Thank you very much for all the likes and for stopping by!
The hull is done, so it is now time to make the deck fittings.
Hannah only had a few deck fittings by comparison to Victory or even the Prince de Neufchatel.
I started with the stop for the bowsprit and the hatches with gratings over them:10717928-2987-4C02-84C2-3057AFDFC46C.thumb.jpeg.93454c113366ef070d1f3ad4245a54b0.jpeg
The stop is basswood, the hatches are posterboard and regular printer cardstock.
Once these are done, I’ll make the hatch going into the lower deck area and the deckhouses.
All will be painted a forest green as in the painting I am using for reference.
Once all immovable fittings are done, I’ll ink the deck with an Army Painter Strong Tone wash.
Building:
Thank you very much!
The first round of fittings are painted and on:
7181201B-64A7-42F0-AF84-F26AA5CB8020.thumb.jpeg.c8781d1c9044d1ac79d4a612056b31c2.jpeg20674A17-D837-4E03-B6C3-DDF58425AD23.thumb.jpeg.6d477741d11ffa3ffb68a6f48094e996.jpeg
The deckhouses and binnacle are in the process of being detailed.  I am cloning Hahn’s method, just with posterboard instead of veneer.
There really isn’t that much to this model.  I still need to make one more hatch, a windlass, a ship’s belfry with bell, two pumps, a stove pipe, four small carriage guns, 10 swivel guns, 2 anchors and one ship’s boat and the deck will be complete.  That sounds like a lot, but it really isn’t, especially next to the Prince de Neufchatel or the Victory, and especially mostly made out of card.  I’ve just been running really short on time lately.
Building:
Thank you.
I am having a lot of fun building Hannah.
This is my second scratch build.
I built the Prince de Neufchatel from the plans in the Chapelle books.  I am trying to refine my methods that I used there.  I made the discovery that I have a lot more fun building from scratch than I do building a kit (it is much more satisfying too).
I used it as a learning project so I could improve my skills to finish the Victory as a bash, instead of out of the box.  It has worked beautifully.  I will hopefully finish the Victory next year.
I tried several new things with this build than what I did with the Prince de Neufchatel.  I made the impression of there being a second deck.  I made an actual stern instead of cutting off the hull covering and bulwarks and gluing on a transom.  The corrugated cardboard worked like a dream.  I didn’t have the twist in the hull that I did with my earlier models.
I used many of the same methods for my deck fittings that I used with Prince de Neufchatel.  The binnacle is nearly identical to the one I made for Victory.
I will use the same method of carving my cannons and making the gun carriages, that I did with Victory.
Hopefully, this project will be done within the next couple of months and I will get back to working on the Victory.
Building:
Your deck fittings are real good Phil.😃
I don't know if you've said earlier, but are you putting a full rig on her?
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
The pumps, the stack for the galley, the deckhouses and the binnacle are all complete and in place:D34B6EB4-5991-4C86-BA18-DF822CA30322.thumb.jpeg.51c0f75c127c6ed12703f203f40b1a8e.jpeg0E57AC49-EC11-46C3-AE44-6F5259610E76.thumb.jpeg.57a24c78fa6884aa76534633cccf770a.jpeg
In other news:
The belfry is drying because the bell keeps breaking off.  I started on the last hatch and I resized and printed off the plan for a cutter out of my Victory AOTS book.  I’ll carve a blank out of it and build it with the shell method, using card instead of wood.  I also cut out the supports for the windlass which are just laying on the forward deck in the top picture.
I still need to make four carriage guns and ten swivel guns, two anchors and chain plates.
I am planning on using a bunch of leftover deadeyes and rigging blocks from my bits box to rig Hannah.
Building:
The last hatch is made and is sitting in place.
The windlass is under construction:
0D535FF6-8290-4BEC-BCEB-DEF3BBF5D7E9.thumb.jpeg.9f20cbed2d23fd2164587f88d6d51500.jpegA0B2BA36-4BBB-4549-BBF2-F8AA9CFC43C7.thumb.jpeg.9ac7dbfabee1584e94108e243072abe9.jpeg7A206CAB-EF16-4131-91B9-8FDBA0D1EE39.thumb.jpeg.783f1e346abe5be8e06a30393447bd43.jpeg4E616154-3A4A-40F4-AA42-40987418BD13.thumb.jpeg.6aea0b5012c8563fad1e4e9c0990dc47.jpeg14C97EFA-E73F-4FA6-AED9-F3318B7A6768.thumb.jpeg.2e6a754952fa0e359bd02176792c3ef3.jpeg
For those who would like to try this method of construction.  I used a generic dowel rod that I squared off and then turned into an octagon.  I then cut a groove in the center to simulate the gear in the middle.  I drilled holes for the posts used to turn the windlass and squared them off with my scalpel.
Building:
I cut out the shape of the ship’s boat and laminated the two slices together.
BC37D535-36B7-4B89-87A5-B632D6468CB5.thumb.jpeg.fcb567dbd64847c47965dd9ebd77c1dc.jpeg654742E2-8B79-4658-A359-0648773B29A5.thumb.jpeg.7517c5bd861cb3d26c8f454b04c2bec4.jpeg0426F776-CA6A-42CE-8431-C8780F679B0D.thumb.jpeg.d1bf3e11c9da26cfe395e79532e05fa7.jpeg
The finished one is a leftover from the Prince de Neufchatel.  It is slightly too large to fit on Hannah’s deck.
I included it in the picture because I used the same drawing out of the AOTS, for the Victory,  for the one I’m making now.
Building:
Thank you very much!  I used an Army Painter Strong Tone wash.
I have the new mould carved and wrapped in plastic wrap, so the glue doesn’t stick.
The keel is glued to the support around the mould and all frames are on.  I am currently working on planking the boat.
8A9CFAEF-D445-480D-9BD1-88080D6242D1.thumb.jpeg.7ebcfb3efe52be3fa4b916f911abaed9.jpegFC57FF8A-E236-4F9F-B7A6-AE721CAC1005.thumb.jpeg.b3516d46d3877c3b013b3e7b7ffeb06f.jpeg
This is a little cutter so it was most likely clinker built, so that is what I am doing.  That means the plank above overlaps the plank below.  It’s a little challenging but not overly difficult.
Building:
The cutter progresses:60332E2A-AB90-43F1-9C40-15BC5E01BB5D.thumb.jpeg.a4c6dc97a0e7a2b5318fd1e762266e80.jpeg
Even as imperfect as this is, these still look so much better than what comes with the kits.
That’s why I am going to scratch build the ones for my Victory instead of using the Mantua boats that I bought.
Building:
