Check out our New MSW Sponsor - LUCZORAMA - in the Banner Ad Section ×
@FriedClams Thanks so much Gary. I am so happy that the boating season is back here in Maine. Now I have a list of new projects that need doing on my 1:1, as well. 🤣
Paul
On the Ways: Mighty Mite, Harbor Tugboat by pwog - NautiCurso - 1:64
__________________________________________________________________
Completed Builds:
Lobster Boat Red Baron (Bluejacket)
Sardine Carrier Pauline (Bluejacket)
Swampscott Dory (BlueJacket)
  • 4 months later...
Hello Everybody!
Now that my 1:1 boat is on the hard and ready for a long Maine winter, I am starting up again on the Pauline. It’s good to be back at it.
Although, the rigging on the Pauline looks very simple compared to that of sailing ships, this is my first attempt at rigging.
I’ve tied the turnbuckles to the eye pins and chain plates and tied the shrouds to the turnbuckles and mast. I also threaded the shrouds through the pin rails, as well. The laser cut pin rails that were included in the kit were so fragile that I ended up breaking both of them! So, I just made my own out of scraps.
Paul
Completed Builds:
  • 2 months later...
Good Morning Paul.
                                   I am building Pauline and am at the step of constructing  the  antenna system.  The difficulty I am having is inserting the.20
brass rod into the small hole in part LP24A  I tried enlarging the holes but broke each part
How did you accomplish this step?
                                  Also did you paint the antenna silver-I tried but paint will not adhere and if it did it would make the rod even thicker.
Your photos and steps serve me well as at  88 I need all the help I can get   !!       Dick
Hello Dick,
 I’m trying to remember the antenna assemblies specifically. I looked at my build and it looks like I was able to get the wire through the holes. That being said, there have been several parts that are so delicate I broke them while working with them. Usually I ended up fabricating new parts from the wood that initially held the pieces that broke. In some cases I glued the parts together and used paint to try and camouflage the  damage.
currently I am at a stand still, as I am finding assembling the rat lines to be very tedious and have broken a few parts in my attempt to assemble the lines. It’s very frustrating!
 Concerning painting the antennas; I painted them after completing the assembly.
I’ve reached out to Nic at Bluejacket for advice before and have found that useful at times. I hope this helps. Good luck!
paul
Paul
Completed Builds:
Paul - I just looked at your build logs and both the Red Baron and the Pauline are first rate work - very impressive!  You'll enjoy the Swampscott Dory and have no problems with it.  I'm just taking a long time with it as I have zero nautical background and am learning the language as I go along (what's a jib?; what's a halyard?; and don't even get me started with "strop a block"!) Congrats on your terrific workmanship!
Melissa T.
Current Build: Half Moon - Corel
Completed: 85’ Air-Sea Rescue Boat - Scratch Build, Gunboat Philadelphia - Model Shipways, Statenjacht - Kolderstok, Swampscott Dory - BlueJacket ShipCrafters
Thank you so much for your kind words Melissa. Honestly, I'm finding the Pauline challenging, at times, as some of the pieces are so delicate that I break them and then have to repair or reproduce the part. It's very frustrating. However, the builds are fun.
Again, your work on the dory is just beautiful!
Paul
Completed Builds:
  • 6 months later...
Hello Everyone! I hope you are all well.
It has been a while since I've posted. Truthfully, I needed to step away from my build, as it was getting so frustrating. Also, I have a 1:1 scale boat that I spend most of my time on during our (too short) summers here in Maine.
To bring you up to speed...
I was in the process of starting the standing rigging. I was having a very difficult time with gluing the ratline battens onto the inner shrouds. The battens just weren't sticking to the rigging thread. After many attempts, the frustration (and the fact that I was running out of swear words) got the best of me and I closed my shipyard. Now that I've had time to distract myself around the coast of Maine; I'm back at it. Having thought through my previous attempts at gluing the battens, the only conclusion that I could come up with for my failed attempts was the glue. I did some research and found that CA glue has a shelf life! I had not realized that. I bought new glue and the battens are attached! Easey peasey.
I have all the standing rigging attached, but I'm not completely satisfied with some of the slackness in some of the runs. I'm considering removing and trying again.
I found it difficult to keep the tension on the thread and tie it off. If anyone has some tips and or suggestions, I would greatly appreciate your feedback.
Paul
Completed Builds:
What type of rope are you using? I found that moving to polyester rope for me helped solve this problem (there are disadvantages to it as well, some that I'm probably not even aware of), but polyester has a stretch to it so you can make it tighter. I never found a great way to keep all my cotton lines taunt and it bugs me a little bit on an earlier build of mine.
Hi Tim, I'm using the cotton thread that came with the kit. I'll look into polyester thread. Thanks! - Paul
Paul
Completed Builds:
Quick update - I tried something that I hoped would prevent me from having to redo the slack rigging and it worked! I decided to cut the line attaching the stern turnbuckle to the stern chain plate and reattach applying a bit of tension, which was enough to draw the main back stay and the spring stay snug. I'm much happier with the result!
Paul
Completed Builds:
A quick update...
I finished the rigging. This was my first attempt at rigging. It was at times frustrating and challenging, but once completed, satisfying. I can't imagine rigging a model tall ship! I learned some tricks along the way, but I'm sure I have much more to learn.
My next step will be to coil the ends of the running rigging and fix them to their belaying pins. After that I will be adding some details to complete my build.
Paul
Completed Builds:
Good to see an update on your sardine carrier Paul.  Your model is looking great!
Good solution.  Whenever I'm building a model with a lot of lines on it, I always plan and depend on one last line that I use to tension all the rest.
I have a deep reservoir of cuss words, but when I've exhausted all of them, I find arranging them in novel combinations helpful.
Good to hear you've been enjoying your 1:1 boat.  Looking forward to future updates.
Gary
Completed Scratch Builds
I am just about finished my build. I added a couple of additions to my build based on some photos I have in an article by Maynard Bray with photos by Benjamin Mendlowitz in Wooden Boat Magazine, Number 59, July/August 1984. I added the bags of salt, just forward of the house, the boat with buoys on the stern and some rope hanks on the belaying pins. I will probably add a couple rope hanks on the rails at the sides of the house, as well.
800494902_paulinearticle001.jpg.16f06268497d39702ca855b7bdc8db93.jpg1783690003_paulinearticle001-2.jpg.ec5c598e819bf70823077607c4a62026.jpg
I still have to mount Pauline on a nicer board and I'm still going back and forth on adding an anchor and a radar antenna. My trepidation is whether or not the scale of the anchor and radar antenna are correct. I'm happy to hear anyone's opinion on the anchor and/or radar. Here are some images:
Here you can see the anchor hanging from the bow and the radar antenna. If I add the anchor I will coil the line on deck. I wanted to put the anchor on deck, but it seems bigger when on deck.???
1019568055_Pauline-2.jpg.b280eaf45deed191afc0ed21c061394a.jpg1019568055_Pauline-2.jpg.b280eaf45deed191afc0ed21c061394a.jpg
The roof on the house is removable. I have mounted an LED light to it to illuminate the interior, so I have a bit of adjustment to make so the roof fits flush.
I'll post more images when I'm completely finished.
Edited by pwog
Paul
Completed Builds:
So clean and beautiful. Nice work!
Respectfully
The radar looks right for the scale of the boat.  No idea on the anchor.  Great build!
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Here is a radar I found online,
Scale wise it looks right.
My concern is the platform the radar is sitting on.
One single rod will not hold the radar in place, they need a triangular leg or attached to a mast, a setup to be stable in weather.
All radar installation I did in early 80's had that setup.
Respectfully
Those extra details really bring it to life.
Now you are going to have to invest in a new bookshelf worthy of displaying such a nice model!
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
13 hours ago, VTHokiEE said:
Awesome job! It looks great! Unfortunately I have no idea about the scale of the anchor and such
Thanks Tim!
Paul
Completed Builds:
Thanks Kurt! The anchor looks okay (to me) when hanging from the side, but when layer on deck, not so much. I may just suspend it from the side.
Paul
Completed Builds:
Thanks Nirvana. My wife and I were discussing where we were going to put it last night. 😂
Paul
Completed Builds:
I agree with you Nirvana. I will probably use the one I found. It looks realistic and the scale is close enough. It’s pictured above, leaning against the base
By-the-way, after I finished my Red Baron build you suggested that I try a simple planked build next. My next build will be the Swampscott Dory by Bluejacket.
Paul
Completed Builds:
