Hello everyone. I am posting 2 pics of my Corel. I want to get it right and then I will add more pics. This is my second build. I completed a Mantua Santa Maria many year ago.
This Wasa has been a lot of fun. I have torn sections out and rebuilt them as I have been able to view so many photos of the real ship. The stern, for example is wrong in the Corel kit. OK let's see if my first pics posts.
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
good to see you here, never noticed this build on the old MSW, but I will follow you, as I am also building the same kit
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
here are a few more pics. Thank you for looking
Under the table:
Completed:
Vasa-Corel -
Ahoy,  md1400cs :D
Beautiful work. I especially like your treatment of the "gilded metal".
Can I ask your overall opinion of the Corel kit? I am looking into purchasing one.
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
As others have stated......Beautiful details.
David
Current build: US Brig Niagara
Completed builds:  Oseberg Viking Ship - Billing Boats
                                   Armed Virginia Sloop - Model Shipways
                                   The Phantom - Model Shipways
Next project:  Amati's Xebec
A ship has all the discomforts and lack of privacy of a jail with none of its safety or stability - Benjamin Franklin
Quis custodiet ipso custodes?
Ahoy,  md1400cs :D
Hi Jpett,
Thank you for your kind words. Regarding the Corel SM13 I will put some thoughts together regarding this and post my thoughts.
Under the table:
Completed:
Vasa-Corel -
Here are some of the details that I decided to incorporate on my Corel Wasa. The bobinettes from the kit were incorrect. I used photos of the original as reference. Also, the Corel gilded pieces are also incorrect as additions to the Galeries. Here are pics of my attempt. Again, thanks for looking
Under the table:
Completed:
Vasa-Corel -
Hi md1400cs,
indeed very solid craftsmanship! I see that you have some pictures of the real Wasa on your laptop there. Nevertheless, do have a look at the pictures I uploaded in the following forum: http://modelshipworld.com/index.php?/topic/236-wasa-museum-pictures/#entry1924
I am also very much looking forward to your overall assessment of the Corel kit.
/Dominik
Current build: Rattlesnake 1781 (Mamoli)
Wow!
Very nice work md1400cs!! I especially like your jointery in the planking. Are the square nails included in the Corel kit? There is a randomness to their size that looks really cool in a rugged kind of way and it gives a hefty look to the planks. Nicely done!
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Hi md1499cs,
Beautiful job, I look forward to following your build and seeing the finished kit!
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Ahoy,  md1400cs :D
 My opinions of Corel’s SM13 Wasa are as
follows;
I purchased this kit many
years ago after having visited the museum. I did not do any research. The Corel
was the first one that I noticed and purchased it from Model Expo (a
consistently excellent supplier). As I proceeded with the build,
I decided that I wanted to add more details that were available from the kit
right out of the box. I also wanted to take my time and really improve my
skills as I went along. I was having a lot of fun.
I looked at, and filed many
photos of the original and started noticing several shortcomings, in terms of
accuracy, with Corel's example. There were several areas that were totally
wrong. Mmmmm, but I had progressed to a point where it was too late to adjust
the build in some areas.
First noted errors;
The five deck entry doors are
poorly shaped.
The bow entry doors are way
too thick.
The bow step-down side stairs
are incorrect.
The bow front railing is
incorrect (especially those dolphin gilded pieces)
The stern is too thin and
doesn't allow for the required gilded soldiers. In fact the entire stern is
wrong. I tore mine out and re-did it.
I'm only realizing these "issues" because I have researched so many photos. I also acquired a
set of plans from the museum.
OK. Some positive thoughts;
All framing is pre-cut. The gilded pieces are very well plated and well cast.
The instructions are adequate. Lumber is well cut, as are other wood pieces.
If one has no idea of what the real ship really looks like these criticisms would be vacuous, and benign.
The ship "out of the box" is none the less impressive, and is obviously the Vasa.
The one kit that is super accurate to the real Vasa is the Billings example. This kit is excellent to a
fault. However, I do believe that much of the wood parts are only inked onto
boards and then need to be cut. Also all of the very accurate gilding are made
of plastic. The completed kits that I have seen online looks so excellent. Nice
work on Billings part.
http://www.naturecoast.com/hobby/bil490.htm
If anyone has any specific
questions I will be happy to respond. And please any constructive criticism of
my project will be very appreciated, as this is only my second build, and I'm
new to your wonderful forum. Gee some of you have awesome projects.
MJD
Under the table:
Completed:
Vasa-Corel -
Wow!
Thank you for your nice words. No those nails are not part of the kit. I purchased these from a model railroad company. They are rail ties for HO and a smaller size as well. Micromark has most of the other very small nails.  Thanks for appreciating my intent with the randomness, per photos of the real ship, and it was the 1600's I thought that it would kind of look "ok"
MJD
Under the table:
Completed:
Vasa-Corel -
Hi md1400cs,
/Dominik
Dominik,
Thanks! some I did not have (:-)
MJD
Under the table:
Completed:
Vasa-Corel -
Ahoy MJD :D
Thank you for the reply. Your attention to detail and craftsmanship on this build is impressive. Thanks for sharing
  J.Pett
I can agree with the points you made in comparison with the Corel kit to the original. the Billing Boats kit is indead more accurate, but one remark is that the figures are made of plastic.
I decided also for the Corel as I have better experiance with Corel than with Billing Boats. See my buildlog
I enjoyed your modifications to the bow and the gallery, I noticed this just in time as I am starting with that part now.
Edited by JanV
Jan V.
JanV,
I think that that you will be happy with the Corel as most errors, as you noted, can be eliminated as you build. With so many photos available it will be easy to adapt the Corel. The only real issues are with the gilded pieces that are for all-intense-and-purposes mostly wrong. Nonetheless this example can be spectacular. I have noted your build so far. I'm very impressed. I'm looking forward to seeing your progress. Enjoy
MJD
Under the table:
Completed:
Vasa-Corel -
Here are examples on how I decided to do the Gallery framing. It was labor intensive but I sorta like the results.
I did use balsa to do the "castings" Very easy to shape.
Under the table:
Completed:
Vasa-Corel -
Here are some modifications that I have made to the stern of the Corel Wasa. It was woefully incorrect. It is still not "right" but I think that this is an improvement over the "out of the box" build.
I had initially been prepared to build, right from the instructions, and I did so. But as I proceeded I became dissatisfied and re-did certain sections. The stern was my first change, as this part did not effect other already assembled areas.
I am alson now removing the rear windows, as they are too wide, don't have enough inner frames and, they dont allow for the correct amount od soldiers standing along side. Though I think that this won't change. The problem lies within Corel's too narrow stern sizing. This was unavoidable, even before the start, because it would have been impossible to see this outcome before construction.
Also the gilded pieces that I used are not correct, but (:-) so it goes.I don't know how to add comments with each photo, but this progresses from the original kit through my mods.
PS: The chain is hanging because it will be replaced with a black one. Though I think that in the 16th cent. they might have used rope? Does anyone know (:-)
Under the table:
Completed:
Vasa-Corel -
I'm posting in retrospect. Close to catching up to the effort so far. Please note that the plain cannons are the
ones that come with the kit. I will be replacing the deck cannons  with the one in the pic. Not Swedish, but closer to the actual ones. I will also alter the carriages to more closely represent those from the ship.
This, only my second build, has been really helped by all of the available data. Data that are so helpful. I am also learning a lot from seeing some of your projects. Oh my some of you are astonishing artists.
Under the table:
Completed:
Vasa-Corel -
Spud1,
Thanks, I appreciate your comments. I also am learning so much from the many great artists who post their work, and assembly techniques on this board. I'm really a novice, and I fear that I will never reach the artistry of many builders here. But in the meantime its fun. A great hobby.
MJD
Under the table:
Completed:
Vasa-Corel -
Oops,
Decided to try again with the stern windows. The kit offerings were too wide, incorrectly framed, and just didn't look right. No solution has come to mind. But I need to make them thinner, and the framing has to be thought out again. Here are two pics. One of which is my original install and the other, of course, is the gutted out "to be fixed" pending solution.
I also made a mistake with the gallery hight. Too late Mmmm. If anyone has any suggestions they would be surely appreciated (:-)
MJD
Under the table:
Completed:
Vasa-Corel -
This set kinda brings some of the previous work up to date. In retrospect I see errors, but I'm my own worse critic. For example the toilets are very wrongly placed. The anchor rope outlets are not correct. Lastly the lower supporting longitudinal bowsprit braces need to be re-worked. The tips cracked, and look rough.So my repair list keeps growing.
However I'm seeing such fabulous work on this site; such a pleasure to see; I am learning so much. For example rigging Mmmm there are so many experts here. Thanks to all of you who post your updates, lov em.
MJD
Under the table:
Completed:
Vasa-Corel -
MJD,
I think we all tend to be our own worse critics. In case you don't see it, your work shows a great deal of artistry. The top view of the bow is stunning! I have the Billings version of this on the shelf but I'm trying to build up the chops to do it justice before I attempt it. I'm learning a lot from you!
-Buck
Buck,
Your very kind words are much appreciated. Thank you. I am also learning from so many here at MSW. I will need a lot of prompting when I get to both sets of rigging...down the road
The Billings kit is very accurate. I've seen photos of some beautifully built examples. It also looks great with sails. Good luck.
Look forward to your postings after you "take a deep breath" and start...
Michael D
Under the table:
Completed:
Vasa-Corel -
nice done that bowsprit. I am going to use your pictures as reference for mine.
I have remade the parts in wallnut wood.
Jan V.
Michael... you are definitely putting a lot of extra effort in your build. Makes me feel like I'm a lazy fellow.  B)
I did some modifications in my build, but nothing compared to what you're doing.
One thing I thought was that this is a 30+ year old kit. There was not so much information on this ship back then as there is now.. starting with the colors.
I wouldn't paint my ship the way it was originally painted, mind you.
I will keep following your build.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Interesting to see what you can do with a standard kit. I'm not so courageous and am building the kit without any modifications...
Current build: Wasa (Corel)
Already build: HMS Fly (Victory Models)
Ulises Victoria,
You make a very good point. It did not occur to me that Corel released this kit before the resurrection. Now, of course, there are so much data available. One would think that Corel would update their kit? Had it not been for all of the museum photos I would have built the ship right out of the box. Which would have still made for a beautiful model ship. I have seen several "out of the box" examples that are very beautiful. One of which has sails...very nice indeed.
As for other hobbies adding details can be a lot of fun. I'm thinking of model aircraft and model cars.
Michael D
Under the table:
Completed:
Vasa-Corel -
Very impressive indeed! I will be following your build intensely, as I am building a Wasa from Corel as well. I chose to paint it as best as I can according to the model in the Stockholm museum.
I have recently made the bow section, also little bit adjusted from the Corel drawings, but yours is really stunning!!
Andre
Completed:
Catalina from Mamoli (1/32)
European small river ship (scratch build) (1/50)
Currently building: Wasa from Corel (1/75)
Future: Titanic (Mantua), Batavia (Kolderstok), Friesland (Mamoli), Bismarck (Hachette), Prins Willem (Corel)
