Thanks for all the likes! I realize there is ton of wonderful stuff here at MSW and your time could be spent elsewhere more profitably! :)  @shipman, do you have any build logs? I’ve tried to look into the work of the various folk who were kind enough to stop by, and I couldn't find any.
Edited by EricWilliamMarshall
I painted some more moldings and bent them to fit the bow. I also added couple planks in back as well. There wasn’t great surfaces for gluing those pieces so I cut notches in the ribs to support the planks.
I made a piece for the bow (I’m not sure of the name of such a part!) but I didn’t like it so I redid it. Cut with a jeweler’s saw, filed, glued and then painted.
At this point, after I added the remaining molding, I realized I needed to add some matching black paint. Luckily, a 000 brush and a steady hand did the trick.
I spent some time working on the 'outside' while I dig up some of the recommended wire for the interior. I added tape for painting the stripes and picked some colors. I had a minor set back. I had some bleed through and I didn't like the stripping once viewed on the boat. I used an #11 blade to remove the bleeding and I used my finger nail and some rough cotton to remove the maroon/brown stripe. In removing the brown stripe, which removed a bit of the black. I repainted the black free hand.
I also spent time with the printed frieze. I sprayed it with hair spray since I didn't have the recommended varnish. I used an #11 blade to cut the shape out.  I used some white glue - I poured it on to my 'pallet' - a plastic yogurt lid and added a little water so it was thinner but still tacky. I used a watercolor brush to apply the glue to the boat's surface and then applied the paper starting at the bow and working to the rear, ensuring there were no wrinkles.
I made some more moldings and I think I have the hang of it finally. But have to work very slow to get reasonable results. My brass scraper is a tad wider than some of strips of wood and that is 'dangerous' to the out come unless I'm slow. I painted the moldings and applied them. I used a different pattern than suggested in the kit for the lower molding but in keeping with molding of the 18th century. (It is a poor rip-off from Chippendale's design book.) My heat bending wasn't as smooth as before for the moldings and I broke one trying to sand it. I simply applied them as two parts with extra care to knit together the ripped fibers. You can see my expensive palettes in the first shot as well as my glue applicator - a pin mounted in a long pin vise.
I found a few interesting images of similar period/contemporary models in Kriegstein Collection’s book by the Kriegstein brothers. Obviously all rights reserved regarding their book and images.
Excellent addition!
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Thanks for the kind words!
I flatten some brass wire and bent it around the supplied rings. I then chemically blacken them and when dry I attached them.
Very neat, and nicely in scale. Kit-supplied rings often look too large, but yours are just right. I also like the way you've bent wire round the ring - much more realistic than putting the ring on an eyelet.
Cheers, Derek
As always, thank you for your kind words. I found just bending my tiny strip over the ring wasn’t snug and the strip poked into the center of the ring. I’m not sure how others approach this, but used a slender awl inside the ring to force the strip to the edge of the ring and then used needle nose pliers to crimp the the strip. It gives a nice effect, even if my photography doesn’t display that. It is a quick operation. Thanks for noticing!
More fun with strips from hammered wire. I made hinges that match the plans, which differ from the prototype model. Two flat strips with a bit of wire and a passible hinge. The nail heads are just dots of cyanoacetate glue dabbed on.
Some lovely details on what is already a very  nice build, Eric.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you ever so much @Edwardkenway! Little by little!
I worked on the metal strip that sits on the bow. I bent a piece of 1/64” brass scrap with a pair of small needle-nose pliers over an extra bit of keel (as you may remember, Model Expo sent me a replacement sheet due to my false start).
I traced an outline around the cutouts for the splash rails to suggest an inset frame. While I sanded them, I forgot to sand them down as much as suggested in the manual.
I saw Tom Ruggiero’s build and he installed vertical wood work under the seats. He argues that there would be benches there. He carved his panels but I didn’t think I could do that cleanly, so I built up mine. This would have been quicker if it occurred to me earlier. :)
For my faux benches, I want to emulate panel and rail construction that would be correct to the period. There was a lot of test fitting, since I couldn’t measure any of the angles (and almost none are right angles), which required the use of tweezers to do!  The last image is a test fit.
I was thinking about some the blank spaces that might be decorated. There is a lot acanthus leaf scrollwork! I haven’t truly wrapped my mind around how these ‘decorative systems’ work. Here is page of my pokes and nudges in that direction.
I also finished the faux cabinet work under the rear benches. I didn’t bevel the insets, but I should have though.
More nice touches - you're certainly making this model your own.
Cheers, Derek
Thank you Derek; I’m trying to work up to challenges like your HMS Speedy. I built a shooting board to help with small cuts for the oar locks. I tried to be clever and section a chunk of wood which I could slice off the pieces as needed. That failed so I sawed, chiseled and sanded lightly. I used the clamped scrap as a stop to ensure I cut at the same depth.
I experimented with how to represent nails or tree nails with varying success. I can make them very small, as I’m not crazy about the larger size attempts I’ve seen using toothpicks. I found bamboo splinters, small gauge wire, guitar strings and synthetic line all work and give a good size. However it is too subtle to be seen on the hull! As you can see in the forth photo down, the tree nails are almost impossible to see!
I added the oar locks as well and started on the rudder.
I missed a bit and added it as part of the rudder work. I also tried my hand at some more decoration. I sketched an image which I glued to a thin bit of wood. I attempted to carve it but it keep falling a part. I’m not thrilled with it. I’m curious what the panel of experts think: I should I keep it or toss it?
That’s a very decent first attempt - certainly better than my woeful attempts at carving! I suspect a little fettling with fine files and sandpaper to round off the edges would make it very presentable.
Cheers, Derek
