PT 105 by mog - FINISHED - Dumas - 1:30 scale
WOW MOG your work and effort at detail are really shining!:D
Your mast may possibly be the crown jewel of your build so far. Congratulations!:champagne-2:
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Share on other sites
Lanyard pullies for the mast and start of cockpit rework
Current Build:   Not a ship
Completed Builds:   Mississippi River Boat OcCre 1:80
                                Bluenose, Model Shipways 1:48
                                Rattlesnake, Model Shipways 1:64
                                     Dumas # 1233  PT Boat,  Wood, 1:30
                                 1914-1918 US Army Mule drawn Ambulance 1:16
Link to comment
While waiting for supplies,   worked on the wiring  plugs  for the Nav horn, port spotlight bracket. There very small, hard to shape, but I think they will add to the effect, when the cables are connected, also added the mounting brackets for the , cabin  vents and running lights. Test fitted the  reworked 20mm base
Link to comment
 Made some progress in in the odds & ends areas   Life ring with rope grab, added the mast light cable , the mast is aluminium & brass so it will take a few coats to cover,  or I might just leave the used look, reworked the  training gear cranks on the day room cabin, added the port search light cable,  placed items on the engine hatch cover & gave a coat of paint,   missing the engine hatch ( work in progress)
Link to comment
Thanks to Jeff D  at pt103.com for the advise on the hatch ladders, made a simple jig for soldering , shaped and framed the deck hatch opening
Link to comment
Added the foot rails, had to soak & heat bend them into place, always run the risk of snapping or splintering long single pieces when shaping the curve. luckily I tooi it slow and easy turned out  the way it should
Link to comment
mm2.thumb.JPG.2bc654840846da3892dd47043f59b90d.JPG20mm.thumb.JPG.09231bbce47dad27d5657ea535db9147.JPG20mm2.thumb.JPG.b0d05734b90345fc7f764b9500eaa2a2.JPGmm1.thumb.JPG.c8e9e7d03af6c20cee0fce7803169e0e.JPG Finished the 20mm  Oerlikon, pretty happy with it for the first attempt
Link to comment
Torpedo tube training gear, rope locker hatch
Torpedo tube training gear  permits the tubes to be trained inboard so that no part of the tube structure extends over the rail. When action is expected, the tubes are trained outboard, by hand.
Link to comment
 50 Cal machine gun turrets ,and foot stands , work in progress
Link to comment
Torpedo tubs cut ready to fabricate
Link to comment
Test fitting the control panel
Link to comment
Starting to show a little progress , attempting to scratch build the torpedo tubes, learning from plans & pictures . its fun but trying to get it right is slow work.
fit tested parts  of the of the superstructure, and cleaned up the control panel
Link to comment
hey there!........just poked in to see how you've progressed :)   you've come a long way........some really nice detail!   the 20mm looks awesome...can't wait to see the 50's!   decking looks nice too....see  your fitting the smalls bit on it.   dash looks great as well.........super nice job! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
ok..........I bit the bullet!  went to HobbyTown today and bought the kit! :ph34r:   I recalled the kit being in a long squared cardboard box though.......this one is in a long flatish white cardboard box.   it even has a production date on it....5/2/18.  they must have sold it and replaced it with another.  it just saved me from asking if it was a complete kit  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
First stage building the components for the torpedo tubes, ready to be cleaned up. These components fit on the top surface of the tubes. Still have to build the Aft holding cradles , undercarriage, and another set of training gears. Overall when the tubes are completed I think I will have fabricated  about 150 individual parts,  every thing has to be built times 4 which makes slow, hair pulling progress trying to get each set to match, which is almost impossible , so I idea is get them close , with so many  handmade repetitive parts you would go nuts getting perfect exact matches. Pressing on
Link to comment
really nice job on the sub assemblies Mike :)   as I mentioned,  the torpedo tube in my kit are wood dowels.  I think I'll see what I got for brass tube.......if not,  I will get some ;)   it's nice to get a glimpse of what I'm up against  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I used steel  tubes,  brass would have been better , but hade the steel on hand.
Link to comment
The early stages of fabrication on the AFT torpedo turntable cradle mounts  still 5 more parts to add to each, more work to do.  AFT turntable base complete ready to prime
Link to comment
Very nice work
The same thing would have cost $270 if you had gotten them from Model Monkey/Shapeways! Sometimes it is hard to understand why after market venders even offer an item when it costs more than twice the cost of the model!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
I think the answer is simply: "Because they can".   I understand that drawings, etc. take time and there's a limited market but I too have a hard time understanding some of the pricing.
Link to comment
Thanks guys,  I do use some 3D parts mainly for smaller things,  & yes its expensive , however  done with Shapeways , 1 the cost & 2 they print what is sent to them not matter how good the design is  the quality is on them and lately there has been far to many question about there work  so now    if I need anything  printed, like  custom figures , helmets, life jackets , gun mounts  etc.....I have a supplier in Spain  who prints his own items from resin at  a fraction of the cost,  high quality & he will custom it to exactly what you want.  The Virus has slowed  it down  but quality made to my needs for a great price  works for me,    I already have  a good chunk of money in this build  so  any good deal helps . I try to make as many   of the parts as I can,  ok they don't look a clean as pre made , but its my work so its in my hands  however  sometimes there are parts that are way way above my skill level , on the  current torpedo tube section which I have over a month of time invested  the breech door assembly will be 3D , its the only tube part that is  too  detailed & to small for me to do properly.  anyway  its all getting there  if it was easy  everyone would do it.    Mike
Link to comment
Finished fabricating the torpedo mounts suspension. I don’t like using aluminium because it doesn’t  solder with getting into a painful process, so it has to be glued, which it equally does not like, anyway it got there in the end,
Link to comment
Torpedo tube training gear & drive screws
Link to comment
my admiral is big  on that.........."you can make that".....she seems to think I can make anything
news blip....someone hit our house!  they took out the bulkhead {doghouse} for our cellar!  not much more info other than they got the guy already :)  jee,..........all we need now is a dumpster fire! :ph34r:
your making it hard on me,  you know.........now I gotta make stuff like that!.....     nice job.......not even aftermarket can duplicate the effort  ;)   I'm not big on the resin stuff for that reason.......true that some of it can enhance the model,  but in other cases,  the kit part wins out.  you just need to research to see what would be better.   the more you dabble with fabrication,  the better your gonna get ;)    keep it up!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Fabricated torpedo tube brackets and locks.   Took allot of time but I’m happy with the result.
Link to comment
Torpedo tubes fabrication coming along,  looking at maybe  2 more weeks to complete
Link to comment
Outstanding craftsmanship Mog. Those are possibly the most realistic torpedo tubes I have ever seen, at any scale!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Test fitting the tubes ,  added the  detonator housing
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
