problem.  Very interested in seeing your solution to constructing things like hatch gratings, bow rails, stern counter, and especially the Quarter Gallery.
Hello my mates and merry friends,
another little update. I finished the gunport cutting, "second" first planking an other preparations of the hull to start the second part of the first planking - upwards from the maindeck level. I ordered some additional timber - 1.5/6mm walnut - for the gunport sills. I tried to use 2mm or 1 mm - both dimensions did not make a good solution. 1.5 is perfect. I will not paint the sills or the gunports but I will use the natural color.
Second was to prepare the stem post and false keel. Both was good to be done, the stem post got its wholes and a little modification to give the figurehead a proper fitting. You have to cut off some timber to make the lion roar - but all is within a acceptable tolerance. The bowsprit sits perfect on his knee and all further preparations could be done very well. Its a lot of sanding and fine fine tuning. But thats why we all build ships, isn't it? At least I fixed the false keel with four screws and a lot of joiner's glue. I will remove the screws later.
I am very pleased with this kit so far. As usual some pics... the figurehead has not been glued yet :)
Cheerio
Max
Hi my friendss,
it's time for a new update. I am sad to tell you that I have nothing to ask, nothing to critizise - everything goes so well. It's just a wonderful build that has its challenges but no problems so far. The planking goes step by step, all fits and with the usual work on a wooden ship you will get a great model. I strengthened the hull with a second layer. Primary I wanted to do this only along the gunports but I decided to stabilize the whole hull. Next step is to plank the portside too and prepare it with the gunports and further features. Then a little bit sanding and very few filling. Then I will mark the hull with the essential lines according to the plans so I will get a well shaped hull at least. It's amazing to watch the progress.
Thank you for your attention - and please don't hesitate to watch the pictures.
Cheerio
Max
