slowly adding more details :
railings around staircase, benches , kitchen smokestacks, walkway
when all that is done I will varnish the top two decks
fitted the brass rings and eyebolts to the first smoke stack and repainted it
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Looks good the details on the schip, very nice
Robert
Current builds:
Prins Willem - Corel
H.M.S. Victory - Deagostini
Complete Project: San Fransisco II Artesania. / King of the Mississippi Artesania
Hello Adriaan,
If you have not yet "invented' a fixture to shape your dowels perhaps I have a very simple and cheap way to do that.  The whole purpose is to prevent the dowel from whipping about and to give it support at the loose end.
When I had to make the masts for my VOC ship I used a plastic or nylon cutting board and drilled a hole in it slightly larger then the dowel.  This I clamped into a bench vice and chucked the dowel into my drill press.  I positioned the vice with the cutting board under the dowel and raised the drill press table up until the dowel was in the hole.  Next I clamped the vice to the drill press table and had at it.  I could have held on to the vice with one hand and use the other with a sanding block but I like to use both hands.
You can make a similar jig with your hand drill on a table or work bench.  Just align your cutting board support in a vice, or your even your hand, so that the dowel will fit nice and loosely in the hole.  Turn the drill motor on low to see how it behaves and when you have enough confidence in it working increase the drill speed and have at it.
If the cutting board is narrow enough to hold it comfortably by hand you have enough control to make it work for yo.
The whole object is to support the loose end of the dowel and this will work.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
that sounds easy to do Piet. i might give that a try for when i have to taper the ones for the GF
Piet, could you attach a picture of your fix...I would be very interested in seeing what you have described before I need to taper the masts for my current build
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Hello Robbin and Adriaan and others if interested,
Yes, of course I'll recreate my set-up for yuns  :)   Give me some time like a day or two, I have something else going that takes priority.
I'll just use my small drill press but the principle should work for even a Dremmel set-up.
Cheers,
                       VOC Ship Surabaya
Me too
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hello Adriaan and Robbyn and J. Pett and whomever  :)
It's now Friday afternoon in sunny or kinda partly sunny, Palm Coast, Florida.  Lunch is done with, mail has been looked at and It's time to share a few pics of my el cheapo spar sanding jig.  First thing this morning I was hunting for my old jig but that proved fruitless so I made a new one just for yuns  :)  :)
I also drafted the Admiral, my dear bride Gwen of now close to 51 years of putting up with me to take a few action shots.  Naturally she asked many questions and I was obliged to answer them.  Hey, her dad retired as captain with the KPM  ;)  ;)
Okay here goes and remember that this can be adapted for use on large drilling machines down to the Dremmel.
An old nylon kitchen cutting board.  Pic taken after I already cut a small part out, an afterthought.
This is the small part I cut out from the cutting board and already drilled a few holes in it.  Make the holes a little oversize from the dowel(s) you are using for the masts and or spars.
Here a test dowel is chucked in the Jacobs chuck.  Be gentle with tightening your dowel.  I used my nice and sturdy drill press vice to give me something solid and for clamping it to the drill press table.
Here I have clamped the small nylon piece in the vice making sure it's kinda, sorta square to the dowel.  It really doesn't matter too much because of the slightly oversize hole.
Here I have positioned the vice with the nylon thingy under the dowel ready to raise the table up and engage the dowel into the nylon thingy.
Here I have raised the drill press table up and the dowel fits nice and loosely in the hole.
These are two examples of my sanding blocks.  As you can see they are home made.  The large one has a course grit sandpaper on it and the small one has 360 grit sandpaper for finishing.  I find that using a long sanding block gives you better control and handle.  The large one is very good for fairing ribs or bulkheads.
To be continued on next post.
Cheers,
                       VOC Ship Surabaya
Piet,
If you get a chance, could you post this jig in the Tool Making and Jigs area http://modelshipworld.com/index.php?/forum/17-wooden-tips-and-tricks-and-making-jigs/???   I think it would be good for others to see.
Continuation of mast / spar sanding jig.
I am using the larger sanding block with course sandpaper and one handed too  ;)  All the way on the right bottom of the pic you can just make out one of the clamps I used to secure the vice to the drill press table.  This way we can use one hand for the sanding.  Don't use too much pressure on the dowel, especially when sanding thin dowels.  Also, the speed should not be too high, there is no need for that.  Let the sandpaper do the work - - - gently, take your time and use a dust mask!!  When you approach the end of your spar, which is now very thin you'll have to switch over to fine sandpaper and finish it off.  Frequent measuring in between is also advisable, this also gives the wood and the nylon a chance to cool down some.  You can now also cut off the thicker portion of the dowel that's inside the nylon thingy and drill or use a small hole to continue or use the hand-held method shown further down.   All of this may take some getting used to but after a few you'll get the hang of it.  You can also use a a piece of sandpaper hand-held between fingers and thumb, if you dare of course  ;)
A demo in using the small sanding block for the finishing touch but hand-held sanding works also.
For demo purposes I am now not using the nylon jig thingy but when you do this you MUST back-up the sanding block with a piece of hardwood.  If you don't your dowel will brake at the drill chuck.  And again, don't use much pressure on the dowel when sanding.  I found that making a groove in the back-up block helps in keeping the dowel centered to the drill chuck.  Here hand-held sanding works really well but it gets pretty warm though, you'll quickly find that you'll have to easy off in between applying pressure.
I apologize for the fuzzy pic, I moved my hand but you get the idea.  I am showing a hand-held method with a portable drill motor.  I didn't show it clamped here but you understand that you MUST secure your drill motor.  Set the drill motor speed to medium, not too fast and not too slow.
Before we switch on the drill motor with a preset speed, we slide the nylon thingy onto the dowel and position your hand FIRMLY to the table or board and switch on the drill motor.  You may be apprehensive or afraid in doing this but believe me, the dowel will automatically seek equilibrium and directs your hand to center itself.  Now with your free hand you can gently use your favorite sanding block and let the dust fly  :)  :)  with a dust mask on, please.
The whole purpose is to support your dowel at the opposite end from your drill motor or drill press.  When taper sanding small spars, where the ends are very small, like 1 mm perhaps, you may have to drill a small hole in the nylon thingy to support that small end.  After a while of doing this you'll get the hang of it and produce spars by the dozen ;)  ;)   Hmmmm, maybe I'll go into business making spars - - - not  :)
I hope this method works well for you as it did for me.  Now I better put that small nylon jig thingy in a safe place where I can find it because I have a bunch of spars to make for my neglected VOC ship.
Cheers,
                       VOC Ship Surabaya
Hello Mark,
Yes, will do.  I can copy - past this entire section.  It'll be tomorrow evening though before I get to it.
Cheers,
                       VOC Ship Surabaya
Piet, thank you soooo much for that tutorial...such an easy fix really but brilliant way to re-purpose some old cutting board. I can't wait to try that now!!!
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
Ahoy Piet :D
Thank you, excellent idea
If you do post it as Mark has asked please send me a link so I can include it in my Tips thread.
Thank you too Adrieke for making/letting this happen
Cool beans
  J.Pett
Thanks Piet
I was thinking of something much more complex , this is easy and can be used by anyone :)
Happy to oblige and glad it's useful to all yuns ship builders.
Cheers,
                       VOC Ship Surabaya
another small update
fitted the first two curved railings . they where a bit awkward as the head posts have different angles there but I think I got them pretty ok. will se when the glue dries
Adrieke could tell you what kind of glue you've used for gluing the railing?  :mellow:
Robert
Current builds:
Robert
I use the standard white wood glue to fix the wooden parts to the posts and CA to fix the bras railing parts to the wooden parts
Robert
Thanks
Robert
Current builds:
last night when i was working on the last stairs i realised that i made a mistake :(
the top walk way at the steering cabin (the diveboard) inst sticking out enough so the ladder was against the 3rd deck . that wouldnt have been an issue but the
handrails wouldt be on the edge anymore (i ll explain better when iupload the picture)
so i had to remove the whole top assembly (all is stil intact) and ladder
i am repositioning the feet so it will sit properly this time
ok here before correcting the mistake
you can see that the outside of the ladder is flush with the top walkway but not with the bottom one
the handrail going up would be on an angle if I left like that
with the diving board extended more the ladder is not flush with the top walkway leaving room for the handrails witch will be straight now
Hi Andriaan, good catch and good fix.  It's all part of the fun  :)
Cheers,
                       VOC Ship Surabaya
well there vary nice work yes adrieke  i took some needed time off my paddle boat i will get back to it real soon  p.s keep up the great work
thanks dragzz :)
finished the walkway to the steering cabin
all that is left now is to drill the holes for the eyebolts for the cabling that secures the smoke stacks
then I will varnish the decks
after that :
steam stacks (4 off them)
poles that hold up the first deck
2 masts
walkway
capstan
railings
almost :)
Look's really good Adrieke.
Robert
Current builds:
thanks Robert :)
thanks sudomekh. the stairs and railings are done according to the manual. all I will do is sand and clean up a bit :)
