Keith,
Go here:  http://modelshipworldforum.com/ship-model-furniture-and-deck-fittings.php  about halfway down the page....
hello Keith . yeha when researching i saw that and wil be checking out some stores :)
no flickering lights . it would require more knowledge of electronics then i have :). when she is done and i have shown off to all the "interested" people i doubt th elights wil be on much
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
I looked that over Mark and it says in the dimming LED part "In a future update of this article I will present a simple electronic circuit to achieve this and also a cicuit to make an LED flicker like a candle."
but I didnt see any updates on the flicker mechanism. Thanks for the link.
Based on my past electrical experiences it seemed without trying there were times when I could wire a lamp or such so that it flickered off and on.... I wasn't even going for that effect either.. woo hoo... :blink:
It's a gift... :)
keith  its in this tutorial : http://modelshipworldforum.com/resources/furniture/Flickering_LED_Tutorial.pdf
i decided to finish off the steering cabin. all that was left was the wiring.
bottom bit. both wires are black as red would have been to noticable. (i marked plus and minus to keep them apart)
top. this part can be taken out together with the top of the cabin
finished the walk way (i have also added the chains but didnt take a pic of that)
finaly after varnishing the second deck and finishing of some of the windows in the doors i have glued the 3rd deck on. it all fits nicely.
Nice job Adrieke, the wiring gives such a lot of extra work, but I am sure that at the end it will pay off.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
thanks John. so far the lights are still working :) . i stil need to rethink how i wil be wiring up the back 4 rooms of the 3rd deck stateroom but i am sure i ll find a solution :)
with the 3rd deck on i can now start adding the first and second deck headposts. rememebr thta i made a square hole in the 3rd deck . i am now doign the same on the 3rd deck and then sliding the headposts in. since they curve a bit a 1mm brasswire bit is glued in the bottom to hold it in place
you can also see the bit of the small smokestacks that go into the engineroom. i mitre cut the dowel then rounded it a bit to get the bend
the 3 struts that i asume are there to give support for the overhanging first deck are also cut and drilled.
the last picture shows 3 of the headposts in place :)
Edited by Adrieke
Nice job Adrieke, you are well progressing.
Regards,
John
<br />
<br />
thanks Wim,John,Randy and Robbyn :)
compared to the last few weeks, things are speeding up now. thanks to the preparations  the headposts go pretty quickly :)
i have done 9 in total now 3 more to go on this side which i am hoping to finish tomorrow. i do need to keep checking as i am doing everything totaly out of sequence compared to the instructions and i dont want to forget something
Keep on going strong Adrieke! She's coming 'round very nicely.
Carl
thanks Sjors Carl and David :)
before i finishing the headposts on the second deck i think i better put the stairs in place
i created a shape in a balsa block to make sure i bend the stair railings all the same :)
i wil have to treenail the 3rd deck first before adding those railings
headposts on first deck on one side mostly done now except for the front one (need to a bit of touch up paiting on the curved stairs) the decond level i am waiting for the stairs to install
look of the first stairs in place
Nice job Adrieke, real fun adding those details which are completing the decks.
Regards,
John
<br />
<br />
yup John i really love this part :)
btw i just realised i am going to run out of eyebolts very soon. acording to the partlist 30 are needed.
a quick calculation : 8 for the doors on deck 1, 8 more for the chains on the 2 openings. 4 for the cable that holds up the first deck, 4 more for the walkway . about 7 more for tying of the walkway . 9 for the walkway with chain itself. 16 for the 4 cables on each of the large smoke stacks. tahts already 56 and i have probably forgotten a few :(
This is what I'm in the middle of now. I came to the same problems as you with the boiler room and engine room not alining up. I had thought about extending the structure but instead I had done just as you had. Planking the hull I had just enough strips but way to close for comfort. Thanks, reading this has given me a heads up for possible problems later in the build, keep up the great work!
Regards, Scott
Completed builds:
Awaiting construction:
Adrieke,
Looking real good!   Still looking for your post on the other site...... :D :D
Cheers,
Jim
:cheers:
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
That close up view makes her look so realistic and life like. I can imagine myself walking along the deck and going down those stairs. She is looking Great!
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
@Scott thank you . i hope we l be seeing a buildlog of yours too. dont forget because you wetn the same way as me you wil need to adjust the slots in the 3rd deck other wise the smoke stack holes and the edges of the deck wil not line up correctly
@ Jim thanks. this one is taking up all my time for now. whem she is finished and i am workign on the endeavour i am pretty sure there is going to be time for me to restart on the stagecoach :)
@ Robbyn thank you this is the part i am loving finishing off and creating all the detail . looking forward to when its all in place on the lower 2 decks and turn on the lights :)
@Sjors its next to the engine room (dont want anyone fallign down the stairs late at night :) ) i am affraid i only wil be serving belgian beer though :cheers:
only belgian beer on an american icon... yeah, that'll work ;)
I guess if she were based out of St. Louis, the only beer available would be Budwieser..  :unsure:
Mark,
Adrieke is talking 'BEER', the stuff you get drunk on two or three bottles :P:D;)
Carl
haha randy i am the captain and i am not sailing without my beer :piratetongueor4:
honestly never drunk budweiser Mark ^_^
Carl knows what i am talking about ;) and they l be served in the correct glass too
i had taken this monday off and decided to finish of the display
the front pedestal holds the wiring while teh back one has a screw going into the keel for extra stability
fixed the broken rudder too
and here is how she looks now
the rest of the build she ll be supported by some cut up pool noodle so i dont accidentaly put top much pressure on the pedestals
Nice Adrieke, she gets really shape now.
Regards,
John
<br />
<br />
