13 hours ago, RichardG said:
I have a 10" table saw which I seem to do ok with (no fingers lost). I ordered a Byrnes saw a few days ago. A detailed tutorial would be a good resource from both from a safety and precision perspective.
If you haven't seen it, here's where a good bit of info on the Byrne's saw is kept:  https://modelshipworld.com/topic/23843-byrnes-saw-reference-also-good-for-other-desktop-hobby-saws/
As others have "respect it" and your fear will ease with use but keep the respect.
13 hours ago, glbarlow said:
adjust the exit side of the fence away from the blade slightly
This is all it takes to prevent kickbacks in my experience
I believe that the Byrnes Saw fence has a very slight taper on the back half of the fence built into it already for exactly this purpose.
Perhaps, but it was Jim Byrnes that gave me this step first, and offered again by others.
Regards,
Glenn
Current Build: HM Flirt
At one time Jim had built-in  .008" back taper, but with my saw setup I found that adding .005 - .010 was needed.  Thicker sheets and harder woods needed more.  Ebony or bloodwood always needed the most.  Some sheets look perfectly straight but have alot of internal stress which is released when you start to mill strips and the strips can move into the back of the blade.  Sometimes flipping the sheet helps.
Jeff Hayes aka HobbyMill
Jeff
aka HobbyMill
Current Build: Constitution
Jeff!  Where have you been, we all miss you and your wood!  Come back! 😀🤣😂
Regards,
Glenn
Congrats on the retirement, Jeff.
