HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Hi,
By popular request, I start here with a buildlog from HMS Victory by Caldercraft.
Please don't be so strict with me if the one or the other is not so perfect. This is my first ship I am building.
I started doing it about a year and a half ago.
The bulkheads, the main keeland the middle gun deck are already glued together.20190316_144645.thumb.jpg.e4023beb939dac2ed056c2b7491cea5e.jpg20190316_144726.thumb.jpg.1f45ba8011db56c0bd1581477b269aa9.jpg
Here i painted it black and glued Filler Blocks in place20190317_160931.thumb.jpg.a8fab618661fa8111c9c86faba528c6c.jpg
Than i sanded it all
To assemble the gunport I built small screw clamps
I used small screws to keep the gunport 2 and 3 in position
Than i startet with hull planking
After sanding the first planking is finished
So that the buildlog is not too long today, I'm taking a break.
Cheers
Helli
You are a brave man taking this on for a first build, but your work looks simply amazing!
I am definitely following this one. :imNotWorthy:
Ongoing:
Hi,
Charter33
I've been reading your buildlog all the time and have copied a few things:wub:. Was pretty disappointed when you took a break for a year now. But now it goes on again:).
Thank you for the kind words
Copy all the ideas you like, a lot if them I picked up from here too!
My absence was not through choice, I assure you, but it really is good to be back at it.
Some interesting R/C aircraft in the background there.....
Cheers.
Hi,
After my break i start again with my Report. After sanding the first hull planking, i started the quarter gallery and the middle gun deck planking.
Since I liked it better not to lay the planks in one piece, I took over the dimensions from charter33
Then i broke the edges all around and laid the planks with a small gap.
I put a thread in the gap for the kafalterung.
Then i glued the side gallerie in place
When this is done i started whit the second hull planking
Then i started with lining the gunport20190503_175508.thumb.jpg.e502f13e00e873f5647325830105f79f.jpg
and mounted the wales
Planking the upper gun deck
When weathering, I rubbed ashes into wood with a small sponge.
Then sealed with clear varnish so that the ash can be drawn into the wood.
When everything is dry, sand until the desired effect is achieved.
I drilled the nails with a 0.4mm drill and I filled the holes with coal dust with a pencil.
Then I sealed everything with matt clear varnish. Think the result looks ok!
So that's it for today
Helli
Hi,
It continues with the planking of the inner bulark gunport pattern and the production of the other details from the upper gun deck
Now the cannons can be assembled.
For this I made a template with which I can drill the cannons at a 45 ° angle. Then I made a strap with a 1mm wire
Then the cannons are assembled
I had to make a small tool to bend the cannon axis bracket (by Charter 33)
Then I could start painting the hull.
And now the copper
To finish off the copper plates, I sanded back an L-profile made of plastic on one leg so that it just barely covered the copper plates
Then I drilled the holes for the dummy cannons. So that I can drill horizontally, I built an auxiliary device as shown in the picture
Helli
Edited by Helli
Helli,
Incredible work. Perhaps your first model ship, but obviously, not your first model.
This kit is sitting on my shelf, and as I am about to finally finish my current project, you are giving me the incentive to tackle this monster.
Your build log is only 5 days old, and I already have a lot of catching up to do.
I will be following along.
Exellent  work indeed   - you have chosen The referenece  kit  for HMS Victory  and what a superb start you have made on her.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hi,
My build is only 5 days old, but I've been building for a year and a half. Therefore, I actually do a fast forward to my current status.
I am currently in the rigging. But I have some problems that I have already solved in another thread. But more on that later.
Helli
Helli,
You didn't do all of this work in 5 days??? Your slacking off. Just kidding of course.
Your log caught my eye since it was evident that you would be downloading a ton of content in a short period of time to catch up to your year and a half building process. Getting all of that fresh content all at once is great for a viewer. That will definitely keep me checking in often.
And let me repeat.... your work is superb.
Hi Helli
Thank you for sharing that amazing build with us.
That's a very clever trick for attaching the breaching rope rings to the guns. And your work looks great, clean and precise.
Cheers
Peter
Hi,
Now i can start rigging the cannons. Seems to be almost endless but is fun
After I had finished rigging I started the details on the upper gun deck
The first thing i did was assemble the bilge pump
Then i assembled the stairs and the railing20190728_162047.thumb.jpg.fee0aff6ea066fec4c6f351965fb7365.jpg
Finally I sanded the skid beam support pillars square and glued it on deck
After everything was done, I started fitting the quarterdeck. The assembly of the sliding clamps was a bit tricky
The planking of the quarterdeck can begin20190803_200605.thumb.jpg.fa4e98a2a714a2cf8bad2114b0e3d619.jpg
I have cut off the bulkhead so that I can assemble the inner gunport patterns and planked it
Then I painted them20190816_004524.thumb.jpg.8798e3927559e0c58473feb9cf53c8f7.jpg
Forecastle breast beam
Bellhouse
Now all the details on the inner gunport
Assemble the copper profiles and the channels
In the channels I drilled a 1 mm hole and put in a brass pin with cut off the head.
So that i can mount the channels on the hull
Helli
Edited by Helli
Hi,
How can i remove the last 3 pictures and the big free space in the last post?
Helli
Hi Helli,
I've had this problem once as well. I think I solved it by clicking on edit, then deleting the pictures from the bank of imported photos at the bottom. I believe it was necessary to hover over the thumb nail picture for the X to appear. I'm no 'IT techy', but it might be worth a try.
Good luck - and a very nice build you have there!
Graham
Hi,
 The next work i had done was the assembling the beakhead bulkhead
Than i began with the bows
I painted and mounted the beakhead Pilaster
and beakhead doors and gunports
and finished the bows and mounted the forecastle carronade
The next was the shipweel, the binnacle and the main companionway
When that was done, the poop deck was assembled and planked
Than i assembled the Skylight and the flag lockers and glued in place
The next was the cat heads
Cheers
Helli
Hi,
At the stern gallery i put on the individual parts to convince myself of the fit
When i was satisfied i glued the parts in place
Then i sanded the fenders and chesstrees and glued it on their place
I made the black stripes between the windows from black cardboard
Now i painted the stern trophy of arms20191018_153532.thumb.jpg.0e9243705069032671271281e46d2c13.jpg
and mounted it
after that i was able to finish the side gallery
the next was the side entry port and the steps
When assembling the chainplates I saw that some of the length didn't fit
so I had to recreate them
Helli
Edited by Helli
very nice. very, very nice. you're doing a wonderful job.
keep up the great work.
mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
I love the Calder Craft kits, especially HMS Victory.  The feature I like is the raised fo'c'sle bulwarks, the Calder Craft kit being the only manufacturer that has done so.  Great job, so far!
Edited by Bill Morrison
Hi,
The gun port lids were numbered because they had to be individually adapted to the wales20191115_003922.thumb.jpg.8c3b0e3c2c2cbf0559c41149838c3b61.jpg
then the hinges were installed
afterward they were painted and the eyelet was installed
The figurehead were painted and glued into position. I think it's OK
here i milled the groove for the brass profile
I had to bend and solder a brass ring to prepare the anchors. Then the ring was wrapped with rope
the victory lettering was stuck in position. after that i started assembling the rudder
and here is the finished result20200124_013429.thumb.jpg.26feab14d5b68ec9f9a903f733bdc433.jpg
Now that the hull was reasonably finished I started with the masts
First I started with the bowsprit.
I have made all masts from five individual parts so that they cannot twist
That was it for today again
Helli
Edited by Helli
Hi,
The next work was mounted the bowsprit with lashing and bobstay
After that, the manufacture of the masts began
In order to assemble them, I had to make the hammock nettigs beforehand
Now I could start with the masts
The masts were painted and the details were attached
Now I could use a plumb line to glue them into position
I made the thimble myself on the lathe
Then the rigging started. For this I made myself a serving machine
After trying a few things it could start
Helli
Edited by Helli
