End for the tension adjusters for the rigging on the Orca....one done 11 more to go!? It's gonna be a long weekend!?
Made from brass wire, 4 00-90 washers and a 00-90 bolt without the head for the end, and one cut to length for the attachment point.
Neal DeConte
Rhode Island
COMPLETED: 35" Orca Boat movie replica, first wooden/scratch built boat
  • 3 months later...
I have refined the assembly of the tension adjuster end...... Ended up using some .090 bolts and sending them smooth for the attachment ends. The turnbuckles you see here were cast in a very durable urethane, they actually work!
Also invested in a new soldering iron which really made a difference!
Neal DeConte
Rhode Island
Some photos of the ladder that was soldered together out of brass wire. The mounting ends were made out of punched styrene sheet and some styrene rod that was beveled and glued together.
The wrap is a combination of Coxcombing and a three line reverse coxcombing.
Neal DeConte
Rhode Island
What fine detail.  I'm ready to step aboard and let's go fishing.
Bob
Current build:  SS_ Mariefred
Navigation lights were made from a piece of clear acrylic rod which had the center embossed line done on the lathe. A thin piece of sheet styrene was wrapped around the top & bottom to mimic the brass fixture.
The lenses were then painted with transparent paint which I made from clear acrylic and urethane tints.
Neal DeConte
Rhode Island
Your buddy could be right.  The photos do look like the real thing.  Wonderful work, Neal.
