I found small (appropriately 1.5” x 1.5 x 6”)  pieces of boxwood online at Esty. I ordered one and the piece is beautiful...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Allan; Castillo was the name I saw. When I get home this evening I can take a picture if that would help...Moab (aka Allan)
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
Castello (sp) is a South American hardwood that is a good substitute for true boxwood (buxus). Also sometimes called Bermuda boxwood, Castello is a paler yellow than true boxwood when cut, but mellows in color with age.
Somewhere in the past I saw a VERY hard tree nut (something like golf ball size, or a little larger) that was touted as a substitute for ivory for small carvings and turnings.  Maybe that could 'ring a bell' for some, and perhaps there are modern compounds that are 'ivory substitutes' that could also be cut, carved and turned.
Tagua nuts.  https://www.amazon.com/10-Eco-friendly-easy-carve-tagua-nuts/dp/B0002IXM3C
Intricately Carved 16-Century Prayer Nuts Open to Reveal Incredibly  Detailed Scenes
tagua nut carving- beautiful work | Wooden art, Tagua nuts, Carving
"Solid surface" material, originally patented by DuPont as "Corian" and used for countertops and other work surfaces, and now manufactured by others as well, comes in a huge selection of colors including ivory and is easily machined and glued with epoxy adhesive.  It was originally only sold wholesale to installers and was only available to licensed fabricators and installers, but now may be more obtainable by the general public. It's quite expensive in large sheets, but one may be able to secure relatively small offcuts from fabricators. I got an offcut sheet large enough to serve as the top of an extension table for my cabinet saw for $100 "under the table and out the back door" of a fabricator. They had no use for it because it was left over from a job and was a nauseating puke green color. :D The stuff is cut and machined with woodworking tools. I've never tried to carve it with carving knives and chisels, but it can be carved with burs and sands easily.
If making ship models required this level of carving
I'd have to give it up.
Amazing.
Edited by RichardG
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
Tagua nuts can fairly big (50mm) however they apparently always have a void somewhere inside, so I don't think they'd work for large figure heads. For smaller decorative carvings they could be really good - no grain and they can be dyed. You can even buy slices. My carving abilities are zero at the moment but a couple of my planned builds have some carving needed.
Has anyone here used them?
Richard
The carving reminds me of the amazing boxwood carvings in the Art Gallery of Ontario. Check out this fabulous article by the museum and click on chapters to see some amazing carvings (especially the Prayer nuts in chapters 4-6)!
http://boxwood.ago.ca/publication/small-wonders-late-gothic-boxwood-micro-carvings-low-countries
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
You can find smaller pieces (pen blanks) of the Castello and the like more easily than the larger stuff that's for sure.   Very interested in those tagua nuts, thanks for sharing!
Just an interesting possibility:
Before I moved to Asheville (where Holly bushes/trees grow wild in many places) I lived in Stamford Ct northeast of New York city.  My neighbors had LARGE boxwood bushes in their backyard..8 - 12 ft, high.  The trunks were only 6" - 8" ion diameter but there were branches 2" - 3" thick.=, some of which were pruned off now and then.  I got one piece from them of about 2 1/2" inches in diameter and about 3 feet long which seems to me to contain  great wood for modelling, though my building has pretty much stopped and I haven't used much of it.
My point is that there may be sources in your area which can provide resources often overlooked.
 I don't know whether or not this is true boxwood.The wood is yellowish not white, but the hardness and grain is great.
Buxus is yellow and the there is not much difference in Spring and Summer wood and the  rings are narrow and close together - slow growing - very hard.  A look on line will display a variety of cultivars - tall and slender to low growing and wide spreading - with a range in between.  It is probable that there will be minor differences the nature of the wood.
Holly - I have wood from a cultivar with a yellowish color.  The wood is almost grain free in appearance - white or yellow - it bends easily.  If snow white in color is not of interest (and no wood ever used to plank a deck was close to being as white as Holly), even the Blue mold infected pieces will work for most everything.  It is said that it takes up dye well enough to be an excellent substitute for Ebony.  If there is a local company that harvests Holly, they may give you their infected wood for free.  Their customers want the white color only. They do not care that the wood is still just as sound.
You should check the Pisgah region for Dogwood.  Cornus florida is also about as hard as Boxwood.  It does not have a trunk large enough to supply practical framing  or planking stock for a model above miniature scales, but for carving and deck furniture, yards and other small delicate components, it is worth the effort to harvest it.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
