Cheers guys, much appreciated. Now I'm taking a little-big detour, because I decided to scratch-build a small pinnace, about 110 mm long. I'm using bulkheads on a keel. They will provide a foundation for planks and then they will be removed and substituted with "real" frames, or at least I hope that this will work.
1st build - HMS Race Horse (Sergal)
Current build - HMS Fly (Victory/Amati)
Hi Vitus
Nice work on the pinnace. I really look forward to it's progress. I did something like this years ago for some whaling boats and ended up triple planking the things. Two layers on the outside before removing the bulkheads and then a third internal layer - all with the same sized planks as you are using. It is fiddly but the results can be really good. I'll send you a picture of the outcome by PM rather than place it here and confuse your posts. The third internal layer really helps and you can gently sand it and the outer layers to create a very exact boat.
Cheers
Alistair
Cheers
Alistair
Current Build -
Cheers guys, I'll do just one layer, that should be just enough. I don't see how I would be able to make a layer on the inside.
I think that the crude hull turned out quite good for my first attempt. Now it is time to sand it, cover the pin holes and finish the fittings
Edited by vths
Beautiful job on the pinnace, Vitus, well done indeed!
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
A superb boat Vitus - I won't bother to show you my efforts! I really like the clinker planking. Well done I look forward to seeing it finished.
Cheers
Alistair
Cheers
Alistair
Current Build -
Cheers, ZyXuz.
Now I'm creating the main wales using simple anchor stock planking. Planks are 110 mm long with full width in the middle and half at both ends and they are shifted like the rest of the hull planks. The wales will be painted black, but their pattern should show anyway.
Hello everyone, I've got a small update. Just finished the main wales and painted them black, now it is time for the little ones above.
Doing this I realized my previous mistake. The main wales are just thick planks, not another layer, which means that I could not follow the plan precisely, because then they would be overlapping the planks below. So, note to self, next time begin the second planking layer with main wales and follow their lines correctly. Now I had to choose the lesser evil - slightly wrong shape, but no overlapping, which would look just terrible in my opinion.
It is also almost time to chose the colour for decorations' background. Ochre would create poor contrast, red is used in the interior, green is just ugly and blue is used too often. I'm thinking about plain white, is that possible (i.e. historically plausible)?
Edited by vths
The hull looks very nice Vitus :)
How you colour the topsides is down to personal choice, but the official colour in the British Navy was Black, although in practice there were variations, predominently shades of blue and red, particularly on contemporary models.
It really comes down to aesthetics and what looks best to your eye; personally I would stay away from white, perhaps a little too stark against the dark wood, and probably the least authentic of colour choices. You also need to consider how the brass etch decoration will look and how you intend to colour that.
Against the hull colour you have I would go for either Dark Blue or Black, but that's just my  thought.
Cheers,
B.E.
Thanks B.E., black topsides seem reasonable, at least the hull won't look like a Christmas tree (or some medieval ships :). Then I will probably go for ochre decorations, but are the brass pieces possible to paint well with water-based Jotika Admiralty Paints? I don't want to see the paint peeling off.
To paint the decorations and brass fittings it is best to key the parts with acid etch (primer). It will give you a good surface to paint and unless you are heavy handling the painted parts, you should not get any chips.
Edited by miketherock
Built: Bounty, Lady Nelson, Endeavour, Granardo.
Finishing, HMS Fly, Victory, another Bounty
Want to build, Snake, Vanguard, Aggamemnon,
I used enamels and artists oils to colour the etch after applying an etch primer.
Humbrol 81 (pale yellow) was used as a base colour, this along with the primer was applied before I removed the decoration from the fret.
Once in place on the model I applied the Artists oils using a fine pointed brush
For the highlights I used soft mixing white with a touch of Yellow ochre, and for the shading Raw Umber mixed with Indian Red and toned down with white.
Both mixes thinned with distilled turpentine to quite a thin consistency.
B.E.
 miketherock, BE: Looks like a lot of painting and an opportunity to experiment. Thanks.
Anyway, almost finished the topsides, so now it's time to treenail the hull. A gentle press of a sharpened needle and a coat of clear varnish seems to do the job just fine, but I will have to create a template to place those nails evenly.
Edited by vths
Very crisp work Vitus - great. The alignment of your nails looks spot on. The black is an interesting choice but looks really sharp. Look forward to more.
Cheers
Alistair
Cheers
Alistair
Current Build -
Wonderful job Vitus! The hull is magnificent!  :)
Padeen (Adeline)
Thanks guys. Now I have a real challenge in front of me - creating the quarter badges (Alistair, thanks again for the plans). The supplied cast metal pieces are not great, so I decided to make my own. The first attempt includes modurit, which is a kind of clay that is hardened in an oven or boiling water.
Now I have to decide whether it is good enough and then it will be necessary to create windows. Those will be simply made of thin wooden strips.
That looks pretty good to me Vitus. Perhaps protrudes a little far from the hull though? You can get the PE brass window frames from Pegasus - I ordered mine through Chris Watton. They would be very fiddly to make in wood strip but it looks like you have the skills required.
Cheers
Alistair
Cheers
Alistair
Current Build -
Nicely formed Vitus, the pattern looks good but I would agree with Alistair the canted quarter badges only protruded a little way out from the hull.
David Antscherl makes the point in Vol 11 of tffm that the lower stool is shaped that it protrudes no further from the ships side than the Quarter pieces, (ie the stern piece on the model) and comments that many modern models show badges that project to far. A heavy sea could carry such a badge away.
B.E.
Edited by Blue Ensign
Hi Vitus
Have measured my badge and reckon the maximum projection from the hull will be about 5mm at the centre, perhaps less when I shape the junction between the two. That feels about right to me but this is just guessing...
Cheers
Alistair
Cheers
Alistair
Current Build -
Thanks alot guys for the info. The pieces are about 8 mm at their thickest point and I was wondering, whether that is not too much, but I found nothing on this topic. Then perhaps instead of clay I will simply use a piece of wood, with a maximum of 5 mm you say?
B.E.> Antscherl speaks about the lower piece of the badge, but what about the top part? Should that be a bit more "massive" or the same?
By the "stern piece" you mean the stern fascia plywood part with five windows? This one protrudes about 8 mm from the ship side, but in the narrowest point of the ship, so if I'm getting this right, it should be like this. In such case the badge should be no more than 3 mm thick.
And my last question, what about the window itself? The badge has one big window and two narrow at its sides. Should there be appropriate openings in the main hull for all of these (as you can see, now I have just the one big) or not?
If I recall correctly, I made mine to stick out about 5-6mm, just a little bit inside the edge of the stern fascia.
As for the hull opening, it should be just for the main central window.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
