Hmm...I think my concern is that cosmetics and house-cleaning products aren't meant to have a long life when applied high-value surfaces. Both initially stay in tight containers, then tend to get washed off pretty quickly after application. Unless you know any women who keep their makeup on for 30 years without taking a shower?
HI Eric,
Perhaps your concern is valid, I really don't know and I have to find out if this is a problem for the near future. For the short term it works perfectly. 😉
Thanks for your concerns.
Hi guys,
In this update I would like to show you the first impression on how the Focksail looks on the ship. The height and position of the yard is been controlled by to the two ramshead blocks being made earlier. Here you see it in action and placed on the ship. I placed the yard termporarily to experiment with the positions etc. The yard can be detached from the ship. I still need to place some blocks on the yard and make the Parrel. After that I can place all the other rigging that operates this sail and yard.
to be continued....
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
Wow your rope work looks realalistic,  Happy belated birthday  as well. Have you ever hear of a product call GAC 400 for stiffing  sails  I tried it,  and seem like it works well and is real easy to use. Might want to look at it some time in the future.
 Anyway nice work on the sails and lines, you are a master    :cheers:
                   WASA
                   USRC Harriet Lane
This is an excellent build that I have been lucky to find as will be invaluable assistance for a future build of the 'Indiscret' by aeropiccola which I have on my shelf.
Hope you do not mind me following.
Current Build(s):
Completed Builds:
Thanks! Happy to have you on board and welcome! 😀
Thanks! I will look into GAC400, Thanks for the suggestion. I like the boiled postauto starch too. Easy to prepare and to apply.
The closeups look incredible! The Ramshead block you scratch-built just fits right in. 👍
Hi Ben, thanks! Almost looking at the real thing right? if you discard the background that is.....
It's a real treat to work with your ropes and all.....makes all the difference!
Foresail rigging finished
Hi guys!
Quite an update today with lots of pictures, 24 to be exact. It was not easy to get everything right in front of my camera. I have all running rigging of the Foremast ready. I really had some trouble rigging this sail. Some things I had to redo over 3 times or didn't turned out the way I wanted it and was pretty exhausting from time to time. Also figuring out the details cost me a lot of evening hours of work. Unfortunately in all the documentation I have the details are vague or not known. I followed the rigging of Le Requin in combination with another Xebec (museum model). In the end you make choices that seem logical and I tried to keep as close to reality as I could or know.
The parrel
It starts with the Parrel. The parrel is like a "guide system" that actually rolls the rod / yard up and down the mast. The parrel is made up of so-called "trucks", these are the beads and "ribs" the vertical pieces of wood. As always, I start with a drawing to the actual scale. Then I make it as on the drawing in various steps. Oh yes, the ribs that come with the kit are made of metal and also the wrong size. So I haven't used it. Each rib is individually handcrafted. Builders with milling machines can do this faster and easier than I can, but the admiral won't allow these machines on her dining table and that's the end of the discussion....
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
The parrel is finally assembled with the made ribs and the trucks of (3mm) and attached to the yard. The parrel of this mast is a simple version. Just 3 horizontal rows that are spliced together and extended into one single rope. On one side of the yard, a strop is used to attach it to the yard. The parrel is wrapped around the mast and then attached with a truss by using a bead the other side of the yard. (see second photo). For the main mast I'm going to replace this bead with a block. Finally the rope runs down at the mast to the foot of the mast where it's tied down using a tackle with a few blocks. This can be seen in the following pictures.
[IMG]
[IMG]
A lot of lose ends here....
[IMG]
The parrel tackle is seen on the picture and is the one with the dark ropes next to the mast. The other two tackels are used to turn the ends of the yard. The ropes are running throught the top sheeves on the mast. These tackles are attached with a hook to the rings besides the mast.
[IMG]
[IMG]
[IMG]
In between I made the flagpole. The flagpole is attached with two metal braces.
[IMG]
then a picture of how it looks in full view of the sail.
[IMG]
[IMG]
And a lot of detail pictures of how I tied down all the ropes.... All rope ends are nicely bound together and tucked away...I tried to mimic reality as much as possible and hopefully the rigging is truthfull to the real thing....
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
And that's it for this update. I know, sometimes I can't see the forest because of all those ropes. The mainsail will carry the same amount of rigging.
Only the rigging of the Foremast took me approximately more than 40 hours of work / time. I can only say that it is a big job and the same is waiting for me for the rigging of the mainsail. I have to finish the construction of this sail first, put the boltrope on and so on. I hope you enjoyed this update.
Until the next update, and I wish you guys a nice weekend!
Peter
1 hour ago, CiscoH said:
beautiful work Katsumoto
you probably said it some posts back.  who makes your rigging line?  its nice and not shiny and looks very realistic
I’ve ordered my ropes from ropesofscale.com. @BenD is a member and a sponsor of MSW. I personally think he offers one of the best aftermarket scale ropes you can buy and offers a great service as well. I’m impressed how good his ropes are and how it lifts my model into a next level build.
Thanks for your support @CiscoH appreciated very much!
12 hours ago, BobG said:
Wonderful work, Peter! The rigging and sails are fantastic!!
Thanks Bob, It took me a lot of time to get it like this. Now I have the same amount of work ahead of me for the main sail. It just keeps me from starting with it. I have to find some inspiration and motivation, that’s all. 😮‍💨
Peter,
Just really catching up - been away from the hobby for some weeks, as well as the forums.... But my Gmail inbox had lots of your links -
Wow!! your work is so superlative to the smallest detail - camera close up images love your work.. Oh and the sails well  👏. Your log is brilliant..
Hmm I do need to re-open my shipyard soon...on  my mind or so it's been said haha
Cheers,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
1 hour ago, md1400cs said:
Peter,
Cheers,
Hi Michael,
Missed you lately, now I know why. 🙂 I hope we can get an update of your beautiful Sovereign of the Seas soon. She is a real eyecatcher for sure. All the modifications you’ve done. The lightning is really stunning as well.
Thanks for the likes and cheers. See you soon!
Peter
Hello friends,
In my previous update I've finished the work on the Fore. Time to move on to the Main mast. The yard is lifted by two heavy ramshead blocks. The blocks have many sheaves to distribute the load. Below you see how I made these.
All are handmade out of walnut. Re-used some of the pictures of the ramshead blocks of the foremast, because the process for making them is the same.
I all begins with a 1:1 scale drawing of the two blocks. with a front view and side view.
[IMG]
After this I cut the needed parts out of walnut strips of .6 and .8mm thickness. I re-use some of the pictures of the Foremast blocks.
[IMG]
[IMG]
[IMG]
On the sides of the bottom block, two large cleats are attached. Let me show you in detail how I made these...
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
The blocks are blackened with East-Indian Ink and after it dried finished with Danish Oil. Some of you guys swear by Clou, but it looks a bit to shiny to my liking...
The sheaves of these blocks are made of .8mm thick walnut and 8mm in diameter. I reduced the diameter to 7mm and 4mm by hand.
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
Main sail and Parrel
Hi guys,
Last week and weekend I've been working very hard on this project. It's a tedious job with all these ropes, blocks, stitching sails, boltropes and so on. You all know the work that's into making models. I've done so many little things, that its hard to mention it all. So let met start with the attachment of boltrope. It's a 0.6mm rope and I need the thinnest needle I can find to get the threat through one of the three threats of the rope. Then I push the needle through the sail fabric and tighten the threat so the boltrope is secured against the edge of the seam of the sail. Using this technique, no threat is seen on the outside of the boltrope which I like. It's a bit more work, but details, details and more details it is for this build I guess.
[IMG]
[IMG]
[IMG]
[IMG]
Then the preparations of the reef lines. The cloth is so thick at the place where the reef lines are attached to the sail, that I need a hammer to lightly tap on the head of the needle to get through the layers of cloth. When the end of the needle hits my cutting mat, I turn the sail upside down and push the needle, with the head on my cutting mat, through the cloth.
[IMG]
[IMG]
In the end I've attached all the reef lines on the sail, attached all the needed blocks on the yard and attached the sail on the yard.
[IMG]
Back to the ramshead block. To attach the lower block on the ship, a served rope is made where the ends are attached to rings and hooks. The hooks are then attached on rings that are located on deck behind the main mast.
[IMG]
[IMG]
The lower and upper blocks are attached to each other due to a 0.6mm rope that's running through the sheaves of both blocks.
A 0.9mm rope is looped through the top of the upper block and then goes through to both lower sheaves of the mast head. On the ends of the rope a pin is attached. This pin holds the weight of the entire yard. That means that the rope on the yard that will be attached to this pin, will be served for extra strength. This is seen on the second last photo.
[IMG]
The next picture shows a sideview of the two ramshead blocks located left from the mast and show some of the details of the pair. Between the blocks a single sheave block is attached to the upper block. The function is simple, the upperblock has less sheaves then the lower block. So a block is placed between them to compensate. Another thing that clearly can be seen are the lines that goes through the back top of the lower block and are not behind the block.
Sometimes the word insanity goes through my head to add these kind of details on this scale....😅
On the right side of the mast, the parrel tackle is located. The rope is attached to a violin block on the top and a single sheave block at the bottom which eventually ends in a hook that's attached to a ring that's located on deck in front of the mast. The end of the rope is attached to a cleat beside the parrel and located on the mast.
[IMG]
The upper part of the parrel. It's the same as on the Foremast however this one has four tracks instead of three. I've used a double sheave block for the rope of the parrel to lash it around the yard.
[IMG]
[IMG]
The last thing for this update is to secure the ends of the rope of the ramshead blocks on the cleats.
[IMG]
Well, some things I did, didn't made it on the pictures, but I will show in the next update. The running rigging that will manage and control the main sail and yard are made next. This will be done after my vacation trip with my family. I wish you happy modeling the next days and thanks for taking time to read and respond in my log!
Peter
The rigging of the main sail is done, it was a race against the clock but it's done before my vacations starts (tomorrow) After my vacation I can start on the Mizzen mast / sail.
[IMG]
[IMG]
The final chapter....
Hello everybody,
As you can see this will be the last building chapter of this model. She is finished! It has been a journey and the end is a bit bittersweet. Sure I'm proud I finished this model and the way it came out, but on the other hand it was a real joy to work on her and by finishing the build, this stops...
However, it's not entirely finished, I still need to make a presentabele stand and a complete photoshoot has to be done as well. This is for later...
For now let me take you on the final steps of the build of the mizzenmast, sail and rigging.
After sewing on the boltrope, I attached the sail to her yard. While under tension, I used boiled potato starch on the cloth and some sugar in a plastic bag to bring the sail to shape. It takes about 12-24 hours to dry and then the sail holds it's final shape.
photo 586146
photo 586147
To hoist the yard, I needed to fabricate the ramshead blocks. In this case this was not an easy job to do. On this scale 1:60, they are really, really small and I wanted to make these blocks the same as the others. So with working sheeves and all......
The upper block is 2mm in width, with sheeves of 2mm in diameter and 0,5mm thick. Again the process is similair as the other blocks and are made out of laminated 0.5mm veneer strips.
photo 586138
photo 586137
When a knife is sharp enough, slices can be cut of the upper block to get to the right size.
photo 586140
photo 586141
I somehow lost the photo of the final product, ah well....they are the same as the others but smaller. Here you see them installed on the ship.
photo 586142
While working on the ship all kinds of hazards and dangers came up her path. In this case a big black and white one who seems to love attention and playing with scale ropes..... No worries, we are good friends and we have a very good mutual understanding. Touching the ship shortens lifes rapidly....
photo 586148
photo 586136
photo 586134
photo 586139
Some kitparts are not needed anymore and are thrown into the bin....
photo 586135
Back on rigging....The principle of the mizzenyard / sail is the same as the two others, however the masthead contains only two sheeves instead of four. Both are used to hoist the yard. Also the parrel is different and much easier constructed. In this case only the trunks (beads) are used. The end of the parrel is tied off beneath the mast foot.
photo 586151
photo 586149
photo 586144
photo 586145
photo 586143
photo 586150
And then the end result. So a final photoshoot will occur soon, but in the mean time this is how she looks!
photo 586152
photo 586153
photo 586154
I have tried to push my limits with the construction of this ship and can say that I succeeded. Pretty much everything about the kit has been changed and I can easily estimate a little over 2500 hours of work that went into this model. Not all hours are construction hours. I suspect I've spent over 250 hours of research and study just trying to figure out specifics about this type of ship. Unfortunately, generalities are known, but the details are missing from these types of ships and there is also very little documentation to be found. Everything is made by hand, the carvings of course gives an extra special character to this ship. The sails and rigging are fully in accordance with a famous French Xebec from the 18th century called Le Requin, the museum model Singe of 1762. https://en.wikipedia.org/wiki/French_xebec_Singe_(1762)
I am also very happy and blessed with you guys as followers who have accompanied and assisted me on this adventure. Thank you so much for the interest, reactions, likes, loves and especially support. Thank you!!!
I hope you will follow me again on the next journey. I have already done a lot of research for this model and that project will also be quite a challenge.
The next update will be a photoshoot with a lot of pictures....
The end.
Peter
This is a spectacular model and a real joy and inspiration to follow. Thank you so much for sharing your detailed progress with us! I will miss this log...
An amazing amount of detailed work on this ship, wonderful work. Will be waiting to see what is up for the next build.
                      :cheers:
Edited by Knocklouder
Yep typos 😒
                   WASA
                   USRC Harriet Lane
Peter, congratulations on finishing this wonderful ship. Your build log has brought me much pleasure. Thank you!
Best Regards……..Paul
Absolutely beautiful ship. Estimating 2,500 hours of work involved... sounds about right for this level of kit bashing.
Looking forward to the photo shoot.
What's next up in the shipyard?
