Look what arrived this morning  - :dancetl6:
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Great !  Pulling up a chair front and center!
Jack
Current buildUS Constellation
Welcome jack.
OC.
Current builds
Completed works.
2 hours ago, Edwardkenway said:
Count me in OC!!
More than welcome.
OC.
Current builds
Completed works.
22 minutes ago, Canute said:
Sign me up, OC. I'll bring the popcorn, too.
Most welcome Ken.
OC.
Current builds
Completed works.
Great news, OC.   I'm pulling up a chair also.
No chair for me. I can't sit in them for more than an hour or two anymore, but I will be in and out.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Get one of those garden hammocks   you could share it with lou.
OC.
Current builds
Completed works.
Nah... I've heard that if he falls asleep he snores.
I heard  - he pinches pop corn  - oh and watch your  pop, but I wont tell  Lou.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Don't drink pop very often. Don't snore at all, as SHE would kill me if I did, (She sometimes snores though, :D) Can't sleep more than an hour or two at a time anyway without waking up and shifting from one side to the other. BUT I HAVE slept in Hammocks more than once. You have to do some special things to stay warm while camping but some of my best nights sleeping have been while hiking/camping and sleeping in a hammock! Those crewmen had it pretty good in the old days when they slept in hammocks and the officers were stuck in bunks!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I might start this later today,   as I have reached a stall with Mossie  due to needing to Rattle can  but I will wait till  the risk of spray fumes  aggravating  the admiral.
So I thought as Acrylic bottle paints give off zero fumes, I should be able to start building this  and  plan to get to the Rattle can stage for the frame sprays  (with any luck  things might have settled down in a few months time).
OC.
Current builds
Completed works.
Ahh... late to the party, but, I see the main attraction hasn't arrived yet, just being introduced....
Grabbin a seat......
More than welcome.
OC.
Current builds
Completed works.
Evening all,    So as I said  - I have put  Mossie away in a box  and decided to start this,   first off  I looked over the spit-structions   page one called  for two  sub assemblies that are lower hull wall sections that have a few fittings attached to them - lever's,  covers and  bottles, these were glued done  then put aside, also  I cut away the two fuselage sides  - these needed the normal light tidy up and a pip cutting away,  there was a few moulding holes that I filled with plastic putty, this was then put aside to  set.
So I have made a start  - its a very very nice kit very good accuracy and quality  the dry fit join of the fuselages is excellent.
Sorry for the last pic  - didn't know it was oof  till after I took it.
OC.
Current builds
Completed works.
12 minutes ago, BLACK VIKING said:
Looking forward to this OC . Stay safe m8
Martyn
Thank you Martyn,   same with you and yours mate.
OC.
Current builds
Completed works.
Hi all   hope everyone is ok,     more work today  -  I continued with the cockpit sections, next off  was the framing  and a sub frame attached to it,   very precise placement was required but they  fell in to place well, I also drilled out a few  holes in the framing  and attached  one part of the PE  included in the kit.
Oh  - I also  sanded down the areas in the fuselage side where I had filled some of the injection pin  marks.
OC.
Current builds
Completed works.
Good day all,  I thought I would give a bit of back ground info  on the reason for me building this -  its about my late farther again,  as well as his service on bombers  he also worked on different versions of Spitfires  and  Hurricanes,  he actually started on these before  moving to heavier  aircraft  a year or so later.
So  - he  was based at a RAF base called  West Malling   (famous for its Battle of Britain use)   he was a Airframes and Engines fitter  and did various  jobs on both Spits and Hurricanes.
This is again a build in his memory.
OC.
Current builds
Completed works.
A bit more done  -  I brush painted the cockpit green  and flat alum  also the  fuselage  sides.
OC.
Current builds
Completed works.
OC.
Hi OC I used to live about 15 miles from West Malling when I was a kid and my uncle worked there during the war as a parachute packer . Small world.
 Martyn
 Martyn
In deed it is mate, my dad was there  between 43 and early 44, he then was moved to Norfolk  to work on bombers and stayed into the Fifties  where he worked on the first jet engines  and  also did some work in Oz   doing diss-assembly  of fighters to be crated up and returned back to the UK.
OC.
Current builds
Completed works.
Hi all,
Another good couple of hours,  I touched up the green then picked out  the Black fittings, then a few items in flat Alum,   then when dry  (with hairdryer)  I then ran a pencil to create some shading, next using white I I did some highlighting  then I dulled everything with some flat coat.
Next will be to build the seat.
OC.
Current builds
Completed works.
look'in good OC! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
4 minutes ago, popeye the sailor said:
look'in good OC! :)
Thank you kindly Denis,   I'm very impressed with the quality and accuracy of the moldings.
OC.
Current builds
Completed works.
Yes, the casting job is very nice.... looks to be a well thought out kit..... (and your better at dry brushing than I am) Good Job!
Quote:
Thanks EG,   I just use a wide brush  and make sure its almost dry  like a powder brush, then just light brushes over the details  keeping an eye on how its building up, then seal in with brushed on clear top coat.
OC.
Current builds
Completed works.
More work today -  next job inside the cockpit was to paint the floor assembly,   this was then shaded and dry brushed  for highlighting,  next was to attach the yoke and stearing columb, this again was  painted and weathered  then the floor was glued in place.
OC.
Current builds
Completed works.
