HMS Victory by drobinson02199 - FINISHED - Caldercraft - Scale 1:72
Bowsprit yards done and mounted.  Pictures show bow-on view with some arrows added so the yards are more identifiable, and a top-down view.
Now the real rigging can start!
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter
Currently Building:  Amati Bismarck
Link to comment
Share on other sites
Finished the foremast yard lifts and sheets (plus "bunt" and "clew" lines, whatever those are).
I used flash in the dark with no white background so the rigging would show up.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Main mast yard lifts, sheets, buntlines and clewlines done.
Regards,
David
David Robinson
Boston, MA area
Link to comment
The lifts, sheets, buntlines and cluelines are now done on all 3 masts and the bowsprit.  Pictures attached.
Next step is braces.  It moves along more quickly once you get to the "real" rigging stage.
Regards,
David
David Robinson
Boston, MA area
Link to comment
A note on the rather odd backgrounds you may notice in my more recent pictures.  When I started building the yards, I needed to clear my workbench, so I moved the ship on top of some large boxes that contain case lots of household supplies -- something we started doing during Covid and have kept up.
What I found was that I could get to both sides of the ship easily without having to rotate it all the time.  The hull is just below chest level, so the masts and yards are at a perfect height when I'm standing up.  So I bought a headlamp (mentioned earlier) to provide a good worklight in that area, and that's where I've been mounting yards and doing rigging.  Works pretty well -- but it's why you see those odd "basement" backgrounds.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Braces now done.  Next step is the boom and gaff, which look semi-complex to build and to rig.
Regards,
David
David Robinson
Boston, MA area
Link to comment
The rigging looks so complicated and intricate! You're doing a wonderful job of working your way through it all, David.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Finished building, mounting and rigging the Driver Gaff.  One of these pics shows the gaff better, and the other one shows the rigging bettter.
One comment:  the instructions say to rig both the mizzen top yard and the mizzen topgallant yard braces before rigging the vang.  I did the top yard brace because the angles put some downward pull on the gaff, but the topgallant brace would pull up.  So after the top yard brace I rigged the vang, which puts nice downward pull on the gaff and also helps to align it side to side.  Then the topgallant brace and I could put some tension on it because the vang anchored the gaff down.  Just a small note for those who might be building a step or two behind me.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Driver boom built, mounted and rigged.  Also the jackstaff for the ensign.
Regarding the ensign:  there are no flags supplied with this model, and I thought a small ensign would be a nice addition.  So I researched British ensigns of that period, and found a good picture that I could download.  I then used Photoshop to resize it, and also to do a "flip horizontal" on the image so that the backside would come out properly.
Looks nice on the model.
You may notice that the lanterns aren't on.  I held off on that to avoid pranging them, but now that the boom sort of "protects" that area, I can add them at any time.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Fore and main cluelines, tacks and sheets done.
Some of these go through holes in the hull and are anchored below the skids.  It's super difficult to do that last, when you are trying to tension the lines.  So I started there, got them anchored, and then rigged back to the eyebolts on the exterior of the hull -- and it's easy to tension there.  Three points of tension have to be balanced at the same time.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Quarter davits done.  A few comments on these:
  • I have not yet fixed the running end of the lifts, and that's because I won't know how far out I want them to swing until I build the boats and decide which ones I want to hang on the davits.  The plastic clip you see provides some mild tension on the lift for now.
  • I left them natural walnut (vs. painting black) to provide some interest and make them more visible.  They have not been varnished yet, because when I do that I will probably cause the hinges to seize, so again I need to wait until I have the angle set and the boats hung.  So they look a little rough right now.
There will be block & tackle for the boats -- I'll add that when I hang them.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Finished rigging the bowsprit guy lines.  The red arrow shows them running up in parallel from the beakhead to the spritsail yard, and then diverging to different points on the sprit.
The manual wants you to use a single thread for both sides of the black line, which requires you to seize a block into the attached line near the beakhead, and which would make precise alignment difficult (or impossible for me).  So I started at the beakhead end with one line per side, got the blocks lined up (with a slight slant to the stern to match the direction of the guys), and then attached them to the appropriate points on the sprit.  Not sure why the manual doesn't do it that way.
OK, getting close now.  What's left for the main ship is the anchors and the lanterns.  Then I will build the small boats.
Regards,
David
Edited by drobinson02199
David Robinson
Boston, MA area
Link to comment
Something odd in my kit.  When I went to get the anchor stocks -- 8 needed -- there were only 7 in the wood sheet.  There isn't an eighth anywhere.
The parts book says 8.  But curiously, there is no drawing of that wood sheet in the book.  If you look below, you will see a finished sheet with even sides and only 7 stock halves.  Really, really odd.
So I had to make one, which I did out of a scrap piece of the 5mm walnut sheet, sanded down to 4mm thick and then shaped.  I have since sanded the mounted stocks you see below, and now have painted them black (no picture here of that), and you can't tell which one has the handmade stock.  So all's well that ends well -- but really odd with that finished sheet and missing one stock.
Regards,
David
David Robinson
Boston, MA area
Link to comment
No, I looked all over.  And even weirder now that I see your totally logical two sheets of four.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Anchors Aweigh!
Regards,
David
David Robinson
Boston, MA area
Link to comment
Something of a milestone here.  I haven't finished the project yet, but I have finished all of the work on the ship itself (except for adjusting the davits).  What remains is building the four small boats.  I started this ship in June, 2021 -- so at 2 years one month (and not yet quite finished) this is my longest build.
Pictures below show the stern and main mast lanterns.
I also got the ship off of the temporary cradle and onto brass mounting columns.  But it's a really HEAVY ship, and had too much lateral sway, so I added two small wood columns under the hull and now it's solid as a rock.  A couple of pictures below showing that.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Your model is incredible.  As big and detailed as it is, 2 years is not very long.  Someday I hope this kit will be my retirement gift to myself.
Edited by RossR
Completed Build:   HMS Beagle - Occre
Current Builds:       Frigate Diana - Occre  https://modelshipworld.com/topic/33530-frigate-diana-by-rossr-occre-185/
Santisima Trinidad - Occre - Cross Section https://modelshipworld.com/topic/37130-santisima-trinidad-by-rossr-occre-190-cross-section/
On the Shelf:           NRG Half Hull, the US Brig Syren - Model Shipways and USF Essex - Model Shipways
Link to comment
Thanks, Ross.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Thanks, Bob
David Robinson
Boston, MA area
Link to comment
Thanks, Zappto
David Robinson
Boston, MA area
Link to comment
I have built the largest of the four small boats that come with the kit -- the launch.  Took me about a week.  The boat is double-planked, and even though it's small, the planks are small too so it takes some time.
I took a few liberties vs. the instructions:
  • I used 1 x 4 maple for the flooring vs. the .5 x 3 walnut that was called for.  My original reason was a concern about having enough .05 x 3 strips to do all four boats, but as time passed that became moot (see below).  Actually, I kind of like the contrast.
  • I bypassed the winch, which in the pictures of the boat makes it look kind of messy to my eye, so I just left it off.  I'm all for visual appeal vs. historical accuracy.
  • The instructions call for the gunwale to be yellow, but I used red to give some "snap" to the look of the launch.
  • I left out the oars, which didn't paint well, and the rudder piece, which is supposed to be stored in the boat when not in use -- and I just didn't want to junk it up.
Pulling back to the boats overall -- I have decided to just build one more, the cutter.  It's a perfect size to fit on the rear davits, and I want to hang a boat off those davits on the "display" side.  In addition, if you build the launch, barge and pinnace, when you mount them on the skid beams side by side, you obscure all the nice detail below.  I kind of like the look of just one boat on the skid beams, so I mounted the launch, finished positioning the hoists, and that's what you see here.
Regards,
David
David Robinson
Boston, MA area
Link to comment
FINISHED!  My 2 year one month build is finally done.
The last step was building the cutter and mounting it on the rear quarter davits.  Pictures of that here, plus one full view of the ship.
A set of completion pictures with different views of the model is posted in the gallery of kit-built models.
Thanks to all of you who came along for the ride -- I appreciated the support.
Regards,
David
David Robinson
Boston, MA area
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
