Rigging around the Bowsprit
The Spiritsail yard has been rigged with blocks for the lifts and the halyard, eyebolts for the guys and a brass rod to secure it to the underside of the bowsprit:
The following photos show the standing and running rigging that has been attached:
This is as far as I can go in this area without rigging the jib boom. The boom is very fragile and I know that if I rig it now I will end up snapping it off as I turn the hull back and forth while doing the mast rigging so I will hold off adding the boom until all the other rigging is done.
Next I’ll start with adding the deadeyes for the lower shrouds on the Foremast.
Tim
Current build:  USS ROPER (DD-147) (build log)
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
The lines that come down the foremast and are belayed around the mast base are in place. Both the Truss pendants and the Jeers terminate in tackles made up of 2 double blocks (there are 2 more sets on the far side of the mast). The Nave line is just belayed to a pin rack:
The upper deadeyes have been added to the shrouds and backstays:
Rigging the anchors was made a little easier by the rigging hooks available from the syrenshipmodelcompany.com I used them on the bottom of the rigging tackles shown in the first photo and they should come in very handy for rigging the futtock shrouds under the tops:
And here is the anchor in place:
I have to make up some rope coils (one of the most tedious tasks for me) and then it will be time to step the main mast.
Tim
Main mast in place
The main mast has been stepped and the forestays are in place:
The deadeyes have been attached to the shrouds and backstays and the main yard jeers and truss pendants have been rigged to their tackles around the base of the mast:
Next up will be stepping the Mizzen.
Tim
Mizzen Rigging
With the mast stepped the following are done:
  • Gaff Throat & Peak Halliard and Vangs
  • Cross jack Truss Pendant and Lifts
  • Topsail Tye and Lifts
  • Topgallant Halliard
  • Lower shrouds and backstays
  • Futtock shrouds and staves
  • Rope coils
  • Forestays
  • the "railing" on the top
The only rigging left for the Mizzen are the yard braces and the ratlines on the shrouds.
Edited by schooner
Tim
Just about done with the rigging
All the rigging directly associated with the masts (halyards, lifts, jeers, shrouds, stays, etc) has been added along with a couple of the yard braces.
The only things left to rig at this point are the rest of the yard braces, the jib boom and its’ rigging and the ratlines on the lower shrouds.
The end is in sight.
Tim
Almost done….
The rigging is finally done.
Now all that is left to do is fixing any cannon barrels that got pushed off their carriages, adding the gunport lids, the quarterdeck railing cloths, adding the boat to the transom davits and mounting the model on the display case base when it gets here from BlueJacket.
Edited by schooner
Tim
  • 2 months later...
Finally finished
The display case base arrived from BlueJacket so it’s time to take some final photos and put this one to bed. It has been a challenging but enjoyable build.
Edited by schooner
Tim
Congratulations!
I noticed that you didn't include your name and date on the nameplate. You know we get a lot of inquiries here about mystery models with no provenance -- you should include that information somewhere, perhaps on the bottom of the stand?
Beautiful work - congratulations on finishing!
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Well done sailor, very well done.
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Thanks for all the kind responses and the likes.
Tim
Thanks for the kind words.
Just one more photo to show what attracted me to this kit - I wanted a fully rigged 3-master that would fit on a bookshelf. Well, it does!
Tim
Congratulations Tim on a beautiful build!
Very inspirational. I haven't built a solid hull model in at least 10 years. You're making me think it's time to take one on again, and I've always had an interest in this particular ship and kit... 🤔
Clare Hess
He's a -> "HE"
Wow, seeing it on the shelf like that next to the books really brings home what a small model it is. It's tiny! Which makes the workmanship all the more impressive.
