good evening everyone
having taken the bowsprit as far as i can for now the hulls is again being added to
fwd liferatfs
better than the instructions and look ok
IMG_9785.thumb.JPG.05b7296fcaf93d7141bd3e8112ffe741.JPGIMG_9786.thumb.JPG.d28723443e0877c6bef4d8703332a34b.JPG
after spare anchors
i decided to pin these into position and make them look like they are fittedIMG_9787.thumb.JPG.e9b903aea7b1f1de9b8a179bbc228492.JPGIMG_9788.thumb.JPG.58cdf5008d5a57d45d3c2d5cd06e47d0.JPGIMG_9789.thumb.JPG.3af58e89926a3f86f694d20bf34d0b5c.JPGIMG_9790.thumb.JPG.86fd8d4c0f91f2f639f54e4341394bae.JPGIMG_9793.thumb.JPG.f41d7cb7dae2a504ae4b147869845288.JPGIMG_9795.thumb.JPG.20865851206614ec51b9e53a31521210.JPG
when i have finished adding everything i will then secure the rail to close the gap that can be seen
and now the side entry hatches
there are four of these and have a pair of doors, the intention at present are to have one set one on each side
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That is looking so nice Kevin.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
ladders
i am trying very hard to make things better than the kit and my next mission is the ladders
the instructions will have you build it all as one set x 4, glued to the side with a couple of metal strips to suggest supports well this is how i am going about it
not my photo
1826490418_Amerigo_Vespucci_ship_in_Haifa_(26)(1).thumb.jpg.e55da85042179971c849f6c346345333.jpg
it is infact a pair of ladders and when not in use are folded against the ships side (Not my photo)
i removed the brass fittings as they are all wrong, just so very wrong
matched the top platform in position and pinned it so i can remove it at any time, the pin also serves the purpose of being a runner to allow the supports below movement when the platform is folded flat
IMG_9810.thumb.JPG.3b43244262700d59096a26a9eba63240.JPGIMG_9811.thumb.JPG.3e37466f1eb62ca4fc2c2e65b834e1f4.JPGIMG_9812.thumb.JPG.a1e8ecc4ea2f5b1af4b99022830ddaeb.JPGIMG_9813.thumb.JPG.9625f50fa9ef70cba86166305019de6b.JPGIMG_9815.thumb.JPG.40d557b19b5c4ff7c2e5e196e959636f.JPG
i made a couple of support bars and located them against the hull
IMG_9816.thumb.JPG.27dd9e1fcb0e993bc774f5f69f7fdb88.JPGIMG_9817.thumb.JPG.2e48242183eb77bce04822c7c84a3ac3.JPGIMG_9818.thumb.JPG.42936928e5c8747566e23fad6e6d1c39.JPGIMG_9819.thumb.JPG.7a2e6636fc321cbc45c87f2ced31ada8.JPGIMG_9820.thumb.JPG.c4bf64e3c200b421b4879015de9cd92f.JPG
a piece of brass rod made up to take the ladder, which is not fixed as per instructions but stands on top of the middle platform
the middle platform is being fitted the same as the higher one
IMG_9821.thumb.JPG.6574ff78f9ac30873a5bc601294badff.JPGIMG_9822.thumb.JPG.f6a1a438309d83b3d011c78a80475f9b.JPGIMG_9823.thumb.JPG.f71b60f324814455173edfed7579198b.JPGIMG_9824.thumb.JPG.189be12ea0767a199f30911ee2cea1e8.JPG
another ladder to go in and lot of support fittings to design and make
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
9 hours ago, gjdale said:
Nicely done Kevin.
Thank you Grant
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
3 hours ago, yvesvidal said:
There is so much complexity on these transitional ships (between sails and steam). I admire your work and dedication, Kevin.
Yves
Thank you Yves that's a real compliment from you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
ladders continued
i made up a second set of platform supports, but had to reposition the lower platform slightly to allow the upper ladder to rest on it
IMG_9825.thumb.JPG.67a73ca8dbc8fab7d801deec74e2528b.JPGIMG_9826.thumb.JPG.c357bca1c37d08ca18a5d5125b1c7eb1.JPGIMG_9827.thumb.JPG.824cc405fa44df4e7a37989cb551a693.JPG
the lower ladder is lowered and raised by a block and tackle derrick so a couple of brackets made up to support it
IMG_9828.thumb.JPG.ef53fcad401a3744f2b64cd8c12ae967.JPGIMG_9829.thumb.JPG.4a74b4daded24d8a4ea819ff75d80c9a.JPGIMG_9830.thumb.JPG.d398f11244564289dd63d1aef0a10aa6.JPG
made up a chain spreader
IMG_9831.thumb.JPG.7d672321fc6abc0a46f80a415bd78a50.JPGIMG_9832.thumb.JPG.b3ecd9d1559c4d1ad4dc2e6ff561d441.JPGIMG_9833.thumb.JPG.404b983830c9eac02f6e53cacd719c2d.JPG
the chains are to long
and blocks oversized
and the spreader could do with being not quite so wide
or i may make the platforms a little wider, which might be the best option
IMG_9834.thumb.JPG.83dd04f9d2cfd2d3ecfead934b32af23.JPGIMG_9835.thumb.JPG.8a5d45f825b8ef681701bbafa4e3f1c6.JPG
a messy desk tonight
IMG_9839.thumb.JPG.f0a8c55cf61558ecc9cee0cc0840afc0.JPGIMG_9840.thumb.JPG.15ed6eee61c1bd26f84982ba088948ea.JPGIMG_9841.thumb.JPG.202c5f17af45794ef0c83b73c2a859da.JPGIMG_9842.thumb.JPG.3b7c1bb3c098a69d1fc703854de15243.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Nicely done, Kevin.
Thank you Keith
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
must admit I never realised just how much extra work i have given my self
i am still working on the first of 4 accommodation ladders, and every time i look at @schiffebastler build i see more detail to be added.
IMG_9848.thumb.JPG.b6f2cd172c3cc2917e933f150230f1b7.JPGIMG_9851.thumb.JPG.56abaaab12f2f50f3f2a74ca3e4d63a6.JPGIMG_9852.thumb.JPG.f9381b63368ad81ca7f81d64567fcae1.JPGIMG_9853.thumb.JPG.45316fb17fe1a725a9c41b8d866904f3.JPGIMG_9854.thumb.JPG.b53d23a31dfb1b83c48ca382af6945fb.JPGIMG_9855.thumb.JPG.eb7e834bf961ed7181196440f386a42d.JPGIMG_9856.thumb.JPG.aa600d729dc93add68839f60ab2f1d58.JPGIMG_9857.thumb.JPG.59be3cd7fdfad5f7b15371f26e25ca97.JPGIMG_9858.thumb.JPG.e04fe6f4e57af7f1b4156842310d1424.JPGIMG_9859.thumb.JPG.aef0d3e7e09ba7671d101caf60b62310.JPGIMG_9860.thumb.JPG.8ace4aa245a4733c5c0e6e9119b0e3eb.JPGIMG_9861.thumb.JPG.8da553e696448948e6645003f5df436c.JPGIMG_9862.thumb.JPG.311216899d65173c72912d4dc525a981.JPG
i was asking about how to cut brass tubing into small sections to make the Stanchion supports and found out if i put small lengths into a rotary drill i can score the lenghts quite accurately with a x-acto blade
IMG_9849.thumb.JPG.9ec987e555b21c86a1ce9e7bde538f20.JPGIMG_9850.thumb.JPG.a125878412a539a6816e2ca599c4ec82.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
It might be a lot of extra work Kevin, but it’s worth it - that is looking really good!
good afternoon everyone
still a few fittings to sort, but i now have possibly a ladder im happy with,amother 3 to go but will all be slighly different in the way they are rigged
if in the long term i do make it again, i will use the original idea of more brass, but for now this is staying
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That looks amazing! Did you use soldering wire for the cage going to the ladders?
Good evening and than you, yes i did,  all metal is now being soldered, lol i should get quite good by the end of this build
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
6 hours ago, Robp1025 said:
I see that lol. It's an amazing build though and love learning new tricks and tips from vets like you :)
lol, easy on the vets
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
lol thinking hard about re-naming her, the green is just not working for people, any suggestions?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
16 minutes ago, Robp1025 said:
Is green not the color its suppose to have?? If your gonna rename maybe something with jade cause that is what the green makes me think of
def no green on the AV  never has been in the 90 years she has been on the water
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
How about   "The Black Merchant"
OC.
Current builds
Completed works.
OC.
i like that, the green merchant sound a bit eco frienfly
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I thought of that after  googling  the name  and this came  up  -  I quote  -
OC.
Amerigo Vespucci
Amerigo Vespucci was an Italian-born merchant, explorer, and navigator from the Republic of Florence, from whose name the term "America" is derived. He became a Castillian citizen in 1505. Between 1497 and 1504, Vespucci participated in at least two voyages of the Age of Discovery, first on behalf of Spain and then for Portugal.Wikipedia
Current builds
Completed works.
felt like pants today, so not much achieved. might be due to 2nd covid jab i had yesterday,
but i did get some of the after port side accommodation ladder made up
and changed the build title pending a name change
at present my fancied re-name is TS Nivek Sira (im sure most of you will work that one out)
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
"Training Ship Beautiful Journey" ? If that's it, it's a beautiful name and a vessel we should all hope to travel aboard.
well most of the port side accommodation ladders are in, another couple of fittings to sort out and then paint then in relevant black or white
im struggling with the rung ladders, making them out off paper staples, getting them to look tidy and inline and as for the white painting to do the touch ups
i may take the white one back out redrill and paint them before placing on the hull
IMG_9886.thumb.JPG.2f39643cde00998a2f4c038d1f7257d0.JPGIMG_9887.thumb.JPG.8bcc52d76c172695347b058a8c1d959e.JPGIMG_9888.thumb.JPG.6568cbfa2164feb1515994e9e56fb9ce.JPGIMG_9889.thumb.JPG.06122ebca5ff5ce03cfc6833fae30a5a.JPGIMG_9891.thumb.JPG.26bcc6ad420a374ee2e463a0dd730735.JPGIMG_9893.thumb.JPG.526d9dcd129e040fb3111baa34cac55a.JPGIMG_9894.thumb.JPG.ce0f1867600d44ce411e2636118f056d.JPGIMG_9896.thumb.JPG.757d270b9e301d79e1adceedf94c6c56.JPGIMG_9897.thumb.JPG.4a5f1d5b4f85d59adc325f57989c5831.JPGIMG_9898.thumb.JPG.193d80f79c61708f88bc1bd9a34a657e.JPGIMG_9899.thumb.JPG.4e488bd072f57154b139db51858fede5.JPGIMG_9900.thumb.JPG.c3a9e3a043ea26ca3703f20a4c27c9ae.JPGIMG_9901.thumb.JPG.3f1cfa134b8f34b13a256b319e13dac5.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
most of the two lowered stbd side accommodation ladders are complete now, hope to finish them tomorrow
as the port side was a test, these went together much better and faster and in my eyes look better
 made a set of jigs to ensure the platform supports were the same size,
lol its the danger time when i say to myself is it time for a redo of the port side
IMG_9909.thumb.JPG.12101c5c5b5cad69fd1e1623d73a6e4f.JPGIMG_9911.thumb.JPG.b49f9af6704e5d2da4ac84d1008aeec9.JPGIMG_9914.thumb.JPG.301db80f77a3c2734cc78c7e29645aeb.JPGIMG_9916.thumb.JPG.c8e32c2be6c595403a860aba9b37936d.JPGIMG_9922.thumb.JPG.a04a003d5a71441f7671795fea560428.JPGIMG_9925.thumb.JPG.934aa3dd870ba576b3912bac928678d7.JPGIMG_9926.thumb.JPG.1355d875dfaf2a215e554133be0c4e7f.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
She is looking splendid mate,     ingenuity  is the key to science  and imagination key to artistry.
OC.
Current builds
Completed works.
OC.
thank you OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
