48th Scale imperial rulers. Where?
Go to solution Solved by iMustBeCrazy,
Morning All,
I am in Australia. I have searched for 48th scale imperial rulers with no luck. I have bought two so far but whilst they both have 1:1 imperial scales, they both have the 48th scale reading metric as in the attached pic.
I don't want to keep importing this sort of mistake.
is anyone familiar with somewhere that does have this scale ruler?
Regards
John
Current builds:
Victory Models HMS Pegasus
https://modelshipworld.com/topic/38046-hms-pegasus-by-john-murray-amativictory-models-164/
Syren Ship Model Company HMS Winchelsea
https://modelshipworld.com/topic/38504-hms-winchelsea-1764-by-john-murray-148/
Builds on hold: Model Shipways 3 Kit Combo for Beginners. 1/48th HMS Echo Cross Section by Admiralty models.
Pending Builds: Victory Models HMS Vanguard
G'day John, best I can offer is that I posted a PDF with some scale rules I worked up in CAD. It prints to scale on my laser printer but you may have to make some adjustments when printing.
After printing I just put Scotch Magic tape each side then trim to size.
LINK
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
LINK
Thank you for that. I shall try that. 🙂
Regards
John
Current builds:
Look for some drafting scale rules on eBay. They come in all scales and "quarter-inch" is pretty common. In the U.S., triangular scales as pictured above commonly have a "quarter-inch" scale on one side. I've never seen one here with a combination of Imperial and Metric, although some engineer's scales (as opposed to architects' scales) will have inches divided into tenth's.
Alternately, 1:48 scale is equivalent to "O" gauge model railroad scale. You should be able to find a 1:48 scale rule offered for sale on a model railroading website.
See also: Triangular Scale Ruler for 1/12, 1/24, /1/32, 1/35, 1/48, 1/72 (L: 17cm) | eBay
  • Solution
The Excel 55777 fits the bill but for most of it's length it's resolution is 3 inches.
See also:
That one seems to be Metric only, the only one I can be sure of is the Tankraft Imperial Pro Modeler Scale Ruler. @John Murray
Craig.
Here's a PDF file of rulers in various scales and are not metric.   I print, verify that it matches a standard ruler and then cut out the one I want and glue it to a slab of wood.  After rechecking that there's deformation, I trim the now wooden ruler to size.
ImperialScales.pdf
Curious about the accuracy of my HP Envy printer, printed the attachment and was surprised the print to be dead on for all scales without
any adjustment. The pdf could be used as a calibration monitoring means for a printer. Also convenient comparison between the various
scales.
As an alternate suggestion, print it out on a suitable transparent media and protect the printed surface. Much easier to take dimensions
off a drawing using a transparent scale.    Now where do I save this file,?
Thank you Mark
Bridgman Bob
Bob, I have a folder in my model ship area on my PC HDD.   I keep files of all sorts there.   The HP Envy is pretty good printer all things considered though I wish they still made a printer (at a reasonable cost) for 11X17 paper.   The accuracy is come a long way on printers.  They used have a forced change such that they would never print exactly at 100% to stop counterfeiting.  But that went away when they started using the special paper with the embed strip in it.
I suggest, print it on your suitable clear media then spray it with a clear fixative.  You'll have to do some research on which works best as I"m not sure what's best.  Check with a local stationary shop as they can point you to clear media and fixative for the ink jet type printers.
USA tool maker, Starrett, makes steel rules graduated in 1/48 inch.  Six-inch-long, part # C601-6; 12-inch-long, part # C601-12.  Front and back, top and bottom of the rule make for four graduated edges.  One edge is graduated in 12ths, 24ths and 48ths.  The others give measurements in 10ths, 20ths, 50ths and 100ths; 16ths, 32nds and 64ths and lastly, 14ths and 28ths.  They will be very well made and surprisingly expensive.
You'd get your hand slapped for doing that in an old-school apprentice training program. In professional practice, measurements are never lifted from the drawomgs. (Many plans bear the notation, "Do not measure from drawings.") The distance notation on the plan is taken off an accurate rule with dividers and transferred to the workpiece using dividers. Even in modeling practice where one might be tempted to "cheat," with 1;1 plans, the better practice is to use dividers to take the distance from a plan, rather than using a rule. This insures accuracy. With a sharp eye and a good rule, measurement can be laid out far more accurately than by measuring from the plans with a rule. (Which is why good machinists' rules and dividers aren't cheap.)
23 hours ago, John Murray said:
Morning All,
Hi John,
I too am in Aus and I happen to have a 12 inch three-sided Imperial rule that includes 1:48. I no longer need this so if you pm me your address I'll send it to you.
Cheers
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
That will be the 3rd ruler from BNA... 🤣 However, that does have the scale I am after on it. Strange thing is, when I searched BNAs website, I did not find that one.
Regards
John
Current builds:
On 9/30/2022 at 6:17 AM, realworkingsailor said:
Try here for something more closer to your location:
https://www.bnamodelworld.com/index.php?route=product/search&search=Scale ruler
Andy
Just ordered it. :)
Regards
John
Current builds:
I have just ordered one, not starret though. Couldn't find one anywhere then this forum turns up loads of responses. :)
Regards
John
Current builds:
On 9/30/2022 at 4:40 PM, Richard44 said:
Hi John,
Cheers
Thank you very much for your kind offer. Unfortunately, I ordered one and then read your offer... Doh!
Regards
John
Current builds:
