Amazing and inspirative, as always. A lot to enjoy it and a lot to learn.
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Thank you Nenad,
I`m happy if some Points were of help to you, I also find many helpful inspirations on MSW. Hope you are now pleased with your CS plating work
Nils
Current builds
-Lightship Elbe 1
Completed
"Violin" blocks...
I noticed that there are some 7 mm high violin blocks with each two staggered single sheaved rollers shown on the plan. Actualy a regular double sheaved block would do the same function, but OK it may be an 18th century speciality to use violin blocks. So I searched the web in vain trying to find 7 mm violin blocks. Those found were of so poor Quality that I decided to do them myself this morning. Here is a prototype one....
two woodrods (5 and 3 mm diam.) were shafted together, whereby the 5mm one gets a concave outcut over the length. Both are glued together with PA. Borings drilled, and rope guide groove put on. Then cut the part in slices carefuly and do fine Tuning..., groove for stops, etc...
Build log part 40 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils -- the shots of your forecastle are fascinating, and these violin (or "fiddle"?) blocks are absolutely ingenious!!  I'm sure your technique here will be copied widely -- certainly by me.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thank you B.E. and Martin,
both your words are very much appreciated. I will be doing the gun Tackling next, and then installing the messenger and the gundeck capstan, because I want to put on forecastle- and the Quarterdeck permanently. There is a drawer full of finished parts waiting to be mounted when the decks are on.
In the meantime I am grooving myself in for the rigging System, in order to understand the function of each of the lines and various operational ropes
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Geoff...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, just been catching up with your log, and have to say that Pegasus is looking tremendous. :)
Yes, the aligning of the deadeyes is a bit critical. I used the length-of-string method on my Sherbourne, worrying that all the deadeyes would be at the right angle. Lo and behold, when it came to actually rigging the shrouds – they were! I breathed a sigh of relief then, I can tell you!
With all the forethought you've put in on this, I don't think you'll have many problems.
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
Hi Crackers and Kester,
thank you for looking in on the log, and for your comments
I just cut off a complete drilled and slotted slice of the violin "raw bar" it fell onto the carpet and went lost in nirvana, like many small parts before..., shi...
Kester, this Feeling you experienced with your Sherbourne, untill hopefully the sigh of relief Comes I am going through right now myself...
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
When I clicked the like 'button', I wasn't of course referring to the first part of your post!
All I can say about that is: 1) It happens, usually at the most awkward moment; 2) I find a few choice words often help; 3) when you've calmed down a bit, you start all over again... sigh. :(
Kester
Nils, If I got a Dime for every small part that I lost , ( usually its a part that I spent alot of time making )  I would be a wealthy man , While I was building the billings Dragon,I ripped open the vaccum cleaner bag looking for parts, at that time I lost the gooseneck and some other parts . Fortunatly I did find the gooseneck but the other parts , I have no idea
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Nils I have complete sympathy.  Years ago I spent a week working on a miniture pump.  I was doing a final cleaning before blackening and it went ping into the sea of last parts.  I found it a month later after I made a duplicate.
David B
so it is David....
I catch myself every time on knees and elbows swaying / feeling the Hands over the carpet when one of these parts has fallen down, bounced a few times on the carpet taking an undefinated direction, and I unfortunately could not track the flight curve so quickly,..... it must be here, it ca`nt vanish, shall I make a new one or give it another search, extending the square meters. I trust we all know this Situation very well, its probably part of the game...
Nils
Current builds
-Lightship Elbe 1
Completed
Har Spy!!  That would be the longest thread on the site!   B)
Nils, you have my sympathy.  Everytime I'm down on my elbows and knees looking for that d*** little piece, my dog decides to join me and put her wet nose in my face while sitting on the very spot where I'm sure the piece went.  If I ever do find it, though, it's usually way off on the other side of the room.
Cheers,
Martin
Build log part 40
Working on the gun tacklings in the Moment....
this is a very weary Job with these good looking but very small 3mm blocks ( single and double).
Instead of cotton rope I used 100 % Polyester thread in natural hemp Color, which Looks the same, but gives the possibility to thin out the Ends (soft flame / heat) for doing the sheaving through the tiny holes
there are left and right Tacklings and the carriage backing tackle
the breech ropes are all pretackled to the carriages
this Little device helps to pretackle the blocks
I do 6 at a time (for two guns)
the runner Ends are not belayed properly yet.
This first test mounting was just to see if the Position can be achieved with the 3 Tacklings only
I think I`m not going to glue the carriages to the deck
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work Nils, Very well done
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
That is a nice fixture you made Nils.  How did you think of it?
David B
Edited by dgbot
David B
Hi David,
the thought was first to prevent those Tacklings from getting all twisted up from alone (without doing anything to cause that) if I just lay them on my deskboard...
and second, to get them easyer hooked into the bulwarks eyelets, I would possibly have become an heartattack by Tackling on the ship...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils:
So glad I have run across your beautiful work. I really love the cutaway hull....really enjoy learning new techniques from master builders such as yourself. Thanks for sharing.
Dave
Thanks for your appreciative words Dave,
I also had a look at your ships on the web, it`s a nice Homepage I like with lovely built displayed models
Nils
Current builds
-Lightship Elbe 1
Completed
I don’t know how I missed this build for so long.  But I’m here now to admire and learn from your fantastic skills.  Thanks for sharing.
Bob
Current build:  SS_ Mariefred
Thank you very much Bob
Nils
Current builds
-Lightship Elbe 1
Completed
cannon and lashings look great Nils.........very nicely done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Popeye,
rigging those small 3 mm blocks is driving me crazy, especialy when the neat tackle is taken from the seperate pretackling device and transfered to the positions on the gundeck....., the tackle trys to tangle up and twist extreme. I have also given up my own Obligation not glue the carriages on...., but now CA helps to secure the Position. Would love to hear what fellow builders do in that case ?
Nils
Here some pics of the gun Tackling, I started with the most difficult ones under the forecastle deck
here also the horizontal beam with the maessenger return rollers, it also supports the anchor cable above the Manager board an -pit
the riding bit is pushed in a bit too deep (still loose) on the left side, thas why it does not apear straight here
Nils
Current builds
-Lightship Elbe 1
Completed
Amazing work and detail Nils, Beautifully done , Very impressive
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Pete,
your nice comment is much appreciated...
The gun Tackling is quite time intensive and may take the whole week, if the house gardening work outside does not take overhand
Nils
Current builds
-Lightship Elbe 1
Completed
Oh David,
I have by no means a mastermind and with my 66 years I have to write a list for groceries from the Supermarket every time I go, in order not to forget half of it. When modeling, my mind goes at ease, when I have an idea to a solution I have the strive to see quite quickly if it works...., scetch, dummy, mock up, etc..., you`re right, maybe a Little gaga sometimes
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Nils
Looking good, nice bit of work
Cheers
Geoff
Nils
Current builds
-Lightship Elbe 1
Completed
