11 hours ago, Veszett Roka said:
Didn't you consider to bash the motorboats a bit? Their shape quite off because the wheelhouse moved too far forward. They had brown wheelhouse and grey hull. Their aft deck was covered by an open top, not a solid structure though.
Panzerschiff_Admiral_Graf_Spee_before_th
This old kit has two of these boats and only one "open type" as you mentioned.
However most plans shows two motorboats and two crew boats around the funnel.
What I did is to get these two motor boats and drill them from the back with 1mm drill, something which is hardly visible on the pic.
For the color you are right I don't know how I came up with the desicion to paint the house grey, maybe tomorrow I remove the lifering and correct it.
Νew AA guns produced. Barrels were made of needles of various diameters. Cutting 3mm long pieces with rotary tool was troublesome and may didn't worth the extra detail. Nevertheless guns came up good looking.
Boats were repainted and the hunged ones were reglued with very tiny supports that  hardly are visible. Funny thing I didn't miss any part
IMG_20240116_190707.thumb.jpg.4cfd021fb746c4412341684f4cfb7df1.jpgIMG_20240117_195043.thumb.jpg.bc53f78f12eda304692a927aa80403fa.jpgIMG_20240117_203356.thumb.jpg.3d4863bf67bca7bd516f70ac11fb3eb3.jpgIMG_20240117_203549.thumb.jpg.9d703411c8eeb0243891c3b54c1d058b.jpg
Nice work.
If I remember correctly, I also made this model a long time ago.
I was about 10 years old at the time, I will be 60 next month 😁
On 1/20/2024 at 9:20 PM, Baker said:
Nice work.
Thanx
My first kit was USS Indianapolis from matchbox. My father got it from the local supermarket on toys section along with a tube of UHU glue.
Few years ago  I managed to buy a couple for my stash
Dome extra details added. Only things to add is the aircraft and rails. Then a new hull  paint required especially were its sides meet the wooden deck. Weathering and rigging of course.
I made the aircraft. PE parts were troublesome so I made a new frame for the floats. These also came together as a single piece to increase strength as some parts were as much as 0.20mm thick only.
Decals also were not precut. The whole decal sheet was a single piece. It was tricky to cut the tiny pieces around, so they can fit to the limited space, like wings and fuselage.
On 1/28/2024 at 12:21 AM, king derelict said:
Nice job on the aircraft Mike.
alan
Thanks. The added decals made some difference. Therefore I decided to paint the plane one tone lighter green so they can look better as they are mostly black.
Railing is done, added few more decals. Tomorrow I will spray with mat varnish, do weathering and oiling. Rigging is next and hopefully I will done the sea base by weekend.
Nice work.
I have never seen the red, white and black bands on the turrets on a German ship from that time
was this so then?
13 hours ago, Baker said:
Nice work.
was this so then?
Thank you. These are parts of the Decal sheet I ordered. They have been used on another  built which I used as a guide.There is also a black roof and a white circle which I didn't draw so I can avoid a paint disaster.
I am not aware of the exact date all I know its definitely before River Plate and after the search light platforms modification on the superstructure.
Oils done. Some chipping, rust effect and ready for rigging
IMG_20240201_211925.thumb.jpg.8e531cbd56e1a363e2e97aa3ba864cc1.jpgIMG_20240201_211903.thumb.jpg.4e80f955864bebfa47ed97e1dd490567.jpg
On 2/9/2024 at 3:59 PM, king derelict said:
Great work with the printer
alan
Thanks. It is an old printed with partially working screen and regular resin. Obviously is good to know how to get the best out of it before upgrade to another model.
I experiment  a bit with plaster and various tools to form the seabed but all come to dead end so I gave up.
Since my target was to create a light wavy sea, foam was replaced by wood. Then used gel to form the waves.A standard method. Only difference this time I use clear blue from Tamiya on top. Tomorrow will proceed with the final details.
IMG_20240206_185852.thumb.jpg.1ca7b66d8a1c3334cec69b6e3c4cab1f.jpgIMG_20240215_203403.thumb.jpg.be62da45ef0231894137dd7acf125272.jpgIMG_20240213_215744.thumb.jpg.b9685746e952d7e0b1a523c6cb1c5ca7.jpgIMG_20240215_190905.thumb.jpg.b996d511749c907ccc6eec9fcbdab452.jpgIMG_20240215_190948.thumb.jpg.bf1bb25bb1794d8d61a2d7c5a06e66b6.jpg
The lesson of the day.
The display looks symmetrical but its not.
Snow paste was used to resemble the waves. On the right i used brush with left and right moves with fading effect.
On the left my index finger was deeped in the paste then applied on the wood.
I found out that the first choice was more appropriate when making long stern wakes as the left and right water moves are quite visible. Perhaps I will try it on a  future smaller model as I will need a longer base.
beautiful-shot-motorboat-foam-trace-sea_181624-14983.jpg.86255abca623756607b3b14d619d7142.jpgbeautiful-shot-motorboat-foam-trace-sea_181624-14983.jpg.86255abca623756607b3b14d619d7142.jpg
So I balanced the sides by using airbrush on the left to fill in partially the blue gaps and by "indexfingering" the right one. Some airbrushing for smoother fading effect and a drizzle of microballoons. Lastly a few glitters on white foamy surfaces along with silicone bits.
The model assembly came quite good I would rate is 9 out 10 on my satisfaction scale.
The base it wasnt my planned outcome but turned ok. Maybe a few extra gel layers for thicker result would be better. I was pleased by 8 out of 10
IMG_20240217_154403.thumb.jpg.de970e332c103b803f6a05a43af341f7.jpgIMG_20240217_154705.thumb.jpg.f1652518896e08d21814e027be7a702e.jpgIMG_20240217_154849.thumb.jpg.6a48c266ebccdf896d84e767173c2d66.jpgIMG_20240217_154618.thumb.jpg.8a6a3065314cfecd81b5b115c444da74.jpgIMG_20240217_155416.thumb.jpg.2ccc7ef7519cf74653975a8f2f416233.jpg
22 hours ago, Chuck said:
Lovely work.
14 hours ago, king derelict said:
You are a master of seascapes Mike
alan
21 hours ago, CDW said:
Very nice work Mike
I thank all the members for their supporting comments as well all the silent followers.
21 hours ago, Baker said:
Much, much better than my attempt. 50 years ago 😉 👍
Great work.
You need to consider the information resources and the materials available back then and compare again.
  • 2 months later...
