I said that I would start a log on this vessel if it looked like the hull is a keeper.   it was touch and go for a while there........but I must admit,  it came out quite well.   this is the Steingraber kit that JCT and I have been collaborating on.   he is finished with his model..........but of course,  me with my propensity for making a mountain out of a molehill,  have other ideas for this kit.  the kit is old.......I would say onwards of 50 years or so,  and this played a very large roll in how we came up with our hulls......the most important part of the model.   J did replicate some of his hull parts,  while I replicated most {if not all} of the hull parts for mine.  I even added a couple of parts to mine to complete areas that seemed to be missing something.  during this time,  I ran into a National Geographic article about the slave ship Clotilda,  which caused me to change the name of the ship I was modeling.  in our research,  we found that there was no slave ship called the Agillis........odd that this would be fictitious.   though fitting to do a model of a known slave vessel......the last of the slave vessels,  I was still drawn to the box art......I like the way it looked.   there were a few Briggs that were used as slave vessels,  but my thinking takes me away from that subject.  it's just a Brigg...the odd partis that I adopted the name.......seems as good as any,  since what I would name her would like be fictitious as well
the parts were terrible to cut out of the sheets.......this kit was not laser cut.  J seemed to have a better time of it than I was.......mine being mahogany sided plywood,  and his being blonde plywood.  I was fixing them like crazy,  cementing layers of basswood sheet to take the place of the delaminated mahogany.  my scroll saw was literally tearing them apart.
928581318_1.jpg.bbfd6805643ba2049beeb086178df20f.jpgyou can see the missing chunks of mahogany
798193242_2.jpg.ce7acbaf5ef1bfbf81950cfc1caf7604.jpgthe part 1A for the bow,  the modified part #10 with bulwark posts
1261687206_3.jpg.5652e780a83cade3d14775bfadd98104.jpgafter cutting out the keel part,  I removed these strips of mahogany from the cast off with my fingers!
106130716_1.jpg.8a634e73b516ef0106416c0fbf9fb0b5.jpgthe repaired parts of the hull frame.....the two parts 9A are also added parts
 in the end,  we both came up with viable hulls,  and we continued from there.   I was cleaning up the mess,  just about ready to toss these parts in the trash,  when my inner pack rat kicked in.  so much was done to preserve these parts.......it would be a shame not to give it the 'ole college try,  and create a second hull.   what the heck.........if it doesn't work....I get to see it burn :ph34r:
2116641837_2.jpg.4c2e2114a61a022fe2793490ea5daf1d.jpgand so starts the assembly of the second hull
I'm doing the Clotilda as a topsail schooner,  which will be void of the mast tops.  built as a Brigg,  the mast tops can be used.   I don't like the way these mast tops are shaped,  so their refabrication is in the future.   it must have been in the cards,  because I had traced the deck platform on a basswood sheet,  as well as a few of the other parts that required that thickness of wood.
the same method was used to create this hull frame,  as I did for the Clotilda,  running a straight strip of wood fore and aft,  and marking the centers on all of the bulkheads.
467422616_4.jpg.cc166bbfc70870bd9d2e793b9537ae78.jpg490196757_5.jpg.e33e6666721e4e875f01511af3857c95.jpg
the deck platform was cut out and notched..    I started this the end of February....I have a lot more to cover.  so not for anyone to think I'm Speedy Gonzales,  I'll give the dates as I go along,  until I get caught up.   I'll have more on her tomorrow :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 kits for the price of one, and no one outside MSW will know thew difference,
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
welcome Ed and Kevin :)   I hope you find this enjoyable.   it's a kit,  but it will have a lot of scratch building from here forward.  the build will follow the instructions,  but I want to add in a few aspects that the model doesn't have.   it has been a process getting the hull to this point........I'm very glad that it worked out.
what I've done here isn't new to me Kevin.........I've been replicating hulls for quite some time now.   when I remove the parts from the laser cut sheets,  I try my best to save them.  my only interest at this point are the hull parts,  since I have hardly any CAD skills.......I couldn't draw a hull blueprint if my life depended on it.  from here I trace the hull parts onto sheets of plywood and cut the parts out.   I also try not to use exact measurements from the kit.......I build the hull and scratch build from there....fitting them out as I want to.   for example........from the Mary Anne kit,  the M&M Fun Ship and the Trawler Syborn were cloned.   from the Boulogne Etaples kit,  the Andrea Gail and the Holiday Harbor fleet were cloned {although the harbor fleet has shrunk due to defections with the building of the Andrea Gail and the other fishing boat I'm building}.  the Midwest Lobster boat was also used to fill in the gap left by these defections,  cloning a better model of the Christmas Tree Boat.  in all of this,  I found that the idea of using the Boulogne Etaples hull for this subject was a bad idea,  but when I was assembling the hull frame,  I immediately thought of the Andrea Gail.......that idea was a very good one!  the Bluenose project isn't off the ground yet,  but from the Bluenose that I got from a friend,  two other hulls were cloned.  this will consist of three schooners....the Bluenose,  the Bluenose II,  and the America.  all three have basically the same hull construction,  but are outfitted differently.  they will all be at 1:65 scale and will sport sails.....that will be a heck of a lot of sewing,  btu I already have the Bluenose sails cut out and ready to sew.  I'd like to go larger,  like a fifth rate ship...or one of those large sailing ship that I can never afford,  but obtaining the parts panels from them is impossible {unless someone is willing to indulge my madness}.   I can buy and make the fittings,  but some of these kits are too rich for my blood.   there are a few other hulls that I'm working on,  but so far,  not enough to report or start a log about.  I'm constantly doing something........:ph34r:
as you read above Ed,  all this started out as an experiment,  to see if it could be done.  most folks will throw the instructions away after their model is built......I don't........not even the plastic models ;)    I've run into instances where a person puts out a shout,  because they've lost their instructions.   the Revell Cutty Sark is still the #1 model in which this is the case.   it's so popular,  that I posted the instruction sheets on one of the blog sites that I use.........the U.S.S. United States was the second one posted.   I mean....really,  once you buy the kit,  what becomes of the instructions after the fun is done?   JCT and I are based our models on the Topsail Schooner {of course his is finished}.....I'm still building the Clotilda.   I want to build the Brigg that the box art shows,  but I want to build it as an armed capable vessel,  perhaps a vessel that participated in the deterrence of the slave trade.   I think it's kind of nice to throw a little light on the Steingraber kits.   they are a lesser known manufacturer,  but they are old.   caution should be observed in attempting to build one.  I still think it's kinda funny how all this came about.......I'm glad that J had fun with what he did with his kit.....he built a very nice model from his kit :)
enjoy.....I will try and keep the ball rolling as steady as I can........gonna try and do sails,  so with no real diagrams to work with,  it should be entertaining  ;)    a thanks as well to those who hit the like button!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
continuing on in February.........the 28th,  once most of the frame was assembled and the deck platform was cut out,  it was fitted in place.  through the process,  there was some pieces that broke off.....the wedges can be seen on the build board {the same board that the Clotilda was built on}.  to help in keeping the bulkheads aligned,  a strip of planking was affixed to the sides.
458939085_6.jpg.c244dc783941d55aa4424e3e819a5162.jpg  1692438970_7.jpg.b1779a77030733a7ea44e2253b7405c5.jpg
1263908306_1.jpg.68b6851201945eff09c3ad0dd615c306.jpg2088321294_2.jpg.7d9ef0144dec6d4d81116a2f523a19b1.jpg
the odd parts I made and the stern bulkhead was left off for the time being,  until the frame had enough time to adequately dry.   the bow part served well in forming the bulwarks for the Clotilda....I think it will do just as well for this vessel as well.  the stern,  as built from the instructions,  looked kind of lost without the bulwark posts to end the bulwarks and form the transom.  the bulkheads are very rough......the mahogany damage and such.......some I simply scabbed in basswood to complete them.   others I completely removed all of the mahogany and cemented another layer to them,  trimming them later.  by the time I was done with this step,  mahogany bits were all over the place!   from this point,  I turned to work on the Clotilda,  who by now was nestled in her new birth.....a hull that had been already planked.  I made the separate birth,  awaiting her arrival.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
March 12th...........was when I finally got back to her {the Agillis}.   the hull frame has fully set and cured by now.   the deck platform was repaired....the bits that broke off were trimmed and fitted back in place.   at this time,  the bow bulkhead {or is this the Knighthead}.......I'm not sure,  but as it will work for the Clotilda,  the sill produced from the addition of this part,  will provide the seating for the bow spirit.
the sill I speak of isn't shown here yet........the plank strakes that will run along the decklines,  will define the sill.  I will be adding the chock at the tip of the bow stem to give the angled lift to the bow spirit.  I may need to drill a hole through the bow part,  to allow the spirit to run through it.  I do plan a fore deck,  so perhaps I can get away without having to do it ;)
the original part #10 was cemented to the ends of the deck platform,  leaving the overhang in the center {which is curved}........the new part #10A was cemented to it,  taking up the overage.  this bulkhead was also slanted slightly to give a slant to the transom.  between all this,  some fairing was being done........a head's up from dealing with the Clotilda hull.   some of the bulkheads are not exact to contour....if you catch my meaning  ;)
   after these parts had dried,  it was time for the real fairing process.....a lot of it!   my arms were like spaghetti after!   down towards the keel,  there was more to be done,  but I wanted to get the deckline and bularks defined.......something about those posts dangling in the breeze worried me.   getting the upper end of the hull faired,  the hull planking started at the deckline.  I want to use as much of the original wood as I can...some of it was useless anyway....it was warped and twisted.  this stuff looks like mahogany,  but is hard as nails.  I'm sure that after adding a few strakes of this,  the hull will be solid ;)
232246654_3.jpg.5d983bfee10232c6083ffe7768b39645.jpg  1362718230_4.jpg.e072021d91d727f12b11f8f3623908f5.jpg
at the bow stem,  the sill I spoke of has now been formed {more on this later}.   I didn't get a picture of it,  but looking at the stern in the pictures above,  it can be seen that I added the parts #9A to interrupt the large gap between #9 and part #10 {more on that later too}.  to help support the deck platform,  I added bits of wood underneath.
885411446_1.jpg.39fe7e1746afc41064d335717160ced6.jpg  1239859097_2.jpg.cf4696744bfc964599698356337e8558.jpg
the idea here is to insure that these two strakes are flush with the platform.......I kept some of the camber ;)   some testing was in order to see where to put the gun ports....something I've never done before!  I shouldn't mention it,  but I will have quite a few cannons from the Connie kit I have.  they do look a little out of scale,  but look close enough for the model......I used the bow chaser from the United States kit to check the height of the gun port.
1532078099_3.jpg.0f15c560724729b9ee9b86a6cb3c7cfd.jpgI got the bow chaser from the Connie kit as well....unassembled,  but after all......I'm playing  ;)
with the deckline set,  now to set the bottom lip of the gun ports.
to figure this out,  I needed a stand in........Cloey will do the honors.  positioning the cannons up to the bulwark,  it appears to be around 4 mm to 5 mm would be good,  to allow the cannon to have sufficient drop.  now,  I plan to size the gun port 10 mm X 10 mm.....seems to be a good size to me
843829884_5.jpg.09465ab6cc11e304df922095bb7a8fca.jpg  1604766384_6.jpg.af9cf48e5af42a6f0105c5dc4ef29606.jpg
the bulwark strakes for Cloey are 1.8 mm X 5 mm...good food for thought.   for what I need.....there is an abundance.   I'm sure you're wondering.......what's with Connie?   still in the planning stage,  but I assure you,  it will be interesting ;)    nutz........off to take Gibbs for a walk,  and I'm sure the admiral will want to run the errands.  bee back in a bit with more .......still much more ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
we had a good walk.......the admiral suggested we wait a while for the store,  to give my foot a rest...........OK! :)   I can add more to this log!   bouncing back from Cloey and other projects,  on the 18th of March,  I was back to continue.   by now,  I've added three strakes to the port side,  and was adding the same on the starboard side.
2136913664_1.jpg.32eaefb958f6aeeaf70743d790a1db9d.jpg  2147393608_3.jpg.80dc0f0ec7f898d52e5887ddd0aa3e7f.jpg
this wood is tough to bend.......I'm not sure that I will be able to do the entire hull with it.   in the event that I don't........I can rest easy knowing that this ship will have an armor belt  ;)
584025414_2.jpg.a4d4da4d174f97c5e2b3212f2a16ce63.jpgI had to do a double take here........
it appears that there is a gap mating these strakes to the bow stem.........I looked at the hull........it is not the case {I may have adjusted them......not sure}.   completing this,  I moved on for a bit........but on April 2nd,  I was back to planking the hull further.   I decided to use 1.8 X 5 mm Obechi to raise the bottom bulwark sill.   the pictures are a bit blurry.......not too bad,  but it shows ;)
606151637_1.jpg.da7d8a7662f7c5f8e9c53ca14bf4b05e.jpg  2085648210_3.jpg.2ff3a6bc049c2599dae916d639907549.jpg
the mast holes were drilled,  and in checking the cannon height,  it is OK :)    there is sufficient drop.  {any closer than that.....you might want to hand out the muskets and swords ;) }
I know this is a different approach in creating the gun ports......bear with me.   at the bow,  there is to be a fore deck,  so building up the bulwarks can be done here.   the windlass will be set up much like the Clotilda,  if this works out as I hope it will.
122653316_5.jpg.b0069e1cacb7a2c0ef3598360d7962df.jpg  883452830_8.jpg.b49d9794953a9a5ea289fe63d73a4def.jpg
the stern winn be built up as well,  a aft 'poop' deck is in the plans too.
582685190_4.jpg.61ad4a48977175ec19518937b5698dd4.jpg  2111671016_6.jpg.9e5ccdb66b1e7a8db5146e2426d81c06.jpg
1549839770_7.jpg.465fea427194bb7b07a6481d9c5816f7.jpggoing fine so far,  but I was soon to shoot myself in the foot!
I was so bent on getting the transom boxed in,  that I planked it.........as far down as I could.   little did I realize,  that in planking down around the counter,  I would need to clamp the planking.   not having the transom planked was essential......
1260251525_9.jpg.a27184550a4b8693e24b5d408a25ae54.jpgthe open field on the sides will be spaced for the ports - five on each side
341170666_10.jpg.37ab31df83f4696448f476bbdfc79a9f.jpg  1508155981_11.jpg.879e9a349cc31bb6d6f03e45e599af1a.jpg
then.......a problem occurred.......the bow stem lamination was splitting apart!   it was an easy fix though........some glue was tucked into the separation and both sides were flanked with a piece of wood.......might come in handy when gammoning the bow spirit
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I got back to planking the hull on April 22nd.........added another four strakes to the starboard side.  I have been using a small block of pine board to help with terminating the planking at the stern.   it fits on the deck and is thick enough to prevent damaging the transom planking.  I'll let ya know ahead of time,  that it was short lived............one slip later,  and the transom wall was broken.  ....not that it wasn't expected......oh well!  I'll fix it later.
the #2 bulkhead looks to be too narrow....I had to shim it.   actually,  it's the #3 bulkhead.........too wide...........making the hull too rounded as it heads towards the bow.   this is about the time when I started to make metal parts for the masts....also a tracing of the bow deck.
1361572118_1.jpg.4bb3006144d976a8c5bf168bac107634.jpg  350076270_3.jpg.6eac5cb191d7640f818d10f3366eed2e.jpg
in the last picture,  it can be seen that I used the Dremel to bring down the #9A bulkheads........too much there as well.   this hull was turning out to be harder to plank,  than the Clotilda hull.......         in this picture,  it shows the first defined gun port....four more to go on the port side.
532565836_4.jpg.b011b54d0ce1cb9c221d32eb5161ce65.jpg  1272636578_5.jpg.0c62e8e3120821827644170f48246558.jpg
two thing to note here,  is that the extra transom bulkhead boxes the deck platform in leaving a space......that will be covered with deck planking.  the other thing is that I trimmed the bow bulwarks to the third post.....I may need to scab in some extra wood to center the gun port.
well....it's time to run the errands..........I was able to post as much as I did......and I managed to wolf down two tuna sandwiches :)    I think there are four more sessions to go before the log will be up to date.   more to come........ :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
hello John........how many...........hmmmmmmmm........I think I've lost count too :D  :D    I will take a census....a big thing at the moment here in the states ;)   I'll have to get back to you on that.......I'm sure others are curious as well.   basically,  this started to see if the parts could be used........I really hated to toss 'em out.   I think that when I get to where I am now with the hull,  most will agree that the hull is a keeper.  glad to have you look'in in :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
so,  by April 25th,  I was able to move forward with the port side planking.   the mast boxes that I had made for Cloey,  were made for this model as well....they are in place.
1260265462_1.jpg.bc438ad5bb464c72caf65bb48023702a.jpg   605803737_2.jpg.a6934fe3438e6f084f00c7c8c277d25b.jpg
now at five strakes below the 'mahogany' band.  along the way,  additional fairing is being done,  to insure the run of the planking.   it has been hard to maintain the line.........at this point,  the planks met one another at the stern.  I think they call this 'herringbone'........I'm going to let it run like this down the counter,  as it will leave a very small area to close when the planking run onto the rudder stem {the terminology escapes me}.
528560079_3.jpg.55a8fde803c38220a582006f86b0e1e6.jpgthis is also the repair of the transom.
the planks now are being eveningly laid.......port and starboard.
it can be seen how the planking is closing in on the rudder stem.  closed sufficiently,  the hole can be drilled for the rudder stem to enter the counter.   I need to do the same for Cloey ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
John.......I just told the admiral what you asked me..........her answer was "too many if you ask me! "   I look at it this way.......I'll be spend'in the rest of my life finishing them all ;)   I'd better be around till a ripe 'ole age,  'cuz I even have a stash that I haven't even started  :D  {I'm reminded of this often}.
anyway......it's April 30th........I've stopped on cloey till I get this one planked.   the hull looks like a three legged dog....it's gonna take a lot to whip it into shape.   it's a good thing I have the 'rasp'........hopefully,  I have a picture of it somewhere.    it's a ten inch 5/8 dowel,  with some really aggressive sandpaper adhered to it.......my own design ;)   by the seventh strake of Obechi,  the planking was well onto the rudder stem.   there are five strips of this mahogany left,  so I though to get rid of them.....two on each side.  as I'm going along,  I've also been sanding......mainly to get a head start early.
276924717_1.jpg.bfed09f89fec82d427c547556bbe15ae.jpg  1534283361_2.jpg.a1e7de469b86fda79c466ede8c30cfdb.jpg
the rest will be done in Obechi.   this does seem to take on the looks of a interesting hull planking............almost pretty.......in a sense.   this is temporary,  as it might get stain,  but likely will see paint.   I have a hard time arriving with a hull that doesn't show glue blotches afterwards.   surprising that I haven't had any more instances of delamination.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
May 8th..........I am done!   I've done quite a bit of sanding too..........the rasp lived up to its name.  it took down a lot of the high spots and shaped the counter / stem relationship.  from there,  it was medium grit sandpaper,  later switched to a finer grit.
926348376_1.jpg.20c9b47b79d255b89afe66885d491e86.jpg  938751306_2.jpg.bb89d6e15274b39a787a74b927259eec.jpg
still more to go..........it can be seen that there was a bit of a problem on the starboard side.   I tried to fix it,  but there was no other way,  but to cut it out.  it will have a copper bottom,  so it will be hidden.   more sanding was done in the meantime........a little filler and shaping was done.   dusting the hull off and cleaning up the mess,  I thought it rather neat to do a comparison with Cloey.
1655611422_3.jpg.69b70ccfddf1940434703b5f654d4151.jpgohhhhh....there's the RASP!!!!  :D
207230514_4.jpg.1732534b51369be362a616ed2dba49fd.jpg   980884338_5.jpg.f5c535b4bbc34899d7b6642f71ba4588.jpg
she still need a bit more work,  but I'm quite happy with how the hull came out
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks god the transom came out OK  ;)    so this will bring her up to snuff.........the 15th of May.   I've done some more filler work,  as well as sanding,  but these next two updates concern the assembly of the gun ports.  as I mentioned,  they will be 10 mm X 10 mm..........amounts to two strakes high.
1577406776_1.jpg.e3fda57cf702cac17e09cea0d798ba6d.jpg  615366928_2.jpg.61fda80dd7c3c77e99bcee37de0ab362.jpg
simply......spaced ports with short segments of bulwark.   I ran a 2mm strip of mahogany to cap them off.  what also can be seen,  is that the aft cabin is defined.  there will be a companionway entrance,  and I may add some portholes or windows.......gotta go higher and build it up.
1296237061_3.jpg.9764bd9a763521b1dfdd0c65d98546c8.jpg  2094043154_4.jpg.0ebaddd37328fe317725402a1778cf76.jpg
I also need to adjust the posts too........good firm base for the cap rails.   still a bit to do before I can plank the deck.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
...and this will catch her up to date........this was done on the 20th........the starboard side.   I did get a couple pictures of the process.
695155850_1.jpg.3a66ba5afeecf8d370f366dacffaa562.jpg  361576269_2.jpg.f54b79bb103211a60869b36d310d39e6.jpg
the sanding stick on the slip is 10 mm wide.   the hull is a lot more defined than when you last saw her.
with this done,  the mahogany was run along the top.   there is a gap at the bow.........I'll just fill it with filler and sand it later.
1509719722_4.jpg.cdbdeec83cc9bfc3946b32f5e767e69b.jpgin fact.......there's filler on it now.
435006258_5.jpg.c438aab396a63aaa7ff1b9d11c21dd27.jpg  93932689_6.jpg.d5d6794aef01b10550521d0e74845ced.jpg
so......here she is.   I'm glad I didn't throw the parts out...it was worth the gamble.   I see a lot of potential here......I'm already getting ideas.   thanks for look'in in........I hope to have another update soon :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Most kit plans come with the templates for the die cut and laser cut parts.  That is a cheaper alternative than buying the kit.
Cornwall and Age of Sails both have a nice selection of kit plans for reasonable prices.  It’s just copy, paste and cut at that point (plus you can alter the scale at will at that point).
Plus the plans for Triton are $5 with complete POB templates and the plans for Winchelsea are $15, with all templates provided.  I have both sets and plan to modify both for masting and rigging.
Building:
hello Ferit.........thanks for the kind comment and I hope you follow along.   even though this is just the hull,  there still a lot to be done yet :)
thanks Phil for the info.......I'll check it out.  I do tend to spend more time at the table rather than the drawing board,  but I do try some things on the computer.   one of the experiments I have going on is with recreating the Danmark hull.   I have some odd parts from the kit........I hate to throw them out { I got them quite some time ago}.   so I took the instructions and blew the diagrams up.   at 150% the diagrams match the scale within about 1/8th {I think the actual number would be 153%}.   it was good enough for me and I have assembled a hull frame,  but I haven't gotten around to fare it and try the parts.  I would also like to scratch build a larger scale Gothenborg.  I have the model {and the instructions}.......the original model has damage from a couple of falls....not sure if it's salvageable.   if I did it,  I would be outfitting it with cannons.......the original kit doesn't have cannons.   I have the parts panels for quite a few of the kits that I've built.........it make it easy to replicate hulls :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
You work like lightning mate  - very nice work on them hulls.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Good morning Dennis, that freebe hull looks fantastic. lol i was thinking i could re scale the new billings Cutty sark to kit to 1/48, as the intention was ro scratch most of it anyway
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
  • 4 months later...
sorry to all who posted........the big change here........the virus........and my shift from wood to plastic,  has distracted me somewhat.  worse is the focus issue i've been experiencing..........but I think I found redemption by using my own #13 boot to help me along  ;)   not having a suitable camera has also been a thorn..........I hope to remedy that soon as well.  the last picture showed a bare hull.....the gun ports have been established along with the aft cabin, which will be capped with the aft decking.   there has been some progress.....the outer hull has been painted,  upper and lower,  as well as the inner bulwarks.  I'm looking towards an open bow with the usual windlass set up,  to make it easier I think.    next will be to plank the deck and add the rub rail along the outer hull...........then the cap rails.  naturally,  the progress will move forward  ;)   once I can get a decent camera,  I can show you what I've done so far.   to be continued.......
I haven't looked at the Billing's Cutty Kevin.........do you already have the kit?  I used photoshop to enlarge the parts panel diagrams for the Danmark,  to fit the odd parts that I have for the model.  I basically enlarged the diagrams to around 150%.........to be more exact would have been about 153%.  this brought me to around a 1/8th difference in the numbers and size of the bulkhead parts....they were all I was interested with.......I can scratch build the rest,  since all corresponding measurements now will be different {once started,  it will snowball from there ;) ).   of course,  this one is not a priority,  considering that I probably got somewhere in the neighborhood of 15 or so active projects going on,  I won't be getting back to it any time soon :ph34r:
so be assured that the Clotilda and this brigg is still in the works....given the condition of the kit that I'm building them from,  they are coming along surprisingly well.   JCT was able to create a decent model from the box.....it inspires me to press on :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good to see you back working on this and Clothilda although I have been enjoying your excellent WW1 Flying Circus type builds ;)
Edit: only camera I have is the one on my phone! I don't think the current Mrs Kenway would approve a budget for photography 😔
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
hi there Ed :)    I'd have probably been better to have bought up a bunch of those throw away cameras :D ....I'd have likely gotten better pictures  ;)   I can't see myself buying one of those fancy cameras.......I probably wouldn't use half the functions....that's why I prefer the cheap cameras.   I want to get back to wood........I kinda miss it {slight lean towards the semantics of it all}.   there is another wood project to throw on the pile........I think this bugs the current Mrs. Wenzel more,  than my want of a new camera  ;)   .........lemme take the puppy out.........I'll be back :)
so.........yea,  I felt bad that there are no pictures to show,  so I used the admiral's phone and took some.   .......just a few to test the theory out.  if I go this route,  I will need to be mindful of the camera angle........it creates odd shots.   the bottom paint is copper........the upper hull is painted with Billing's flat black.   I should have left it as it was........the first coat looked to be similar to dark walnut stain.   but instead,  I gave it a second coat and will leave it at that.   very little wood grain shows through,  but it gives the hull a worn look,  which I kinda find appealing.   after all,  it's an older vessel,  and I'm sure maintenance wasn't a priority ;)
I also added the chock to give the bow spirit that upward sweep.  the inner bulward color is a medium green.   taking the pictures,  I wasn't seeing the color and was afraid that it might not show in the pictures.   I'm glad it does :)   the 'tool' you see in the foreground is how I'm going to gauge the rub rails.
the deck will be planked and I will need to make a grate for the hold.
I will likely go up another 4 mm for the aft deck.....giving more height to the cabin.   I might add some port holes.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
hello John....glad to see your following along! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I spent a bit more time on the Agilis than the Clotilda.   they are both together on the table.   if your following the Clotilda build,  you read that I had made up two bow spirit assemblies....I fleshed out the one for the Clotilda first.   the glue hadn't set on this one yet,  so I applied a bit more and set it aside.   this one will have the spreader as well,  but will also have a double striker.  I will need to create a cap for the spirit,  since I didn't leave enough jutting past the fitting to drill.
the hawse holes were drilled into the bow.......they will be fitted with metal eyelets.  I had shown in the past,  where I fell into the possession of an entire box of different size eyelets,  used for shoes, and various leather goods {anything that requires lacing}.   they have come in handy quite a bit....and I still haven't put a dent in the amount that I have.
I was being rushed by this time.........errand day :rolleyes: .......so I had to stop what I was doing.   the last thing I did was mark out the deck for planking.  I'm not going to get as fussy,  as I did for the Clotilda,  but it will still look good :)
I may add a couple more lines mid ship........those fields look a bit too wide.  we'll see ;)   thanks for look'in in and your patience......
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
coming along a treat, nice to see you back in the sawdust my friend
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thanks Kevin :)    I made some progress on the Agilis today......fleshed out the bow spirit some more.   I was able to give it a dual striker......I was concerned,  since I didn't leave enough of the spirit jutting out the front.   knowing how tough it would be to solder it { a mast ring with two sockets},  I used Ca to assemble it.   I bought a new camera today........I was gonna wait for the next update to introduce it,  but I don't have a picture of the assembled bow spirit,  so I ran in a snapped a quick picture.   it's a Kodak PixPro Fz43......metal flake black,  as opposed to lima bean green,  which was the color of the Kodak easy share I used to have.
there was just enough of a stub to slip it on.   here they are both dry fitted in place.....I added a bit of brass rod on the butts of each one as a guide pin
20591526_2.jpg.c08cbccd12961f59888a7b1095cb95fd.jpg  1297773337_3.jpg.fa0d76d3aba68dad777d60544f65165e.jpg
171498216_4.jpg.b01668168b09440ea0d07e079da57dcb.jpg  shown here also is the grate I made for the hold
I also began to plank the deck...the same wood I used on the Clotilda's deck.
833075135_6.jpg.0c9488046015490dfd50ab9409135a53.jpg it's a start :)
...another picture with the new camera :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
