Big thanks to all for your comments.
Part 13
The Case Completion
The Winter of '22-'23. Rains storms, high winds, and flooding rumbled through California. After years of drought, Mother Nature more than made up for it in three monthes.
In my drawings I planned to have the the left facing side hinged for access. I realized the arc of the travel would be too high and awkward. In addition the weight of the panel would put too much stress on the whole structure.
In order to keep the frames the same dimension all around I designed and built a corner mockup, seen below, with interlocking cuts. The outside piece remains in place as part of the case, while inside piece is the removable frame and its plex.
Now one may ask, how do you remove and replace the access panel? On each corner there is a quarter radious tab that turns 90 degrees to release the panel. With the two knobs pull and loosen the bottom, then with one hand hold the top and remove. Same way in reverse to install.
The final touch was engraving the builder's plate. When it finally has a patina I will polish the surface so the letters show up better.
Thank you all for showing interest and for your valued comments.
Edited by Steve Anderson
Just lovely. No other words for it. Well done!
BZ
Alan O'Neill
Amazing work. It’s stunning. Can i ask where did you find and buy plans? I am looking for them and I can’t find them anywhere. So I would be happy and grateful if you can help me with this issue. Could you please send me a link where you buy the plans. Thank you very much. Have a great day Gasper
  • 9 months later...
The contest opens on the 15th of June. I imagine all information will be available, and the website will be operational then.
Alan O'Neill
  • 3 months later...
